depending on the device that depends on the author of the device. some are pre-defined by Matt/Jay other are defined by people that develop plugins.
In the DEVICE / EDIT screen you see everything that the device /plugin programmer has made available to be edited. There is likely some logic behind the screen Ie which fields to show if you select model a vs model b.. etc.
if you type into an action script menu (you find that under in action/ server/ scripts
indigo.server.log(unicode(indigo.devices["theDevicenameHere"])) ( keep the " )
you will see all info stored by indigo about the device like this:
- Code: Select all
batteryLevel : None
buttonGroupCount : 0
configured : True
description : cookieName=orange
deviceTypeId : MotherCookie
displayStateId : statusDisplay
displayStateImageSel : None
displayStateValRaw : 72.3°F
displayStateValUi : 72.3°F
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 913782042
com.karlwachs.mother : (dict)
BatteryIgnore : TRUE (string)
BatteryQueryWait : 600 (string)
MotionIgnore : FALSE (string)
MotionQueryWait : 900 (integer)
PresenceIgnore : FALSE (string)
PresenceQueryWait : 4 (integer)
PresenceQueryWait1 : 120 (string)
TemperatureIgnore : FALSE (string)
TemperatureQueryWait : 240 (string)
address : mTEa9t2G1yu6Q9MeYTNTBzZINW5Qt3A4 (string)
displayField : Temperature (string)
pullPush : false (bool)
lastChanged : 2015-05-18 19:36:30
model : Cookie
pluginId : com.karlwachs.mother
protocol : Plugin
remoteDisplay : True
states : States : (dict)
Battery_LastEventDate : 2015-05-03 14:21:07 (string)
Battery_LastStatusChange : 2015-05-03 14:21:07 (string)
Battery_ignore : true (string)
Battery_level : 2964 (string)
Motion_LastEventDate : 2015-05-03 00:19:12 (string)
Motion_LastStatusChange : 2015-05-03 00:19:12 (string)
Motion_data_0 : 0 (string)
Motion_data_1 : 52 (string)
Motion_data_2 : 300 (string)
Motion_data_3 : 30 (string)
Motion_ignore : false (string)
Motion_profile : WalkStandard (string)
Motion_queryWait : 900 (string)
Motion_string : {u'durationSeconds': 300, u'durationWalkSeconds': 30, u'numberSteps': 52} (string)
Presence : 2 (string)
Presence_LastEventDate : 2015-05-05 14:46:39 (string)
Presence_LastStatusChange : 2015-05-05 13:37:24 (string)
Presence_ignore : false (string)
Presence_queryWait : 4 (string)
Presence_string : {u'body': u'Present', u'code': 200} (string)
Signal : -61 (string)
Temperature : 72.32 (string)
Temperature_LastEventDate : 2015-05-18 19:33:42 (string)
Temperature_LastStatusChange : 2015-05-18 19:33:42 (string)
Temperature_ignore : false (string)
Temperature_ui : 72.3°F (string)
statusDisplay : 72.3°F (string)
subModel :
supportsAllOff : False
supportsStatusRequest : False
version : 0
ps there is also the menu option but that is similar to the device edit, just a different form factor for smaller changes.
