[ANSWERED]: Moving from Fibaro
Wed Nov 26, 2014 11:53 am
boz offline
I'm evaluating a move from Fibar hc2 to indigo, is there a way to reuse the zwave id:s somehow?
If I use aeon zwave stick on one device will it recognize the rest of them?
I'm thinking that the routing tabel is stored on every device or have I misunderstod that?
Fri Nov 28, 2014 11:52 am
Re: Moving from Fibaro.
The modules can only be includes with one main controller at a time (HC2 or Z-Stick), so you will need to exclude them from the old and include them with the new, individually. So it is somewhat of a pain, but you can do it piecemeal, defining the Indigo logic/schedules for the devices as you move them over while leaving the HC2 running for the un-migrated modules.
Sat Nov 29, 2014 9:20 am
boz offline
Re: [ANSWERED]: Moving from Fibaro
Aha ok thanks for the answer.
Sat Nov 29, 2014 5:17 pm
Madelaide offline
I have made this move too (Fibaro -> Indigo); As Matt said it is tedious, but works well; the z stick makes it relatively easy; go to a group of modules, disassociate them. Then go back and add a few in bulk to the stick, then scan and add to Indigo.
Apart from the occasional glitch, it has been MUCH more reliable than fibaro and a great use for my old macbook that was gathering dust!
Cheers
M
