[SOLVED]Multiple "Any" or "All" Conditions?
Mon Nov 11, 2013 3:57 pm
ckeyes888 offline
Somehow I was under the impression that it was possible to use multiple Any or All
conditions using the Conditions menu.
The + sign to the right of the Any All drop down menu just adds a new condition,
not a new Any All menu. Is that how it should work?
I have a few rather involved conditions I need to set up that would be much easier
to accomplish if I could have a list of Any and a list of All in the same condition.
Carl
Mon Nov 11, 2013 4:22 pm
ckeyes888 offline
Re: Multiple "Any" or "All" Conditions?
Doh. I use VNC viewer on my iPad a lot to do Indigo programming
which for some odd reason isn't sending a correct Option key command
to create a new submenu in the conditions.
Tried it on the Mac Mini's keyboard and it works fine.
Carl
Mon Dec 30, 2013 10:10 pm
Indy_Larry offline
I know this post is a month old but I was trying to do this tonight and not having any luck. I've tried to create multiple "Any" or "All" conditions using ARD and also through the Indigo client connecting to the server. Just wondering if this is a bug. I'm using ARD v3.7.1 and on IndigoPro v6.07. I'm doing this from a MacbookPro v10.9.1 ARDing/connecting into a MacPro running v10.7.5(indigo server). I keep getting additional conditions as well.
Thu Jan 02, 2014 6:47 pm
I suspect your problem is much the same - getting the remote client to correctly send the modifier keys. From Indigo's perspective, we're just using the standard Cocoa rule editor UI control which is designed to work by using the option key to add sub-groups. If it's not working with ARD then it's likely an ARD issue.
Thu Jan 02, 2014 8:13 pm
Indy_Larry offline
Thank you Jay, I honestly didn't think of using the option key in Indigo.
Thu Jan 02, 2014 9:08 pm
It's discussed in the Conditions section of the docs... :wink:
Mon May 11, 2015 4:25 pm
Turribeach offline
Re: [SOLVED]Multiple "Any" or "All" Conditions?
I got caught by this issue too. Perhaps a change in the UI could avoid having to use the option key and also "expose" the functionality so it is more visible? At first I wasn't even aware I could do this.
