Shelly Qubino Wave 1PM Mini
Sat Mar 30, 2024 7:50 pm
gillekes offline
Hi Matt,
I submitted a new device.
The device is recognised and the relay is working as expected. Still have to test power metering.
Z-Wave Indigo Device "066 - Wave 1PM Mini Relay Switch" Z-Wave Properties:
Indigo Z-Wave Version: 2023.2.0
Node ID: 66
Model: Relay Switch
Model ID: 0002008F
Manufacturer: Shelly
Manufacturer ID: 0460
Protocol Version: 7.19
Application Version: 11.01
Model Definition Version: 0
Library Type: 3
Class Name: Relay Switch
Class Hierarchy: 04 : 10 : 00
Command Class Base: 25
Command Versions: 20v1 25v1 5Ev1 98v1 9Fv1 55v1 86v1 6Cv1 73v1 60v4 87v1 7Av1 5Av1 8Ev1 59v1 85v1 70v1 71v1 32v6 72v1
Features: routing, beaming, security, energyMeter, powerMeter
Neighbors: 4, 9, 12, 14, 15, 17, 18, 19, 22, 25, 27, 30, 35, 47, 56
Associations: 1:[1] 2:[] 3:[]
Config Values: - none -
Thanks Gilles
