Sonos Python 3 Beta
Sat Nov 11, 2023 8:02 am
autolog offline
Re: Sonos Python 3 Beta
You could try a manual install:
  • Shutdown the Indigo Server
  • Copy the Sonos plugin into Indigo's plugin directory at:
    /Library/Application Support/Perceptive Automation/Indigo 2023.1/Plugins
    that is, assuming you are running 2023.1 (change as appropriate)
  • Restart the Indigo Server
See if that works or throws an error.
Sat Nov 11, 2023 9:07 am
MartynD offline
Hi Jon,
That worked ! Excellent. Everything seems fine and working as expected, I have 1 error message in the event log but it doesn't seem to stop anything working:
Sonos Error 'HTTP Error 403: Forbidden' in module 'request.py', method 'http_error_default [2023.0.30]'
Failing statement [line 643]: 'raise HTTPError(req.full_url, code, msg, hdrs, fp)'
Many thanks for your assistance .
Martyn
Sun Nov 19, 2023 3:51 pm
wideglidejrp offline
I am trying to add a bit more of a pause after each period in the text I submit for Polly. I inserted <break time="1000ms"/>. I got the following response.
John R Patrick
Author of
Home Attitude
Mon Nov 20, 2023 10:35 am
aldera offline
Running Indigo 2023.1 on a Macmini (M1) with Ventura 13.0.1 OS.
I installed all the python libraries and got the plugin running. However, I'm not sure how to fix the last 3 errors in the code below. There are no image files in the directory specified and there never were any image files in the prior version. I'm not a Unix guy so I don't really know how to fix it. Thanks for any help.
 Reloading plugin "Sonos 2023.0.27" using API v3.1
   Stopping plugin "Sonos 2023.0.27" (pid 74054)
   Sonos                           SoCo Reactor Landing...
   Stopped plugin "Sonos 2023.0.27"
   Starting plugin "Sonos 2023.0.27" (pid 81422)
   Sonos                           Plugin logging now started.
   Sonos                           Loaded Sonos Favorites... [12]
   Sonos                           Loaded Playlists... [13]
   Sonos                           Loaded RadioTime Favorite Stations... [0]
   Sonos                           Loaded Sound Files... [44]
   Sonos Error                     'User not yet authenticated' in module 'pandora.py', method 'check_authentication [2023.0.27]'
   Failing statement [line 12]: 'raise ValueError("User not yet authenticated")'
   Sonos                           [Wed Nov  8 20:26:15 2023] Processed plugin preferences.
   Sonos                           Plugin __init__ ended.
   Started plugin "Sonos 2023.0.27"
   Sonos                           Plugin startup started.
   Sonos                           Serving HTTP Streamer on 10.0.1.77 [0.0.0.0], port 8888
   Sonos                           Loaded Apple Voices.. [143]
   Sonos                           SSDP Listener Started...
   Sonos                           Plugin startup ended.
   Sonos                           Adding ZonePlayer: 10.0.1.58, RINCON_000E58750DD801400, SonosSpkr_AlanaKit
   Sonos                           Adding ZonePlayer: 10.0.1.59, RINCON_000E58C1855C01400, SonosSpkr_AlanaLR
   Sonos                           Adding ZonePlayer: 10.0.1.60, RINCON_5CAAFD46046201400, SonosSpkr_AlanaWR
   Sonos                           Adding ZonePlayer: 10.0.1.19, RINCON_542A1B85ABF101400, SonosSpkr_Beam
   Sonos                           Adding ZonePlayer: 10.0.1.43, RINCON_B8E93747BD1501400, SonosSpkr_FrontPorch
   Sonos                           Adding ZonePlayer: 10.0.1.36, RINCON_7828CA2979BA01400, SonosSpkr_Garage
   Sonos                           Adding ZonePlayer: 10.0.1.25, RINCON_000E58723DEE01400, SonosSpkr_MBR
   Sonos                           Adding ZonePlayer: 10.0.1.27, RINCON_000E58735A2001400, SonosSpkr_Office
   Sonos                           SoCo Reactor Ignition...
   Sonos Error                     '[Errno 13] Permission denied: '/Library/Application Support/Perceptive Automation/images/Sonos/Basement - KT_art.jpg'' in module 'Sonos.py', method 'processArt [2023.0.27]'
   Failing statement [line 1378]: 'localFile = open("/Library/Application Support/Perceptive Automation/images/Sonos/"+ZP_ZoneName+"_art.jpg", "wb")'
   Sonos Error                     '[Errno 13] Permission denied: '/Library/Application Support/Perceptive Automation/images/Sonos/Basement - LvRm_art.jpg'' in module 'Sonos.py', method 'processArt [2023.0.27]'
   Sonos Error                     '[Errno 13] Permission denied: '/Library/Application Support/Perceptive Automation/images/Sonos/Basement - WR_art.jpg'' in module 'Sonos.py', method 'processArt [2023.0.27]'
Mon Nov 20, 2023 1:06 pm
autolog offline
I think this might be caused by the plugin using lame to encode an mp3 file. It is embedded in the plugin otherwise it has to be installed using Homebrew.
If you get the error, I think you can click Cancel and then got to the Mac's Settings App and select the Privacy & Security tab, then scroll down until you get to the Some system software requires your attention before it can be used box, click Details... and OK the Indigo plugin if it is there. You might have to repeat this a couple of times and reload the plugin?
It is possibly being triggered if maybe you have updated MacOS?
Mon Nov 20, 2023 1:10 pm
autolog offline
I think this is probably triggered by Pandora not working and the resultant ZP_ZoneName being blank?
The code in this area should probably be enhanced?
If you are not using Pandora, then turning it off in the plugin config, should hopefully stop this error.
Tue Nov 21, 2023 1:23 pm
aldera offline
Unchecking Pandora did get rid of the authentication error but the "Permission Denied" errors are still there.
Fri Nov 24, 2023 1:13 pm
aldera offline
I got the 3 Sonos errors fixed. I just added three jpg files with the same names given in the error messages and now it's working fine.
Thanks again for updating this plugin to Python 3. Appreciate it!
Ralph
Sat Nov 25, 2023 12:53 pm
autolog offline
Hi Ralph,
A nice bit of lateral thinking! :D
Sat Jan 06, 2024 11:27 am
Seeker offline
just installed the newest version and I'm getting the Sirius error again.
Sonos Error SiriusXM Response: <Response [503]> [Reason: Service Unavailable]
Content: b'<html style="height:100%"><head><META NAME="ROBOTS" CONTENT="NOINDEX, NOFOLLOW"><meta name="format-detection" content="telephone=no"><meta name="viewport" content="initial-scale=1.0"><meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1"><script type="text/javascript" src="/_Incapsula_Resource?SWJIYLWA=719d34d31c8e3a6e6fffd425f7e032f3"></script></head><body style="margin:0px;height:100%"><iframe id="main-iframe" src="/_Incapsula_Resource?CWUDNSAI=4&xinfo=10-189608790-0%200NNN%20RT%281704561916179%203%29%20q%280%20-1%20-1%201%29%20r%280%20-1%29%20b6%20U24&incident_id=440001270304440364-1072902394145677258&edet=30&cinfo=ffffffff&rpinfo=0&mth=POST" frameborder=0 width="100%" height="100%" marginheight="0px" marginwidth="0px">Request unsuccessful. Incapsula incident ID: 440001270304440364-1072902394145677258</iframe></body></html>'
Sonos Error [Sat Jan 6 11:25:16 2024] SiriusXM SessionID communications error: mismatched tag: line 1, column 356
Sat Jan 06, 2024 4:12 pm
Seeker offline
downgraded to the 2023-11-23 fix you made and it is working with Sirius!
Mon Jan 08, 2024 5:14 pm
Seeker offline
Sonos Error 'name 'channels' is not defined' in module 'Sonos.py', method 'get_chan_parms_3_way [2023.0.27]'
Failing statement [line 3828]: 'l1 = max(len(x.get('channelId', '')) for x in channels)'
Mon Jan 08, 2024 5:27 pm
Seeker offline
I think I got it working again by updating/modifying the config settings and saving the config. fingers crossed.
Sun Jan 14, 2024 7:50 am
MarcoGT offline
With the last version on the plugin store I get following error
Sonos Error                     ''NoneType' object has no attribute 'startSpeakingString_toURL_'' in module 'Sonos.py', method 'actionAnnouncement [2023.1.0]'
   Failing statement [line 2579]: 'sp.startSpeakingString_toURL_(announcement, ru)'
Sun Jan 14, 2024 9:44 am
autolog offline
I need more information to to try and replicate and track this down.
How have you setup the action to speak the message?
