I have forked the 0.7.0 version and created version 0.8.0 and updated it to work with Python 3. You can get it here:
https://github.com/webdeck/SenseME-Indi ... tag/v0.8.0I was never able to upgrade from 0.6.0 to 0.7.0 myself due to errors. I believe I have fixed those errors, but it requires a workaround - after upgrading, if you see any errors, you need to reconfigure each fan device. Edit Device Settings for each device and click Save. That should fix it. You only need to do this the first time after upgrading.
This only works with the old firmware (Haiku by BAF app.)
I have done some refactoring of how commands are sent, and have added some extra error checking. I have done some minimal testing and it seems to work.
I also removed the version update checking.
You can report bugs on github here:
https://github.com/webdeck/SenseME-Indigo-Plugin/issues I will attempt to fix them, but I do not intend to maintain this plugin indefinitely. Hopefully someone can write a new plugin for the new firmware.
