recurring error, unifi access??
Tue Jul 18, 2023 12:23 pm
dtich online
i'm getting this recurring -- restarts, updates, no fix. thoughts? thanks!
is this a port setting perhaps? how can i remedy?
 uniFiAP Error                   HTTPSConnectionPool(host='192.168.100.100', port=8443): Read timed out. (read timeout=4.0); line#,Module,Statement:(532, 'send', 'raise ReadTimeout(e, request=request)')
   DSC Alarm                       Alarm Zone 'alarm/motion/office (8)' Closed.
   DSC Alarm                       Alarm Zone 'alarm/motion/office (8)' Opened.
   DSC Alarm                       Alarm Zone 'alarm/motion/living room (6)' Opened.
   DSC Alarm                       Alarm Zone 'alarm/motion/living room (6)' Closed.
   DSC Alarm                       Alarm Zone 'alarm/door/front door (1)' Opened.
   Trigger                         alarmcomm sets frontdoor var ON
   DSC Alarm                       Alarm Zone 'alarm/door/front door (1)' Closed.
   Trigger                         alarmcomm sets frontdoor var OFF
Jul 18, 2023 at 11:18:08 AM
Jul 18, 2023 at 11:18:29 AM
Jul 18, 2023 at 11:18:47 AM
   Indigo Cocoa client authenticated (192.168.100.127)
Jul 18, 2023 at 11:21:06 AM
Tue Jul 18, 2023 1:27 pm
Re: recurring error, unifi access??
Do you have 2 factor id on?
And naturally any change in userid pwd etc?
Tue Jul 18, 2023 1:37 pm
dtich online
no 2FA, and no change to id/etc, no. no changes in many months.
thanks karl!
Tue Jul 18, 2023 1:39 pm
What is your setup is what controller. It shows port 8443. Is that correct?
Tue Jul 18, 2023 1:44 pm
dtich online
i did not set the port, i believe the plugin set it automatically. it seems that is the issue, but i've found now way to change it.. i mean, there is a way, but it always worked without error before without any changes.
what should i look for? i have not set the port on the unifi controller no. it should still be default, which is assume is 80? or .. i'll check. not sure.
thx
Tue Jul 18, 2023 1:55 pm
dtich online
this is the url that the controller accesses when opening the dashboard:
https://localhost:8443/manage/account/l ... =%2Fmanage
so, yes. 8443. works fine from browser. BUT, it does take more than 4s to load usually. not sure same applies to a json or curl, but it does take a bit in html.
fwiw.
Tue Jul 18, 2023 2:04 pm
Why is it that long? Has that changed?
I will check what the time out param is
Tue Jul 18, 2023 2:20 pm
dtich online
believe that timeout is set at 4s, that's what the error says...
Tue Jul 18, 2023 2:28 pm
please try v ...385 just posted I have set all timeouts to 8 secs. that should be plenty.
Tue Jul 18, 2023 3:01 pm
dtich online
so, still getting this error:
   uniFiAP Error                   HTTPSConnectionPool(host='192.168.100.100', port=8443): Read timed out. (read timeout=10.0); line#,Module,Statement:(532, 'send', 'raise ReadTimeout(e, request=request)')
Jul 18, 2023 at 1:58:09 PM
but the system is communicating as units are popping online right after initialization of the plugin... odd?
Tue Jul 18, 2023 3:04 pm
The plugin uses several sources to get info
It would work 99% w/o http
To the controller
Some reports would be missing
and you can select to have the controller info check the info from the ap and switches
Tue Jul 18, 2023 3:05 pm
And did you install the new version?
Tue Jul 18, 2023 3:19 pm
dtich online
yes this is v .385 running.
thx Karl!
Tue Jul 18, 2023 3:25 pm
dtich online
this is log after i just reloaded plugin again.
Jul 18, 2023 at 2:20:25 PM
   Reloading plugin "uniFiAP 2022.42.385" using API v3.0
   Stopping plugin "uniFiAP 2022.42.385" (pid 63903)
   uniFiAP Warning                 getMessages: stopping listener process for :APdict - 192.168.100.10
   uniFiAP Warning                 getMessages: stopping listener process for :APtail - 192.168.100.10
   uniFiAP                         after loop , quitNow= >><<
   uniFiAP Warning                 getMessages: stopping listener process for :APdict - 192.168.100.11
   uniFiAP Warning                 getMessages: stopping listener process for :SWdict - 192.168.100.20
   uniFiAP Warning                 getMessages: stopping listener process for :SWdict - 192.168.100.21
   uniFiAP Warning                 getMessages: stopping listener process for :SWdict - 192.168.0.6
   uniFiAP Warning                 getMessages: stopping listener process for :APtail - 192.168.100.11
   uniFiAP Warning                 getMessages: stopping listener process for :SWdict - 192.168.0.5
   uniFiAP Warning                 comsumeLogData: stopping process due to stop request
   uniFiAP Warning                 comsumeDictData: stopping process due to stop request
   Stopped plugin "uniFiAP 2022.42.385"
   Starting plugin "uniFiAP 2022.42.385" (pid 65313)
   uniFiAP                         initializing  ...
   uniFiAP                         path To files:          =================
   uniFiAP                         detailed logging        /Library/Application Support/Perceptive Automation/Indigo 2022.2/Logs/com.karlwachs.uniFiAP/plugin.log
   uniFiAP                         testing logging levels, for info only:
   uniFiAP                         logger  enabled for     INFO           ==> TEST ONLY
   uniFiAP Warning                 logger  enabled for     WARNING        ==> TEST ONLY
   uniFiAP Error                   logger  enabled for     ERROR          ==> TEST ONLY
   uniFiAP Error                   logger  enabled for     CRITICAL       ==> TEST ONLY
   uniFiAP                         using '/Library/Frameworks/Python.framework/Versions/Current/bin/python3' for utily programs
   Started plugin "uniFiAP 2022.42.385"
   uniFiAP                         debug settings :[]
   uniFiAP                         initialized ... looping
Jul 18, 2023 at 2:21:04 PM
   uniFiAP                         after loop , quitNow= >>new devices<<
   uniFiAP                         runConcurrentThread stopping plugin due to:  ::::: new devices :::::
   Stopping plugin "uniFiAP 2022.42.385" (pid 65313)
   uniFiAP Error                   plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
   Starting plugin "uniFiAP 2022.42.385" (pid 65636)
Jul 18, 2023 at 2:23:00 PM
   Stopping plugin "uniFiAP 2022.42.385" (pid 65636)
   Starting plugin "uniFiAP 2022.42.385" (pid 66037)
Jul 18, 2023 at 2:24:04 PM
Tue Jul 18, 2023 3:26 pm
dtich online
this is the full error line, not sure why it cut off in that last paste, maybe formatting..?
