Line Numbering in Script Editor
Thu May 11, 2023 7:47 am
SearchCz offline
Sometimes I see scripting errors in the activity log, with references to the approximate line number on which the error occurred. Like this:
Script Error around line 4 - "aDuration = str(xMinutes)f"
"Around line 4" is easy enough to manage, but when its "around line 123" that's aa little harder. Line numbering in the script editor would sure help with that.
Thu May 11, 2023 7:57 am
Re: Line Numbering in Script Editor
That would be helpful for sure, but what I do is copy the script into another editor like BBEdit (basic version is free) and use that to identify the offending line. Another more advanced tool is Visual Studio which is also free and that will also help identify problems.
Thu May 11, 2023 12:10 pm
FWIW, I think a script that is large enough to require tracking down issues using line numbers should probably be run as a separate script file. Text editors geared to writing code are much better for developing scripts in general, and the longer/more complex a script gets the better an external editor will serve you in a variety of ways.
Thu May 11, 2023 1:47 pm
SearchCz offline
I'll try it !
Should I expect any change in performance holding the script in an external file?
Thu May 11, 2023 3:48 pm
Nope.
Thu May 11, 2023 4:01 pm
Two other bonus features with linked scripts are that they run in their own process, and they're not subjected to the 10-second time limit (like embedded scripts are).
