Bond Home Issue with Ceiling Fan
Tue Feb 28, 2023 5:20 pm
Re: Bond Home Issue with Ceiling Fan
OK, well, I have no ideas for a quick fix, and I'm leaving in the morning for three weeks, so it's not going to get fixed real soon. Sorry.
Please open an issue in GitHub and put those logs in there so I don't forget.
Tue Feb 28, 2023 6:31 pm
vvrangler offline
I also noticed that the v3 docs indicate that the IncreaseSpeed acts differently than the DecreaseSpeed, does the plugin send a number value to these actions?
Actions
SetSpeed(speed): Set speed and turn on. If speed>max_speed, max_speed is assumed. If the fan is off, implicitly turn on the power. Setting speed to zero or a negative value is ignored.
IncreaseSpeed(speeds): Increase speed of fan by specified number of speeds. If the fan is off, implicitly turn on the power.
DecreaseSpeed(speeds): Decrease fan speed by specified number of speeds. If attempting to decrease fan speed below 1, the fan will remain at speed 1. That is, power will not be implicitly turned off. If the power is already off, DecreaseSpeed is ignored.
Tue Feb 28, 2023 6:36 pm
Yeah, that's the problem. It didn't used to require a parameter. I guess now it does. You can see that nothing is getting sent since the parameters are "{}".
Tue Feb 28, 2023 6:39 pm
So put a "1" in the parameter field on the action and see what happens.
