Hi all,
I'm having no luck associating this Zooz temperature sensor with this new USB stick.
Are there any known issues with the Zooz 800 and Indigo?
Z-Wave Debug SENT enterInclusionMode: 01 04 00 4A C1 70
Z-Wave Debug RCVD enterInclusionMode: 06 (ACK)
Z-Wave started controller inclusion mode
Z-Wave Debug RCVD inclusionMode ready: 01 07 00 4A 01 01 00 00 B2
Z-Wave Debug RCVD inclusionMode node found: 01 07 00 4A 01 02 00 00 B1
Z-Wave Debug RCVD inclusionMode adding slave node: 01 1B 00 4A 01 03 06 14 04 10 00 5E 25 70 85 8E 59 32 71 55 86 72 5A 87 73 9F 6C 7A 36
Z-Wave Debug RCVD inclusionMode node respondCmds: 5E 25 70 85 8E 59 32 71 55 86 72 5A 87 73 9F 6C 7A
Z-Wave Debug RCVD inclusionMode node added: 01 07 00 4A 01 05 06 00 B0
Z-Wave Debug SENT exitInclusionMode: 01 04 00 4A 05 B4
Z-Wave Debug RCVD exitInclusionMode: 06 (ACK)
Z-Wave Debug RCVD inclusionMode finished: 01 07 00 4A 01 06 06 00 B3
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 06 BC
Z-Wave Debug RCVD getNodeProtocolInfo: 01 0A 01 41 D3 9C 01 04 10 00 00 EF (no inbound callback)
Z-Wave Debug . . getNodeProtocolInfo: node 006, class name: Relay Switch
Z-Wave Debug . . getNodeProtocolInfo: class hierarchy: Routing Slave : Relay Switch : -- (04 : 10 : 00)
Z-Wave Debug . . getNodeProtocolInfo: base class command: 25
Z-Wave Debug . . getNodeProtocolInfo: supported class commands: 20 25 5E 70 85 8E 59 32 71 55 86 72 5A 87 73 9F 6C 7A
Z-Wave Debug . . getNodeProtocolInfo: encrypt class commands:
Z-Wave Debug . . getNodeProtocolInfo: features: routing, beaming
Z-Wave controller included module: 006 - Relay Switch
Z-Wave stopped controller inclusion mode
Feb 28, 2023 at 12:13:20 PM
Z-Wave Debug intiatingSyncUI (timeout in 1500 seconds)
Z-Wave Syncing - started for "006 - Relay Switch"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 06 01 01 7F
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 57 (no inbound callback)
Z-Wave Debug . . getNodeNeighbors: nodeId 006, neighbors: 1, 4
Z-Wave Syncing - retrieved module neighbors list: 1, 4
Z-Wave Syncing - assigning return route to "006 - Relay Switch"
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 06 01 BB
Z-Wave Debug RCVD assignReturnRoute: 01 04 01 46 01 BD (no inbound callback)
Z-Wave Debug RCVD assignReturnRoute: 01 21 00 46 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 99
Z-Wave Debug . . assignReturnRoute: node 006, success 1
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 06 24 56 ED
Z-Wave Debug RCVD nodeInfoFrame: 01 1A 00 49 84 06 14 04 10 00 5E 25 70 85 8E 59 32 71 55 86 72 5A 87 73 9F 6C 7A B2
Z-Wave Debug . . nodeInfoFrame: node 006, combined class list: 20v1 25v1 5Ev1 70v1 85v1 8Ev1 59v1 32v1 71v1 55v1 86v1 72v1 5Av1 87v1 73v1 9Fv1 6Cv1 7Av1
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 06 02 72 04 25 57 E5
Z-Wave Debug RCVD requestManufactureInfo: 01 1D 00 13 57 00 00 01 00 C0 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 7F 7F 7F 7F 7F 19 (node ACK)
Z-Wave Debug RCVD requestManufactureInfo: txTransmitTicks 1, txHopCount 0, txRSSIs 192 127 127 127 127, txACKChannelNum 0, txLastTxChannelNum 0, txRouteSchemeState 3, txRoute 0 0 0 0, txRouteSpeed 3, txRouteTries 1, txLastFailedLinkFrom 0, txLastFailedLinkTo 0
Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 06 08 72 05 02 7A 70 00 B0 02 44
Z-Wave Debug . . requestManufactureInfo: node 006, manufacturerId 027A, productId 7000B002
Z-Wave Debug . . requestManufactureInfo: Zooz, Relay Switch
Z-Wave Syncing - retrieved manufacture and model names: Zooz - 027A, Relay Switch - 7000B002
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 06 02 86 11 25 58 0B
Z-Wave Debug RCVD requestVersInfoGen: 01 1D 00 13 58 00 00 01 00 C0 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 7F 7F 7F 7F 7F 16 (node ACK)
Z-Wave Debug RCVD requestVersInfoGen: txTransmitTicks 1, txHopCount 0, txRSSIs 192 127 127 127 127, txACKChannelNum 0, txLastTxChannelNum 0, txRouteSchemeState 3, txRoute 0 0 0 0, txRouteSpeed 3, txRouteTries 1, txLastFailedLinkFrom 0, txLastFailedLinkTo 0
Z-Wave Debug RCVD requestVersInfoGen: 01 0F 00 04 00 06 09 86 12 03 07 0D 01 0A 01 00 1C
Z-Wave Debug . . requestVersInfoGen: node 006, protoVers 7.13, appVers 1.10
Z-Wave Syncing - retrieved protocol version 7.13, app version 1.10
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 06 03 86 13 32 25 59 38
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 1D 00 13 59 00 00 01 00 C0 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 7F 7F 7F 7F 7F 17 (node ACK)
Z-Wave Debug RCVD requestVersInfoCmdClass: txTransmitTicks 1, txHopCount 0, txRSSIs 192 127 127 127 127, txACKChannelNum 0, txLastTxChannelNum 0, txRouteSchemeState 3, txRoute 0 0 0 0, txRouteSpeed 3, txRouteTries 1, txLastFailedLinkFrom 0, txLastFailedLinkTo 0
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 06 04 86 14 32 05 3C
Z-Wave Debug . . requestVersInfoCmdClass: node 006, class command 32 using version 5
Z-Wave Debug . . requestVersInfoCmdClass: node 006, combined class list: 20v1 25v1 5Ev1 70v1 85v1 8Ev1 59v1 32v5 71v1 55v1 86v1 72v1 5Av1 87v1 73v1 9Fv1 6Cv1 7Av1
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Relay Switch : -- (04 : 10 : 00, base 25)
Z-Wave Syncing - retrieved command classes: 20v1 25v1 5Ev1 70v1 85v1 8Ev1 59v1 32v5 71v1 55v1 86v1 72v1 5Av1 87v1 73v1 9Fv1 6Cv1 7Av1
Z-Wave Syncing - retrieved encrypt commands: - none -
Z-Wave Syncing - retrieved capabilities: routing, beaming
Z-Wave Debug SENT requestAssociationGroupCount: 01 09 00 13 06 02 85 05 25 5A 1E
Z-Wave Debug RCVD requestAssociationGroupCount: 01 1D 00 13 5A 00 00 01 00 C0 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 7F 7F 7F 7F 7F 14 (node ACK)
Z-Wave Debug RCVD requestAssociationGroupCount: txTransmitTicks 1, txHopCount 0, txRSSIs 192 127 127 127 127, txACKChannelNum 0, txLastTxChannelNum 0, txRouteSchemeState 3, txRoute 0 0 0 0, txRouteSpeed 3, txRouteTries 1, txLastFailedLinkFrom 0, txLastFailedLinkTo 0
Z-Wave Debug RCVD requestAssociationGroupCount: 01 09 00 04 00 06 03 85 06 02 1F
Z-Wave Debug . . requestAssociationGroupCount: node 006, group count: 2
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 06 03 85 02 01 25 5B 1B
Z-Wave Debug RCVD requestAssociations: 01 1D 00 13 5B 00 00 01 00 C0 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 7F 7F 7F 7F 7F 15 (node ACK)
Z-Wave Debug RCVD requestAssociations: txTransmitTicks 1, txHopCount 0, txRSSIs 192 127 127 127 127, txACKChannelNum 0, txLastTxChannelNum 0, txRouteSchemeState 3, txRoute 0 0 0 0, txRouteSpeed 3, txRouteTries 1, txLastFailedLinkFrom 0, txLastFailedLinkTo 0
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 06 05 85 03 01 05 00 18
Z-Wave Debug . . requestAssociations: node 006, group: 1, num associations: 0, max associations: 5, replies left: 0
Z-Wave Debug . . requestAssociations: node 006, group: 1, associations: []
Z-Wave Syncing - retrieved group 1 associations: []
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 06 03 85 02 02 25 5C 1F
Z-Wave Debug RCVD requestAssociations: 01 1D 00 13 5C 00 00 01 00 C1 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 7F 7F 7F 7F 7F 13 (node ACK)
Z-Wave Debug RCVD requestAssociations: txTransmitTicks 1, txHopCount 0, txRSSIs 193 127 127 127 127, txACKChannelNum 0, txLastTxChannelNum 0, txRouteSchemeState 3, txRoute 0 0 0 0, txRouteSpeed 3, txRouteTries 1, txLastFailedLinkFrom 0, txLastFailedLinkTo 0
Z-Wave Debug RCVD requestAssociations: 01 0B 00 04 00 06 05 85 03 02 05 00 1A
Z-Wave Debug . . requestAssociations: node 006, group: 2, num associations: 0, max associations: 5, replies left: 0
Z-Wave Debug . . requestAssociations: node 006, group: 2, associations: []
Z-Wave Syncing - retrieved group 2 associations: []
Z-Wave Debug SENT addInterfaceAssociation: 01 0B 00 13 06 04 85 01 01 01 25 5D 19
Z-Wave Debug RCVD addInterfaceAssociation: 01 1D 00 13 5D 00 00 01 00 C1 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 7F 7F 7F 7F 7F 12 (node ACK)
Z-Wave Debug RCVD addInterfaceAssociation: txTransmitTicks 1, txHopCount 0, txRSSIs 193 127 127 127 127, txACKChannelNum 0, txLastTxChannelNum 0, txRouteSchemeState 3, txRoute 0 0 0 0, txRouteSpeed 3, txRouteTries 1, txLastFailedLinkFrom 0, txLastFailedLinkTo 0
Z-Wave Syncing - added group 1 association to interface
Z-Wave Debug . . addInterfaceAssociation: node 006, group: 1, associations: [1]
Z-Wave Debug SENT requestMeterInfo: 01 09 00 13 06 02 32 03 25 5E AB
Z-Wave Debug RCVD requestMeterInfo: 01 1D 00 13 5E 00 00 01 00 C1 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 7F 7F 7F 7F 7F 11 (node ACK)
Z-Wave Debug RCVD requestMeterInfo: txTransmitTicks 1, txHopCount 0, txRSSIs 193 127 127 127 127, txACKChannelNum 0, txLastTxChannelNum 0, txRouteSchemeState 3, txRoute 0 0 0 0, txRouteSpeed 3, txRouteTries 1, txLastFailedLinkFrom 0, txLastFailedLinkTo 0
Z-Wave Debug RCVD requestMeterInfo: 01 0A 00 04 00 06 04 32 04 A1 35 3A
Z-Wave Debug . . requestMeterInfo: node 006, meterType 01, subTypeFlags 35, supportsReset True
Z-Wave Syncing - changed device "005 - Relay Switch" address from undefined to 006
Z-Wave Syncing - complete
Z-Wave Debug terminatingSyncUI
Z-Wave Debug SENT enter_exclusion_mode: 01 04 00 4B 81 31
Z-Wave Debug RCVD enter_exclusion_mode: 06 (ACK)
Z-Wave started controller exclusion mode
Z-Wave Debug RCVD exclusionMode ready: 01 07 00 4B 02 01 00 00 B0
Z-Wave Debug RCVD exclusionMode node found: 01 07 00 4B 02 02 00 00 B3
Z-Wave Debug RCVD exclusionMode removing slave node: 01 1B 00 4B 02 03 06 14 04 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A8
Z-Wave Debug RCVD exclusionMode finished: 01 1B 00 4B 02 06 06 14 04 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 AD
Z-Wave Debug . . exclusionMode node removed: 006
Z-Wave controller excluded module: 006 - 005 - Relay Switch
Z-Wave Error device "005 - Relay Switch" no longer has a matching module 006 in the controller
Z-Wave Error to re-enable the device with a new z-wave module, press the "Define and Sync..." button in the device dialog
Z-Wave Debug SENT exitExclusionMode: 01 04 00 4B 05 B5
Z-Wave Debug RCVD exitExclusionMode: 06 (ACK)
Z-Wave stopped controller exclusion mode
Z-Wave Debug RCVD inclusionMode adding slave node: 01 1B 00 4A 01 03 02 14 04 10 00 5E 25 70 85 8E 59 32 71 55 86 72 5A 87 73 9F 6C 7A 32
Z-Wave Debug RCVD inclusionMode node added: 01 07 00 4A 01 05 02 00 B4
Z-Wave Debug RCVD inclusionMode finished: 01 07 00 4A 01 06 02 00 B7
Z-Wave Debug SENT getNodeProtocolInfo: 01 04 00 41 02 B8
Z-Wave Debug . . getNodeProtocolInfo: node 002, class name: Relay Switch
Z-Wave controller included module: 002 - Relay Switch
Z-Wave Syncing - started for "002 - Relay Switch"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 02 01 01 7B
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5F (no inbound callback)
Z-Wave Debug . . getNodeNeighbors: nodeId 002, neighbors: 1
Z-Wave Syncing - assigning return route to "002 - Relay Switch"
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 02 01 BF
Z-Wave Debug . . assignReturnRoute: node 002, success 1
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 02 24 5F E0
Z-Wave Debug RCVD nodeInfoFrame: 01 1A 00 49 84 02 14 04 10 00 5E 25 70 85 8E 59 32 71 55 86 72 5A 87 73 9F 6C 7A B6
Z-Wave Debug . . nodeInfoFrame: node 002, combined class list: 20v1 25v1 5Ev1 70v1 85v1 8Ev1 59v1 32v1 71v1 55v1 86v1 72v1 5Av1 87v1 73v1 9Fv1 6Cv1 7Av1
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 02 02 72 04 25 60 D6
Z-Wave Debug RCVD requestManufactureInfo: 01 1D 00 13 60 00 00 01 00 B1 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 7F 7F 7F 7F 7F 5F (node ACK)
Z-Wave Debug RCVD packet: 01 11 00 A8 00 01 02 08 72 05 02 7A 70 00 B0 02 00 B1 31 (hex)
Z-Wave Debug timeout waiting for reply from module (non-fatal, skipping request)
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 02 02 86 11 25 61 36
Z-Wave Debug RCVD requestVersInfoGen: 01 1D 00 13 61 00 00 01 00 AE 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 7F 7F 7F 7F 7F 41 (node ACK)
Z-Wave Debug RCVD packet: 01 12 00 A8 00 01 02 09 86 12 03 07 0D 01 0A 01 00 00 AE 76 (hex)
Z-Wave Debug timeout waiting for reply from module (retrying)
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 02 02 86 11 25 62 35
Z-Wave Debug RCVD requestVersInfoGen: 01 1D 00 13 62 00 00 01 00 B1 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 7F 7F 7F 7F 7F 5D (node ACK)
Z-Wave Debug RCVD packet: 01 12 00 A8 00 01 02 09 86 12 03 07 0D 01 0A 01 00 00 B1 69 (hex)
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 02 02 86 11 25 63 34
Z-Wave Debug RCVD requestVersInfoGen: 01 1D 00 13 63 00 00 01 00 B1 7F 7F 7F 7F 00 00 03 00 00 00 00 03 01 00 00 7F 7F 7F 7F 7F 5C (node ACK)
Z-Wave Debug RCVD packet: 01 12 00 A8 00 01 02 09 86 12 03 07 0D 01 0A 01 00 00 B0 68 (hex)
Z-Wave Debug maximum retry count exceeded waiting reply from module
Z-Wave Error Syncing - failed
Z-Wave Error Timeout waiting for "002 - Relay Switch". Module might be asleep, or is unreachable.
matt (support) wrote:Thanks, I think I see the problem. I'm going to email you offline.
Users browsing this forum: No registered users and 31 guests
