You can get the current plugin here:
https://github.com/FlyingDiver/Indigo-S ... s/main.zipThis version requires that you have Simplisafe configured to use SMS to send an auth code for a new device login, like when logging into the website. Some installs send an email. The code is there to support that, but I have not been able to test it.
Open the Indigo log to look for messages from the plugin. Enter your account login info in the config dialog and save. Then use the plugin menu item to start authentication. You'll get a text message with the code. Paste or enter into dialog box and verify. Hopefully you'll get the authentication successful message.
Then create a Simplisafe system device, and then devices for your sensors, etc.
Let me know if you have devices that aren't showing up in the create device lists, or aren't showing the correct state info.
I don't have a keyfob, glass break, or siren so I'm not sure if they'll do anything.
I'm also going on vacation in a week, so don't expect too much work on it until next month.
