SMUSEBY wrote:I just received my first engraved keypads, and may have made a rookie mistake. I'm not trying to use the raise lower feature with the pair of bottom buttons; I was hoping to treat the pair of them as the same as buttons 1-6. However, I am unable to get Indigo to recognize a button press (the engraved keypad presses both of them with button #7). Is the simultaneous push a problem? Is there some way to make Indigo to respond to the bottom button?
Lutron RRA2/Caséta Debug Lutron IP Gateway: 17 characters read:
b'~DEVICE,22,18,4\r\n'
Lutron RRA2/Caséta Debug Lutron IP Gateway: self.buffer = 'b'~DEVICE,22,18,4\r\n''
Lutron RRA2/Caséta Debug Lutron IP Gateway: msg = 'b'~DEVICE,22,18,4\r''
Lutron RRA2/Caséta Debug Lutron IP Gateway: self.buffer = 'b'''
Lutron RRA2/Caséta Debug Received command: ~DEVICE,22,18,4 from Gateway 68394
Lutron RRA2/Caséta Debug Received a Device message: ~DEVICE,22,18,4
Lutron RRA2/Caséta Debug Received a keypad button/LED status message: ~DEVICE,22,18,4
Lutron RRA2/Caséta Debug buttonMultiPressCheck: Timeout reached for keypadid = 68394:22.18, presses = 1
Lutron RRA2/Caséta Debug A linked device (2 mBdRm rssBurLmps 003 - Both Switches) has been updated: True
Lutron RRA2/Caséta Debug 2 mBdRm - kPd N - Button 063.04 - RSS Bur LED: actionControlDimmerRelay sending: '#DEVICE,63,84,9,1' to gateway 68394
Lutron RRA2/Caséta Debug Lutron IP Gateway: Sending: '#DEVICE,63,84,9,1'
Lutron RRA2/Caséta Debug Lutron IP Gateway: 10 characters read:
b'~ERROR,2\r\n'
Lutron RRA2/Caséta Debug Lutron IP Gateway: self.buffer = 'b'~ERROR,2\r\n''
Lutron RRA2/Caséta Debug Lutron IP Gateway: msg = 'b'~ERROR,2\r''
Lutron RRA2/Caséta Debug Received command: ~ERROR,2 from Gateway 68394
Lutron RRA2/Caséta Debug Gateway 68394 received: ~ERROR,2
Lutron RRA2/Caséta Debug Lutron IP Gateway: 6 characters read:
b'GNET> '
SMUSEBY wrote:Can I gather by a lack of reply that I need to forget about using button #7 with indigo?
