Jul 1, 2022 at 9:57:41 AM
Trigger MQTT Connector Event
ShellyNGMQTT received "new device 1" off
Jul 1, 2022 at 9:58:30 AM
ShellyNGMQTT sent "new device 1" on
Jul 1, 2022 at 9:59:33 AM
ShellyNGMQTT sent "new device 1" off
Jul 2, 2022 at 8:56:58 AM
ShellyNGMQTT sent "Back Wall Lighjts 1 MQTT 1" off
ShellyNGMQTT sent "Front Wall Lights 1 MQTT 1" off
ShellyNGMQTT sent "Front Wall Lights 2 MQTT 1" off
Jul 2, 2022 at 8:57:40 AM
pgershon wrote:Sorry to keep posting nut I am trying to get to the bottom of this issue and provide as much information so other can help me diagnose.
I am using MQTT Explorer in conjunction with Indigo and the Shelly app.
What am I missing?
cuhouse wrote:It does not matter if you write shellies or something else as long as you are consistent and have a trigger. Many of us use shellies-ng for ShellyMqtt NG to differentiate from ShellyMqtt.pgershon wrote:Sorry to keep posting nut I am trying to get to the bottom of this issue and provide as much information so other can help me diagnose.
What am I missing?
What Shelly app are you referring too?
I see your message type is: shellies-ng\ ? the "\" is not in Aaron's instructions. Is that a mis-type possibly?
pgershon wrote:Updating again. I have all my devices active and working. However, some show up in the log with their correct names, whiles other show up as new device. I cannot determine the rhyme or reason to the pattern,
Six devices below, 3 come up as new device, 3 are names properly
- Code: Select all
{"src":"shellyplus1-a8032aba4f74","dst":" shellies-ng/ShellyPlus1-A8032ABA4F74/events","method":"NotifyStatus","params":{"ts":1656774055.79,"switch:0":{"id":0,"output":true,"source":"HTTP"}}}
pgershon wrote:I now have all the Shelly Plus One devices working. I realized I have one Shelly One (old style) too. I cannot get the device to work with the old plugin.
It seems that ignorer to get the old Shelly One to broadcast MQTT, I must turn off cloud connection. This disables my ability too use the Shelly app on my iPhone. I did not have this issue with the Shelly Plus One devices. Is this by design or am I missing something? My steps are below... (and thanks to everyone making suggestions)
I have the ShellyMQTT and ShellyNGNQTT enabled. Same MQTT Broker for both:
Two different triggers - one for each type (with or without NG):
Set device webpage to enable MQTT
pgershon wrote:Thanks. After playing with both of your plugins, I think I will make it my go to method (Karl's plugin does not do the Shelly One Plus well at this point at least).
But I ended up deactivating cloud access to my old Shelly One unit ignorer to get MQTT running. Is there a way around this? By deactivating the cloud, the my iPhone's Shelly app, your plug in, and Karl's plugin go out of sync. I turn the device on/off from your Indigo app/MQTT and the device is turned on/off properly, and Karl's device's status is sync'ed, but the iPhone app is not (it stays status on or off while teh lights go back and forth). Conversely, I can use the iPhone app to turn the lights on or off and the status of Karl's plugin reflect this, but there is no MQTT message being sent so the status of the MQTT device remains unchanged in Indigo.
Hopefully that made sense.
