DTV Code Failure
Thu May 26, 2022 7:13 pm
ckeyes888 offline
DTV Code Failure
Anyone else seeing this code for direct channel access failing?
 dvrPlugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.directvdvrcontrol")
if dvrPlugin.isEnabled():
   dvrPlugin.executeAction("setChannel", props={'address':"192.168.1.53", 'channelNumber':'356'})
All other functions seem to be working.
Carl
Fri May 27, 2022 7:15 am
Re: DTV Code Failure
Are you getting an error message in the Indigo log, or is the script "just not working"?
Fri May 27, 2022 9:33 am
ckeyes888 offline
No errors. Just not working.
Edit: I did try rebooting the DTV.
Carl
Fri May 27, 2022 10:00 am
Your script looks right. Are you certain that the IP address of the target DVR is "192.168.1.53"?
Fri May 27, 2022 3:10 pm
ckeyes888 offline
Yes, all other commands work fine.
Carl
Fri May 27, 2022 3:18 pm
Okay, this is a long shot, but I notice that your code in the first message has a space at the front of the first line. If that space is in your actual script, delete it.
For kicks, put one more space in the front of the third line (so it's four spaces)
Fri May 27, 2022 6:53 pm
ckeyes888 offline
Thanks but no joy.
No actual space before first line and any spaces I add anywhere else triggers an error.
Any command using this code does work:
   dvrPlugin.executeAction("sendKeyPress", props={'address':"192.168.1.53", 'keyToPress':"9"})
Carl
Fri May 27, 2022 11:30 pm
Does the action itself work via the plugin UI?
ie taking the script out of the equation?
Sat May 28, 2022 8:30 am
ckeyes888 offline
No, the “go to channel” isn’t working using the UI or the code.
The “send key press” works in the UI and using code.
Weird. I haven’t changed anything with the plugin in years.
Maybe DTV ran an update that broke it?
Carl
Sat May 28, 2022 1:17 pm
I've just added one line, to output the reply from the DirectTV to the Indigo log.
Won't be pretty, but might tell you the problem.
https://www.dropbox.com/s/5bh9eui5isltq ... n.zip?dl=1
Sat May 28, 2022 1:32 pm
Given that nothing has changed in the plugin and other commands continue to work, my guess is that a DTV update has broken that functionality. Maybe @howartp's version can help confirm that.
Sat May 28, 2022 4:12 pm
ckeyes888 offline
Here’s the error using your revised plugin:
May 28, 2022 at 4:10:42 PM
Action Group Fav Ch 23 KTMF
DIRECTV DVR Control Error {u'status': {u'msg': u'Invalid clientAddr', u'query': u'/tv/tune?major=23&minor=65535&clientAddr=0', u'code': 200, u'commandResult': 1}}
Carl
Sat May 28, 2022 5:45 pm
clientAddr can either be 0 (for 'the server') or a MAC Address string (no colons or dashes) for 'a client', but the specs don't say who is which.
Try adding clientAddr to your script props with your Mac's MAC address as a string?
Using your sendKeyPress code above, it would be equivalent to this:
dvrPlugin.executeAction("sendKeyPress", props={'address':"192.168.1.53", 'keyToPress':"9", 'clientAddr':"AABBCCDDEEFF"})
Sat May 28, 2022 6:30 pm
ckeyes888 offline
Guess I’m confused. The “send key press” code, and in the UI, is the one that is working.
How should I incorporate your code?
Carl
Sat May 28, 2022 6:49 pm
Sorry, where you got your actual code for changing channel (which you’ve not provided yet), add the clientAddr on like I have in sendKeyPress.
Or paste me your channel code and I’ll add it for you.
