HFTobeason wrote:Does this plugin still exist? The Dropbox pages are showing "Does not exist" errors. Thanks.
Yes, it does. I'll take a look at it tonight, and see if I can find out what's happening. Otherwise, I might just put it up on Github....
File not found
Sorry, that file doesn’t live here anymore. It might have been moved or made private.
HFTobeason wrote:
https://dl.dropboxusercontent.com/u/241415/indigo%20survey/Survey%20v2.21.zip
results in a 404 error:File not found
HFTobeason wrote:Thank you. Successfully downloaded and ran. Very helpful!
Survey Plugin Total Successes - 135
Survey Plugin Total Failures - 3
Survey Plugin Done processing devices
Survey Plugin Error Error in plugin execution MenuAction:
File "plugin.py", line 329, in survey_1pass_manualUpdate
File "plugin.py", line 311, in make_individual_reports
File "plugin.py", line 184, in make_report
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/survey2.indigoPlugin/Contents/Server Plugin/Cheetah/Template.py", line 1005, in __str__
File "cheetah_DynamicallyCompiledCheetahTemplate_1505575978_86_25526.py", line 136, in respond
TypeError: hex() argument can't be converted to hex
dduff617 wrote:i have successfully run survey plugin in the past, but my last several attempts are failing. i'm still getting this error:
dduff617 wrote:i have a few modules with a space character that makes them fall at the end of sorted list. i think it may be non-breaking space (option-space). i use this when i have a device that is under direct control of a motion sensor or a door sensor, such that i typically don't want to control it manually, thus i want it to fall to the bottom of lists.
i suppose i could rename them....
example: " motion - Pantry Light"
bschollnick2 wrote:dduff617 wrote:i have a few modules with a space character that makes them fall at the end of sorted list. i think it may be non-breaking space (option-space). i use this when i have a device that is under direct control of a motion sensor or a door sensor, such that i typically don't want to control it manually, thus i want it to fall to the bottom of lists.
That was a red herring. I found the issue, it's with the cheetah templating.
I assume you have at least some Z-Wave items? The cheetah template is crashing when it hits the zWave item's firmware number, and can't convert it to hex.
I have a temporary fix which prevents any of the firmware versions from being hex encoded (that was indigo & survey are showing the same version #'s for the firmwares).
I need to sit down and change the logic for that for a more permanent fix. I'll try to publish the change tomorrow morning...
- Benjamin
claudetalbot wrote:bschollnick2 wrote:dduff617 wrote:i have a few modules with a space character that makes them fall at the end of sorted list. i think it may be non-breaking space (option-space). i use this when i have a device that is under direct control of a motion sensor or a door sensor, such that i typically don't want to control it manually, thus i want it to fall to the bottom of lists.
- Benjamin
Hi Benjamin,
A few days ago, I installed last available version of Survey on Indigo plugin store. Unfortunately I do experience the exact same issue as dduff617 with same errors reported in my log. I'm using Indigo 7.1.1 on iMac running 10.12.6.
Claude
kennybroh wrote:Any chance of a new version?
