Indigo Touch on 15.2
Tue Dec 14, 2021 9:50 am
Liptrot offline
Is anyone else having issues connecting via Indigo Touch on iOS 15.2 ?
Both of my homes give me failed to connect errors.
If I screen share into the Mac mini’s…both servers are operating fine and I am able to connect to the other home for either mac.
Tue Dec 14, 2021 9:54 am
autolog offline
Re: Indigo Touch on 15.2
See this post - it maybe relevant: macOS Monterey 12.1 Compatibility :?:
Tue Dec 14, 2021 12:40 pm
Liptrot offline
If only I had seen that a few hours earlier.
Oh well...Homebridge access still works as does screen sharing into the server...
Hopefully they have a fix soon. I agree with Jay...I did not anticipate this on a dot release
Tue Dec 14, 2021 2:52 pm
davinci offline
Homebridge still works?
Mine was gone… the devices disappeared.
[14.12.2021, 22:00:32] [Indigo Server] Error for Indigo request /devices.json/: Error: connect ECONNREFUSED 127.0.0.1:8176
    "platforms": [
            "platform": "Indigo",
            "name": "Indigo Server",
            "protocol": "http",
            "host": "127.0.0.1",
            "port": "8176",
Tue Dec 14, 2021 4:31 pm
Tue Dec 14, 2021 4:59 pm
Hap offline
   Stopping plugin Web Server (pid 6476)
   Web Server                      Stopping Indigo Web Server...
   Stopped plugin Web Server
   Upgrading plugin Web Server to newer version 2021.1.3 (previous version moved to trash)
   Loading plugin "Web Server 2021.1.3"
   Starting plugin "Web Server 2021.1.3" (pid 18537)
   Web Server Error                Error in plugin execution InitializeMain:
ImportError: dlopen(/Library/Application Support/Perceptive Automation/Indigo 2021.1/Plugins/Web Server.indigoPlugin/Contents/Server Plugin/plugin.so, 0x0002): tried: '/Library/Application Support/Perceptive Automation/Indigo 2021.1/Plugins/Web Server.indigoPlugin/Contents/Server Plugin/plugin.so' (code signature in <FCEBE93C-397E-3E6C-BB6E-D8D43C59570B> '/Library/Application Support/Perceptive Automation/Indigo 2021.1/Plugins/Web Server.indigoPlugin/Contents/Server Plugin/plugin.so' not valid for use in process: library load disallowed by system policy), '/usr/lib/plugin.so' (no such file)
Get a popup from the OS that the developer can't be identified
EDIT: Saw the post in the corresponding Monterey 12.1 thread. That approach worked.
Thank you Matt/Jay - my SO will be very happy.
Thu Dec 16, 2021 2:52 pm
We have fixed this issue in the now available Indigo 2021.2 release. If you are not able to install Indigo 2021.2 then see this post.
