Can't rename or update variables list (OS 11.0.1 Big Sur)
Sun Dec 06, 2020 3:16 pm
Butch2427 offline
Re: Can't rename or update variables list (OS 11.0.1 Big Sur
Sadly, after a complete removal of Indigo and a clean installation... the problem still exists. I've been unable find the source of this problem. Hopefully a future update of Big Sur will magically fix this. Thanks for all of your suggestions.
Sat Jan 09, 2021 4:17 pm
Butch2427 offline
Upgrading to 7.5 did not fix the issue.
Mon Feb 15, 2021 1:04 pm
vml offline
I've just started hitting this bug. I was able to rename variables a couple weeks ago, but I no longer can. The behavior is exactly as the OP describes.
I have a Mac mini running Big Sur 11.1. The machine serves solely as an Indigo server and as a wireless Time Machine backup; it rarely undergoes any sort of changes (certainly nothing I can think of over the past couple weeks). I hit the issue whether I'm accessing via remote desktop, or from another Mac connecting as a remote client.
Short of a fix, is there any sort of workaround that might allow for renaming via another means? Maybe some sort of action, script, or plugin?
Any thoughts are much-appreciated!
Mon Feb 15, 2021 4:10 pm
Sorry we haven't fixed this one yet but we still aren't having any luck reproducing the problem here (on multiple Macs running Big Sur). Was it originally working for you on Big Sur then it stopped working?
You can change it via an Indigo Server script by either creating an Action Group with the Execute Script action type, or by choosing the Plugins->Open Scripting Shell... menu item:
var = indigo.variables['oldVarNameHere']
var.name = "newVarNameHere"
var.replaceOnServer()
Mon Feb 15, 2021 5:27 pm
vml offline
Hey Matt, yep – it originally worked on Big Sur, and recently stopped working. Any chance you've filed a radar with Apple?
Huge thanks for the workaround!
Mon Feb 15, 2021 5:58 pm
Without concrete steps or a reproducible test project I don't think it will get much attention, but I probably should to see if they say it is a duplicate.
Fri Feb 19, 2021 11:33 am
What is the exact version of Bug Sure you're using?
Wed Feb 24, 2021 9:46 am
Butch2427 offline
FYI....mine is still failing under Big Sur version 11.0.1
Wed Feb 24, 2021 11:51 am
I'm running 11.2.1 and don't see this issue. Any reason why you're not upgrading? It's usually a good idea to get past the initial macOS releases because they tend to be somewhat buggy. May not fix the issue, but as a general rule...
Thu Feb 25, 2021 7:37 pm
Butch2427 offline
Upgrading is painful as I'm stuck with HughesNet satellite internet. See screenshot. I'm in line for StarLink and can't wait!
Screen Shot 2021-02-25 at 5.32.22 PM.png (84.98 KiB) Viewed 4662 times
Fri Feb 26, 2021 10:45 am
Ouch...
Sat Feb 27, 2021 11:47 am
Butch2427 offline
"upgraded" to Big Sur 11.2.2 and still no change, can't rename or update variables
Sat Feb 27, 2021 12:00 pm
autolog offline
Just a thought on this which probably isn't the case, but if there was another(modal?) Indigo window open e.g. Edit device Settings for a device, then trying to rename the variable would get the behaviour you describe.
So I am wondering if somehow another window has got opened or Indigo thinks a window is open?
If you click on Window in the main Indigo menu, is it showing any other windows there?
Sat Feb 27, 2021 1:14 pm
Disable all 3rd party plugins and see if that makes any difference.
Mon Mar 01, 2021 11:15 am
Butch2427 offline
No luck disabling 3rd party plug-ins. I disabled them one by one then checked for variable rename. No change, problem still exists.
