DICT timeout
Wed Feb 03, 2021 9:41 pm
Re: DICT timeout
Please post the plugin.log file. And switch on http Debug (6 and 6.1).
Thu Feb 04, 2021 8:47 am
stewkenly offline
Re: DICT timeout
Hi Karl,
Here's the snippet from plugin.log. I confirmed there are no other messages. I also attached a screenshot of the web interface. It connects with https but says Not Secure. I assume this is ok?
04 08:46:27 getunifiOSAndPort existing  os>< .. ip#>192.168.0.5< .. trying ports>['443', '8443']<
04 08:46:27 getunifiOSAndPort trying port#:>requests --insecure  -I -s -o /dev/null -w "%{http_code}" 'https://192.168.0.5:443'< gives ret code:
04 08:46:27 getunifiOSAndPort trying port:443, wrong ret code from curl test>< expecting {'200': {'os': 'unifi_os', 'unifiApiWebPage': '/proxy/network/api/s', 'unifiApiLoginPath': '/api/auth/login'}, '302': {'os': 'std', 'unifiApiWebPage': '/api/s', 'unifiApiLoginPath': '/api/login'}}
04 08:46:27 getunifiOSAndPort trying port#:>requests --insecure  -I -s -o /dev/null -w "%{http_code}" 'https://192.168.0.5:8443'< gives ret code:
04 08:46:27 getunifiOSAndPort trying port:8443, wrong ret code from curl test>< expecting {'200': {'os': 'unifi_os', 'unifiApiWebPage': '/proxy/network/api/s', 'unifiApiLoginPath': '/api/auth/login'}, '302': {'os': 'std', 'unifiApiWebPage': '/api/s', 'unifiApiLoginPath': '/api/login'}}
04 08:46:28 getunifiOSAndPort existing  os>< .. ip#>192.168.0.5< .. trying ports>['443', '8443']<
04 08:46:28 getunifiOSAndPort trying port#:>requests --insecure  -I -s -o /dev/null -w "%{http_code}" 'https://192.168.0.5:443'< gives ret code:
04 08:46:28 getunifiOSAndPort trying port:443, wrong ret code from curl test>< expecting {'200': {'os': 'unifi_os', 'unifiApiWebPage': '/proxy/network/api/s', 'unifiApiLoginPath': '/api/auth/login'}, '302': {'os': 'std', 'unifiApiWebPage': '/api/s', 'unifiApiLoginPath': '/api/login'}}
04 08:46:28 getunifiOSAndPort trying port#:>requests --insecure  -I -s -o /dev/null -w "%{http_code}" 'https://192.168.0.5:8443'< gives ret code:
04 08:46:28 getunifiOSAndPort trying port:8443, wrong ret code from curl test>< expecting {'200': {'os': 'unifi_os', 'unifiApiWebPage': '/proxy/network/api/s', 'unifiApiLoginPath': '/api/auth/login'}, '302': {'os': 'std', 'unifiApiWebPage': '/api/s', 'unifiApiLoginPath': '/api/login'}}
08:46:29 getunifiOSAndPort bad return from unifi controller 192.168.0.5, no os and / port found, tried ports:['443', '8443']
Screen Shot 2021-02-04 at 8.48.56 AM.png (45.96 KiB) Viewed 2408 times
Thu Feb 04, 2021 8:53 am
Re: DICT timeout
got it: you have set curl / requests to request
but here it is still using curl. I know how to fix .. later today,
in the meantime set curl/requests to curl.. it will auto switch to request if if finds a controller w v 6.x
and you can use local host for the ip number again, that is now a "valid" ip before it had to have 4 numbers and 3 dots
Thu Feb 04, 2021 9:17 am
stewkenly offline
Re: DICT timeout
Hi Karl,
Ok it seems to connect to the controller now, but I don't see devices registering UP in Indigo. Here is the configuration currently running. Note I just have the controller configured. the AP section is off and blank.
I see in plugin.log the mac address of my phone. Indigo reports it expired 02-03 13:07:34
{"_id":"5f9432bdc371e16619f80f98","mac":"d6:50:1e:ab:d2:a5","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1603547837,"last_seen":1612312775,"is_wired":false,"hostname":"Perez-Hilton"},
Here's plugin.log
04 09:14:49 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie   'https://localhost:8443/api/s/default/stat/alluser'
04 09:14:49 Connection to localhost: returns >>{"meta":{"rc":"ok"},"data":[{"_id":"5eb96e22d7d0d302cd3b3650","mac":"58:bd:a3:f0:cd:f2","site_id":"5e2006d8cd7db309845a839c","oui":"Nintendo","is_guest":false,"first_seen":1589210658,"last_seen":1612451188,"is_wired":false,"hostname":"Nintendo 3DS","duration":20800,"tx_bytes":25616778,"tx_packets":28979,"rx_bytes":4532750,"rx_packets":21733,"wifi_tx_attempts":3544,"tx_retries":0},{"_id":"5e2de03cd7d0d302840da47b","mac":"00:1f:5b:c6:dc:1d","site_id":"5e2006d8cd7db309845a839c","oui":"Apple","is_guest":false,"first_seen":1580064828,"last_seen":1612403848,"is_wired":false,"hostname":"Teagans-iMac","duration":8692033,"tx_bytes":32748825429,"tx_packets":50210093,"rx_bytes":8431170655,"rx_packets":18670966,"wifi_tx_attempts":12175035,"tx_retries":0},{"_id":"5ff62bb1d5c80595a241a23c","mac":"16:5b:86:5b:e1:4a","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1609968561,"last_seen":1612393511,"is_wired":false,"hostname":"Judiths-iPhone"},{"_id":"5fcc0628d5c80568b02facd1","mac":"2a:e8:05:18:ae:c6","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1607206440,"last_seen":1612371321,"is_wired":false,"hostname":"iPhone"},{"_id":"5fc5c74dd5c80568b02f1979","mac":"86:1e:eb:8f:ac:22","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1606797133,"last_seen":1612371321,"is_wired":false,"hostname":"MajbritpleWatch"},{"_id":"5fa55c14c371e16619f9b839","mac":"c2:48:6b:cf:6a:96","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1604672532,"last_seen":1612371321,"is_wired":false,"hostname":"Majbritts-iPad"},{"_id":"5f9432bdc371e16619f80f98","mac":"d6:50:1e:ab:d2:a5","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1603547837,"last_seen":1612312775,"is_wired":false,"hostname":"Perez-Hilton"},{"_id":"5f0dfd36c2e3a9376c5baee8","mac":"1c:f2:9a:41:af:f9","site_id":"5e2006d8cd7db309845a839c","oui":"Google","is_guest":false,"first_seen":1594752310,"last_seen":1612304014,"is_wired":false,"hostname":"Google-Nest-Hub"},{"_id":"5e200badcd7db309845a841e","mac":"8c:85:90:d2:b7:cf","site_id":"5e2006d8cd7db309845a839c","oui":"Apple","is_guest":false,"first_seen":1579158445,"last_seen":1612279745,"is_wired":false,"hostname":"ausmac753218","duration":22080188,"tx_bytes":476258221780,"tx_packets":511610600,"rx_bytes":111273762088,"rx_packets":455233329,"wifi_tx_attempts":75974174,"tx_retries":0},{"_id":"60185c89d5c80528f6019378","mac":"16:47:1e:d8:78:f3","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1612209289,"last_seen":1612216691,"is_wired":false,"hostname":"Judiths-iPad"},{"_id":"5f6e4a05d5c805127e98fa2b","mac":"fe:bb:d8:7d:0c:6d","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1601063429,"last_seen":1612216691,"is_wired":false,"hostname":"iPad"},{"_id":"5fd22e38c371e17c821b6a16","mac":"5e:ce:3a:ad:a5:8d","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1607609912,"last_seen":1612216387,"is_wired":false,"hostname":"AIGG8CWHU7MF3M"},{"_id":"5e200a8ccd7db309845a8414","mac":"98:b6:e9:99:d8:67","site_id":"5e2006d8cd7db309845a839c","oui":"Nintendo","is_guest":false,"first_seen":1579158156,"last_seen":1612216363,"is_wired":false,"duration":28227580,"tx_bytes":31177930472,"tx_packets":23349908,"rx_bytes":1836234194,"rx_packets":13466287,"wifi_tx_attempts":5733397,"tx_retries":0},{"_id":"6013645fd5c80528f601188c","mac":"7e:bc:5f:41:26:bb","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1611883615,"last_seen":1612133091,"is_wired":false,"hostname":"sofias-iphone"},{"_id":"601345d5d5c80528f601152f","mac":"ec:5c:68:25:aa:81","site_id":"5e2006d8cd7db309845a839c","oui":"Chongqin","is_guest":false,"first_seen":1611875797,"last_seen":1612132513,"is_wired":false,"hostname":"DESKTOP-CHN2H3A"},{"_id":"5fe692fb03638b043743332c","mac":"b0:02:47:b0:ce:89","site_id":"5e2006d8cd7db309845a839c","oui":"AmpakTec","is_guest":false,"first_seen":1608946427,"last_seen":1612123146,"is_wired":false},{"_id":"5ff21f21d5c80595a24148d9","mac":"96:9f:eb:92:15:c9","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1609703201,"last_seen":1612050004,"is_wired":false,"hostname":"Amys-iPhone"},{"_id":"5e90789ed7d0d303868e14eb","mac":"78:d1:62:ba:81:b8","site_id":"5e2006d8cd7db309845a839c","oui":"Apple","is_guest":false,"first_seen":1586526366,"last_seen":1611914805,"is_wired":false,"hostname":"ipadDMPCG575PV03","duration":19922552,"tx_bytes":127385485273,"tx_packets":117085824,"rx_bytes":27232101367,"rx_packets":74451975,"wifi_tx_attempts":35252390,"tx_retries":0},{"_id":"5e200a6acd7db309845a8401","mac":"64:16:66:ca:2b:89","site_id":"5e2006d8cd7db309845a839c","oui":"NestLabs","is_guest":false,"first_seen":1579158122,"last_seen":1611750852,"is_wired":false,"duration":30379595,"tx_bytes":208722445,"tx_packets":2152159,"rx_bytes":520074268,"rx_packets":2242338,"wifi_tx_attempts":992937,"tx_retries":0},{"_id":"5e200a7fcd7db309845a8411","mac":"64:16:66:ca:43:12","site_id":"5e2006d8cd7db309845a839c","oui":"NestLabs","is_guest":false,"first_seen":1579158143,"last_seen":1611667996,"is_wired":false,"duration":29078435,"tx_bytes":178520477,"tx_packets":1887225,"rx_bytes":436845977,"rx_packets":1964802,"wifi_tx_attempts":729513,"tx_retries":0},{"_id":"5e200a6acd7db309845a83ff","mac":"64:16:66:ca:39:1b","site_id":"5e2006d8cd7db309845a839c","oui":"NestLabs","is_guest":false,"first_seen":1579158122,"last_seen":1611664526,"is_wired":false,"duration":28578260,"tx_bytes":190387473,"tx_packets":1962966,"rx_bytes":472816005,"rx_packets":2045487,"wifi_tx_attempts":733202,"tx_retries":0},{"_id":"5e200a6acd7db309845a8405","mac":"64:16:66:ca:4b:19","site_id":"5e2006d8cd7db309845a839c","oui":"NestLabs","is_guest":false,"first_seen":1579158122,"last_seen":1611662745,"is_wired":false,"duration":29632207,"tx_bytes":189320483,"tx_packets":1980060,"rx_bytes":458521186,"rx_packets":2061894,"wifi_tx_attempts":811767,"tx_retries":0},{"_id":"5e2b8ca3d7d0d302840d95df","mac":"44:61:32:e1:4f:91","site_id":"5e2006d8cd7db309845a839c","oui":"Ecobee","is_guest":false,"first_seen":1579912354,"last_seen":1611602460,"is_wired":false,"hostname":"Living-Room","duration":16599198,"tx_bytes":225873038,"tx_packets":857150,"rx_bytes":406890360,"rx_packets":6983451,"wifi_tx_attempts":291102,"tx_retries":0},{"_id":"5f6dc8bbd5c805127e98ec6c","mac":"a2:48:28:4b:47:5e","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1601030331,"last_seen":1611238684,"is_wired":false,"hostname":"Stewarts-iPad"},{"_id":"5e200a6acd7db309845a83fd","mac":"64:16:66:ca:4d:a2","site_id":"5e2006d8cd7db309845a839c","oui":"NestLabs","is_guest":false,"first_seen":1579158122,"last_seen":1611060137,"is_wired":false,"duration":28271621,"tx_bytes":171026713,"tx_packets":1849362,"rx_bytes":448295084,"rx_packets":1928630,"wifi_tx_attempts":766127,"tx_retries":0},{"_id":"5e200a6acd7db309845a83f3","mac":"64:16:66:70:de:58","site_id":"5e2006d8cd7db309845a839c","oui":"NestLabs","is_guest":false,"first_seen":1579158122,"last_seen":1610800791,"is_wired":false,"hostname":"Nest-Hello-de58","name":"Nest doorbell camera","noted":true,"duration":18058875,"tx_bytes":19381203936,"tx_packets":280053546,"rx_bytes":493935180248,"rx_packets":457968651,"wifi_tx_attempts":93678773,"tx_retries":0},{"_id":"5fa31aa6c371e16619f97c5b","mac":"fe:dc:d5:7a:20:82","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1604524710,"last_seen":1610576153,"is_wired":false,"hostname":"Judiths-iPhone"},{"_id":"5e200a6acd7db309845a83fb","mac":"cc:9e:a2:25:26:45","site_id":"5e2006d8cd7db309845a839c","oui":"AmazonTe","is_guest":false,"first_seen":1579158122,"last_seen":1610018385,"is_wired":false,"hostname":"amazon-ceeb6ecda","duration":22353221,"tx_bytes":26256865758,"tx_packets":298545863,"rx_bytes":29608087963,"rx_packets":502197182,"wifi_tx_attempts":254480081,"tx_retries":0},{"_id":"5ff62a2cd5c80595a241a214","mac":"98:60:ca:53:c5:4f","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1609968172,"last_seen":1609968545,"is_wired":false,"hostname":"iPhone"},{"_id":"5ff13705d5c80595a24132e3","mac":"64:52:99:ff:39:5f","site_id":"5e2006d8cd7db309845a839c","oui":"Chamberl","is_guest":false,"first_seen":1609643781,"last_seen":1609643781,"is_wired":false,"hostname":"MyQ-CE9"},{"_id":"5f750dde03638b118cdfbd03","mac":"52:29:e4:3a:be:ae","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1601506782,"last_seen":1608930778,"is_wired":false,"hostname":"Amys-iPhone"},{"_id":"5fe17d8203638b043742ae7b","mac":"e8:61:7e:94:24:9d","site_id":"5e2006d8cd7db309845a839c","oui":"LiteonTe","is_guest":false,"first_seen":1608613250,"last_seen":1608614317,"is_wired":false},{"_id":"5e200a6acd7db309845a83f5","mac":"18:b4:30:91:3b:36","site_id":"5e2006d8cd7db309845a839c","oui":"NestLabs","is_guest":false,"first_seen":1579158122,"last_seen":1607394639,"is_wired":false,"hostname":"Nest-3B36","name":"Nest front yard camera","noted":true,"duration":10793596,"tx_bytes":16162204635,"tx_packets":249950375,"rx_bytes":501435533506,"rx_packets":468732027,"wifi_tx_attempts":130530644,"tx_retries":0},{"_id":"5fa583b3c2e3a904b51f1bfa","mac":"7a:9c:1a:f0:bb:ab","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1604682675,"last_seen":1607375718,"is_wired":false,"hostname":"AIGG8CWHU7MF3M"},{"_id":"5fbf0dbdd5c80568b02e8451","mac":"48:a5:e7:24:f7:a6","site_id":"5e2006d8cd7db309845a839c","oui":"Nintendo","is_guest":false,"first_seen":1606356413,"last_seen":1607215507,"is_wired":false},{"_id":"5fca5d18d5c80568b02f84ba","mac":"64:16:66:da:97:e7","site_id":"5e2006d8cd7db309845a839c","oui":"NestLabs","is_guest":false,"first_seen":1607097624,"last_seen":1607097624,"is_wired":false,"name":"Nest gate camera","noted":true},{"_id":"5f8b3e2403638b118ce1e937","mac":"44:c6:5d:31:23:76","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1602960932,"last_seen":1607007608,"is_wired":false,"hostname":"Judiths-iPad"},{"_id":"5faafb6cc2e3a904b51f9c28","mac":"26:17:01:99:37:a4","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1605041004,"last_seen":1606835512,"is_wired":false,"hostname":"iPhone"},{"_id":"5e200a6acd7db309845a83f7","mac":"08:12:a5:81:88:e9","site_id":"5e2006d8cd7db309845a839c","oui":"AmazonTe","is_guest":false,"first_seen":1579158122,"last_seen":1606235258,"is_wired":false,"duration":15472250,"tx_bytes":17958777841,"tx_packets":260614603,"rx_bytes":16799808822,"rx_packets":258753206,"wifi_tx_attempts":122676798,"tx_retries":0},{"_id":"5f4fccaf0f6b71033bf73e02","mac":"9c:84:bf:58:ea:37","site_id":"5e2006d8cd7db309845a839c","oui":"Apple","is_guest":false,"first_seen":1599065263,"last_seen":1605956211,"is_wired":false,"hostname":"Stewarts-iPad"},{"_id":"5facafc2c2e3a904b51fc57d","mac":"0a:f9:2b:9c:2b:87","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1605152706,"last_seen":1605405675,"is_wired":false,"hostname":"Teagans-iPhone"},{"_id":"5e84e9cad7d0d303868dd9f6","mac":"88:66:a5:65:f4:13","site_id":"5e2006d8cd7db309845a839c","oui":"Apple","is_guest":false,"first_seen":1585768906,"last_seen":1605152594,"is_wired":false,"hostname":"Teagans-iPhone","duration":3771909,"tx_bytes":14149433378,"tx_packets":11912997,"rx_bytes":2398130522,"rx_packets":7474587,"wifi_tx_attempts":4543040,"tx_retries":0},{"_id":"5f85ff2a03638b118ce1629f","mac":"d4:a3:3d:ca:54:e8","site_id":"5e2006d8cd7db309845a839c","oui":"Apple","is_guest":false,"first_seen":1602617130,"last_seen":1605034428,"is_wired":false,"hostname":"iPhone"},{"_id":"5f3f27b9d5c805683af049f3","mac":"48:26:2c:10:33:2b","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1597974457,"last_seen":1604682661,"is_wired":false,"hostname":"AIGG8CWHU7MF3M"}]}<<
04 09:15:54 executeCMDOnController: /usr/bin/curl --insecure -c /tmp/unifiCookie -H "Content-Type: application/json" --data '{"username": "stewadmin", "strict": false, "password": ";1Peaches1;"}' 'https://localhost:8443/api/login'
04 09:15:54 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie   'https://localhost:8443/api/s/default/stat/alluser'
04 09:15:54 Connection to localhost: returns >>{"meta":{"rc":"ok"},"data":[{"_id":"5eb96e22d7d0d302cd3b3650","mac":"58:bd:a3:f0:cd:f2","site_id":"5e2006d8cd7db309845a839c","oui":"Nintendo","is_guest":false,"first_seen":1589210658,"last_seen":1612451188,"is_wired":false,"hostname":"Nintendo 3DS","duration":20800,"tx_bytes":25616778,"tx_packets":28979,"rx_bytes":4532750,"rx_packets":21733,"wifi_tx_attempts":3544,"tx_retries":0},{"_id":"5e2de03cd7d0d302840da47b","mac":"00:1f:5b:c6:dc:1d","site_id":"5e2006d8cd7db309845a839c","oui":"Apple","is_guest":false,"first_seen":1580064828,"last_seen":1612403848,"is_wired":false,"hostname":"Teagans-iMac","duration":8692033,"tx_bytes":32748825429,"tx_packets":50210093,"rx_bytes":8431170655,"rx_packets":18670966,"wifi_tx_attempts":12175035,"tx_retries":0},{"_id":"5ff62bb1d5c80595a241a23c","mac":"16:5b:86:5b:e1:4a","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1609968561,"last_seen":1612393511,"is_wired":false,"hostname":"Judiths-iPhone"},{"_id":"5fcc0628d5c80568b02facd1","mac":"2a:e8:05:18:ae:c6","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1607206440,"last_seen":1612371321,"is_wired":false,"hostname":"iPhone"},{"_id":"5fc5c74dd5c80568b02f1979","mac":"86:1e:eb:8f:ac:22","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1606797133,"last_seen":1612371321,"is_wired":false,"hostname":"MajbritpleWatch"},{"_id":"5fa55c14c371e16619f9b839","mac":"c2:48:6b:cf:6a:96","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1604672532,"last_seen":1612371321,"is_wired":false,"hostname":"Majbritts-iPad"},{"_id":"5f9432bdc371e16619f80f98","mac":"d6:50:1e:ab:d2:a5","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1603547837,"last_seen":1612312775,"is_wired":false,"hostname":"Perez-Hilton"},{"_id":"5f0dfd36c2e3a9376c5baee8","mac":"1c:f2:9a:41:af:f9","site_id":"5e2006d8cd7db309845a839c","oui":"Google","is_guest":false,"first_seen":1594752310,"last_seen":1612304014,"is_wired":false,"hostname":"Google-Nest-Hub"},{"_id":"5e200badcd7db309845a841e","mac":"8c:85:90:d2:b7:cf","site_id":"5e2006d8cd7db309845a839c","oui":"Apple","is_guest":false,"first_seen":1579158445,"last_seen":1612279745,"is_wired":false,"hostname":"ausmac753218","duration":22080188,"tx_bytes":476258221780,"tx_packets":511610600,"rx_bytes":111273762088,"rx_packets":455233329,"wifi_tx_attempts":75974174,"tx_retries":0},{"_id":"60185c89d5c80528f6019378","mac":"16:47:1e:d8:78:f3","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1612209289,"last_seen":1612216691,"is_wired":false,"hostname":"Judiths-iPad"},{"_id":"5f6e4a05d5c805127e98fa2b","mac":"fe:bb:d8:7d:0c:6d","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1601063429,"last_seen":1612216691,"is_wired":false,"hostname":"iPad"},{"_id":"5fd22e38c371e17c821b6a16","mac":"5e:ce:3a:ad:a5:8d","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1607609912,"last_seen":1612216387,"is_wired":false,"hostname":"AIGG8CWHU7MF3M"},{"_id":"5e200a8ccd7db309845a8414","mac":"98:b6:e9:99:d8:67","site_id":"5e2006d8cd7db309845a839c","oui":"Nintendo","is_guest":false,"first_seen":1579158156,"last_seen":1612216363,"is_wired":false,"duration":28227580,"tx_bytes":31177930472,"tx_packets":23349908,"rx_bytes":1836234194,"rx_packets":13466287,"wifi_tx_attempts":5733397,"tx_retries":0},{"_id":"6013645fd5c80528f601188c","mac":"7e:bc:5f:41:26:bb","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1611883615,"last_seen":1612133091,"is_wired":false,"hostname":"sofias-iphone"},{"_id":"601345d5d5c80528f601152f","mac":"ec:5c:68:25:aa:81","site_id":"5e2006d8cd7db309845a839c","oui":"Chongqin","is_guest":false,"first_seen":1611875797,"last_seen":1612132513,"is_wired":false,"hostname":"DESKTOP-CHN2H3A"},{"_id":"5fe692fb03638b043743332c","mac":"b0:02:47:b0:ce:89","site_id":"5e2006d8cd7db309845a839c","oui":"AmpakTec","is_guest":false,"first_seen":1608946427,"last_seen":1612123146,"is_wired":false},{"_id":"5ff21f21d5c80595a24148d9","mac":"96:9f:eb:92:15:c9","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1609703201,"last_seen":1612050004,"is_wired":false,"hostname":"Amys-iPhone"},{"_id":"5e90789ed7d0d303868e14eb","mac":"78:d1:62:ba:81:b8","site_id":"5e2006d8cd7db309845a839c","oui":"Apple","is_guest":false,"first_seen":1586526366,"last_seen":1611914805,"is_wired":false,"hostname":"ipadDMPCG575PV03","duration":19922552,"tx_bytes":127385485273,"tx_packets":117085824,"rx_bytes":27232101367,"rx_packets":74451975,"wifi_tx_attempts":35252390,"tx_retries":0},{"_id":"5e200a6acd7db309845a8401","mac":"64:16:66:ca:2b:89","site_id":"5e2006d8cd7db309845a839c","oui":"NestLabs","is_guest":false,"first_seen":1579158122,"last_seen":1611750852,"is_wired":false,"duration":30379595,"tx_bytes":208722445,"tx_packets":2152159,"rx_bytes":520074268,"rx_packets":2242338,"wifi_tx_attempts":992937,"tx_retries":0},{"_id":"5e200a7fcd7db309845a8411","mac":"64:16:66:ca:43:12","site_id":"5e2006d8cd7db309845a839c","oui":"NestLabs","is_guest":false,"first_seen":1579158143,"last_seen":1611667996,"is_wired":false,"duration":29078435,"tx_bytes":178520477,"tx_packets":1887225,"rx_bytes":436845977,"rx_packets":1964802,"wifi_tx_attempts":729513,"tx_retries":0},{"_id":"5e200a6acd7db309845a83ff","mac":"64:16:66:ca:39:1b","site_id":"5e2006d8cd7db309845a839c","oui":"NestLabs","is_guest":false,"first_seen":1579158122,"last_seen":1611664526,"is_wired":false,"duration":28578260,"tx_bytes":190387473,"tx_packets":1962966,"rx_bytes":472816005,"rx_packets":2045487,"wifi_tx_attempts":733202,"tx_retries":0},{"_id":"5e200a6acd7db309845a8405","mac":"64:16:66:ca:4b:19","site_id":"5e2006d8cd7db309845a839c","oui":"NestLabs","is_guest":false,"first_seen":1579158122,"last_seen":1611662745,"is_wired":false,"duration":29632207,"tx_bytes":189320483,"tx_packets":1980060,"rx_bytes":458521186,"rx_packets":2061894,"wifi_tx_attempts":811767,"tx_retries":0},{"_id":"5e2b8ca3d7d0d302840d95df","mac":"44:61:32:e1:4f:91","site_id":"5e2006d8cd7db309845a839c","oui":"Ecobee","is_guest":false,"first_seen":1579912354,"last_seen":1611602460,"is_wired":false,"hostname":"Living-Room","duration":16599198,"tx_bytes":225873038,"tx_packets":857150,"rx_bytes":406890360,"rx_packets":6983451,"wifi_tx_attempts":291102,"tx_retries":0},{"_id":"5f6dc8bbd5c805127e98ec6c","mac":"a2:48:28:4b:47:5e","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1601030331,"last_seen":1611238684,"is_wired":false,"hostname":"Stewarts-iPad"},{"_id":"5e200a6acd7db309845a83fd","mac":"64:16:66:ca:4d:a2","site_id":"5e2006d8cd7db309845a839c","oui":"NestLabs","is_guest":false,"first_seen":1579158122,"last_seen":1611060137,"is_wired":false,"duration":28271621,"tx_bytes":171026713,"tx_packets":1849362,"rx_bytes":448295084,"rx_packets":1928630,"wifi_tx_attempts":766127,"tx_retries":0},{"_id":"5e200a6acd7db309845a83f3","mac":"64:16:66:70:de:58","site_id":"5e2006d8cd7db309845a839c","oui":"NestLabs","is_guest":false,"first_seen":1579158122,"last_seen":1610800791,"is_wired":false,"hostname":"Nest-Hello-de58","name":"Nest doorbell camera","noted":true,"duration":18058875,"tx_bytes":19381203936,"tx_packets":280053546,"rx_bytes":493935180248,"rx_packets":457968651,"wifi_tx_attempts":93678773,"tx_retries":0},{"_id":"5fa31aa6c371e16619f97c5b","mac":"fe:dc:d5:7a:20:82","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1604524710,"last_seen":1610576153,"is_wired":false,"hostname":"Judiths-iPhone"},{"_id":"5e200a6acd7db309845a83fb","mac":"cc:9e:a2:25:26:45","site_id":"5e2006d8cd7db309845a839c","oui":"AmazonTe","is_guest":false,"first_seen":1579158122,"last_seen":1610018385,"is_wired":false,"hostname":"amazon-ceeb6ecda","duration":22353221,"tx_bytes":26256865758,"tx_packets":298545863,"rx_bytes":29608087963,"rx_packets":502197182,"wifi_tx_attempts":254480081,"tx_retries":0},{"_id":"5ff62a2cd5c80595a241a214","mac":"98:60:ca:53:c5:4f","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1609968172,"last_seen":1609968545,"is_wired":false,"hostname":"iPhone"},{"_id":"5ff13705d5c80595a24132e3","mac":"64:52:99:ff:39:5f","site_id":"5e2006d8cd7db309845a839c","oui":"Chamberl","is_guest":false,"first_seen":1609643781,"last_seen":1609643781,"is_wired":false,"hostname":"MyQ-CE9"},{"_id":"5f750dde03638b118cdfbd03","mac":"52:29:e4:3a:be:ae","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1601506782,"last_seen":1608930778,"is_wired":false,"hostname":"Amys-iPhone"},{"_id":"5fe17d8203638b043742ae7b","mac":"e8:61:7e:94:24:9d","site_id":"5e2006d8cd7db309845a839c","oui":"LiteonTe","is_guest":false,"first_seen":1608613250,"last_seen":1608614317,"is_wired":false},{"_id":"5e200a6acd7db309845a83f5","mac":"18:b4:30:91:3b:36","site_id":"5e2006d8cd7db309845a839c","oui":"NestLabs","is_guest":false,"first_seen":1579158122,"last_seen":1607394639,"is_wired":false,"hostname":"Nest-3B36","name":"Nest front yard camera","noted":true,"duration":10793596,"tx_bytes":16162204635,"tx_packets":249950375,"rx_bytes":501435533506,"rx_packets":468732027,"wifi_tx_attempts":130530644,"tx_retries":0},{"_id":"5fa583b3c2e3a904b51f1bfa","mac":"7a:9c:1a:f0:bb:ab","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1604682675,"last_seen":1607375718,"is_wired":false,"hostname":"AIGG8CWHU7MF3M"},{"_id":"5fbf0dbdd5c80568b02e8451","mac":"48:a5:e7:24:f7:a6","site_id":"5e2006d8cd7db309845a839c","oui":"Nintendo","is_guest":false,"first_seen":1606356413,"last_seen":1607215507,"is_wired":false},{"_id":"5fca5d18d5c80568b02f84ba","mac":"64:16:66:da:97:e7","site_id":"5e2006d8cd7db309845a839c","oui":"NestLabs","is_guest":false,"first_seen":1607097624,"last_seen":1607097624,"is_wired":false,"name":"Nest gate camera","noted":true},{"_id":"5f8b3e2403638b118ce1e937","mac":"44:c6:5d:31:23:76","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1602960932,"last_seen":1607007608,"is_wired":false,"hostname":"Judiths-iPad"},{"_id":"5faafb6cc2e3a904b51f9c28","mac":"26:17:01:99:37:a4","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1605041004,"last_seen":1606835512,"is_wired":false,"hostname":"iPhone"},{"_id":"5e200a6acd7db309845a83f7","mac":"08:12:a5:81:88:e9","site_id":"5e2006d8cd7db309845a839c","oui":"AmazonTe","is_guest":false,"first_seen":1579158122,"last_seen":1606235258,"is_wired":false,"duration":15472250,"tx_bytes":17958777841,"tx_packets":260614603,"rx_bytes":16799808822,"rx_packets":258753206,"wifi_tx_attempts":122676798,"tx_retries":0},{"_id":"5f4fccaf0f6b71033bf73e02","mac":"9c:84:bf:58:ea:37","site_id":"5e2006d8cd7db309845a839c","oui":"Apple","is_guest":false,"first_seen":1599065263,"last_seen":1605956211,"is_wired":false,"hostname":"Stewarts-iPad"},{"_id":"5facafc2c2e3a904b51fc57d","mac":"0a:f9:2b:9c:2b:87","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1605152706,"last_seen":1605405675,"is_wired":false,"hostname":"Teagans-iPhone"},{"_id":"5e84e9cad7d0d303868dd9f6","mac":"88:66:a5:65:f4:13","site_id":"5e2006d8cd7db309845a839c","oui":"Apple","is_guest":false,"first_seen":1585768906,"last_seen":1605152594,"is_wired":false,"hostname":"Teagans-iPhone","duration":3771909,"tx_bytes":14149433378,"tx_packets":11912997,"rx_bytes":2398130522,"rx_packets":7474587,"wifi_tx_attempts":4543040,"tx_retries":0},{"_id":"5f85ff2a03638b118ce1629f","mac":"d4:a3:3d:ca:54:e8","site_id":"5e2006d8cd7db309845a839c","oui":"Apple","is_guest":false,"first_seen":1602617130,"last_seen":1605034428,"is_wired":false,"hostname":"iPhone"},{"_id":"5f3f27b9d5c805683af049f3","mac":"48:26:2c:10:33:2b","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1597974457,"last_seen":1604682661,"is_wired":false,"hostname":"AIGG8CWHU7MF3M"}]}<<
04 09:16:58 executeCMDOnController: /usr/bin/curl --insecure -c /tmp/unifiCookie -H "Content-Type: application/json" --data '{"username": "stewadmin", "strict": false, "password": ";1Peaches1;"}' 'https://localhost:8443/api/login'
04 09:16:59 Connection-localhost: {"meta":{"rc":"ok"},"data":[]}
04 09:16:59 Connection: /usr/bin/curl --insecure -b /tmp/unifiCookie   'https://localhost:8443/api/s/default/stat/alluser'
04 09:16:59 Connection to localhost: returns >>{"meta":{"rc":"ok"},"data":[{"_id":"5eb96e22d7d0d302cd3b3650","mac":"58:bd:a3:f0:cd:f2","site_id":"5e2006d8cd7db309845a839c","oui":"Nintendo","is_guest":false,"first_seen":1589210658,"last_seen":1612451188,"is_wired":false,"hostname":"Nintendo 3DS","duration":20800,"tx_bytes":25616778,"tx_packets":28979,"rx_bytes":4532750,"rx_packets":21733,"wifi_tx_attempts":3544,"tx_retries":0},{"_id":"5e2de03cd7d0d302840da47b","mac":"00:1f:5b:c6:dc:1d","site_id":"5e2006d8cd7db309845a839c","oui":"Apple","is_guest":false,"first_seen":1580064828,"last_seen":1612403848,"is_wired":false,"hostname":"Teagans-iMac","duration":8692033,"tx_bytes":32748825429,"tx_packets":50210093,"rx_bytes":8431170655,"rx_packets":18670966,"wifi_tx_attempts":12175035,"tx_retries":0},{"_id":"5ff62bb1d5c80595a241a23c","mac":"16:5b:86:5b:e1:4a","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1609968561,"last_seen":1612393511,"is_wired":false,"hostname":"Judiths-iPhone"},{"_id":"5fcc0628d5c80568b02facd1","mac":"2a:e8:05:18:ae:c6","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1607206440,"last_seen":1612371321,"is_wired":false,"hostname":"iPhone"},{"_id":"5fc5c74dd5c80568b02f1979","mac":"86:1e:eb:8f:ac:22","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1606797133,"last_seen":1612371321,"is_wired":false,"hostname":"MajbritpleWatch"},{"_id":"5fa55c14c371e16619f9b839","mac":"c2:48:6b:cf:6a:96","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1604672532,"last_seen":1612371321,"is_wired":false,"hostname":"Majbritts-iPad"},{"_id":"5f9432bdc371e16619f80f98","mac":"d6:50:1e:ab:d2:a5","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1603547837,"last_seen":1612312775,"is_wired":false,"hostname":"Perez-Hilton"},{"_id":"5f0dfd36c2e3a9376c5baee8","mac":"1c:f2:9a:41:af:f9","site_id":"5e2006d8cd7db309845a839c","oui":"Google","is_guest":false,"first_seen":1594752310,"last_seen":1612304014,"is_wired":false,"hostname":"Google-Nest-Hub"},{"_id":"5e200badcd7db309845a841e","mac":"8c:85:90:d2:b7:cf","site_id":"5e2006d8cd7db309845a839c","oui":"Apple","is_guest":false,"first_seen":1579158445,"last_seen":1612279745,"is_wired":false,"hostname":"ausmac753218","duration":22080188,"tx_bytes":476258221780,"tx_packets":511610600,"rx_bytes":111273762088,"rx_packets":455233329,"wifi_tx_attempts":75974174,"tx_retries":0},{"_id":"60185c89d5c80528f6019378","mac":"16:47:1e:d8:78:f3","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1612209289,"last_seen":1612216691,"is_wired":false,"hostname":"Judiths-iPad"},{"_id":"5f6e4a05d5c805127e98fa2b","mac":"fe:bb:d8:7d:0c:6d","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1601063429,"last_seen":1612216691,"is_wired":false,"hostname":"iPad"},{"_id":"5fd22e38c371e17c821b6a16","mac":"5e:ce:3a:ad:a5:8d","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1607609912,"last_seen":1612216387,"is_wired":false,"hostname":"AIGG8CWHU7MF3M"},{"_id":"5e200a8ccd7db309845a8414","mac":"98:b6:e9:99:d8:67","site_id":"5e2006d8cd7db309845a839c","oui":"Nintendo","is_guest":false,"first_seen":1579158156,"last_seen":1612216363,"is_wired":false,"duration":28227580,"tx_bytes":31177930472,"tx_packets":23349908,"rx_bytes":1836234194,"rx_packets":13466287,"wifi_tx_attempts":5733397,"tx_retries":0},{"_id":"6013645fd5c80528f601188c","mac":"7e:bc:5f:41:26:bb","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1611883615,"last_seen":1612133091,"is_wired":false,"hostname":"sofias-iphone"},{"_id":"601345d5d5c80528f601152f","mac":"ec:5c:68:25:aa:81","site_id":"5e2006d8cd7db309845a839c","oui":"Chongqin","is_guest":false,"first_seen":1611875797,"last_seen":1612132513,"is_wired":false,"hostname":"DESKTOP-CHN2H3A"},{"_id":"5fe692fb03638b043743332c","mac":"b0:02:47:b0:ce:89","site_id":"5e2006d8cd7db309845a839c","oui":"AmpakTec","is_guest":false,"first_seen":1608946427,"last_seen":1612123146,"is_wired":false},{"_id":"5ff21f21d5c80595a24148d9","mac":"96:9f:eb:92:15:c9","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1609703201,"last_seen":1612050004,"is_wired":false,"hostname":"Amys-iPhone"},{"_id":"5e90789ed7d0d303868e14eb","mac":"78:d1:62:ba:81:b8","site_id":"5e2006d8cd7db309845a839c","oui":"Apple","is_guest":false,"first_seen":1586526366,"last_seen":1611914805,"is_wired":false,"hostname":"ipadDMPCG575PV03","duration":19922552,"tx_bytes":127385485273,"tx_packets":117085824,"rx_bytes":27232101367,"rx_packets":74451975,"wifi_tx_attempts":35252390,"tx_retries":0},{"_id":"5e200a6acd7db309845a8401","mac":"64:16:66:ca:2b:89","site_id":"5e2006d8cd7db309845a839c","oui":"NestLabs","is_guest":false,"first_seen":1579158122,"last_seen":1611750852,"is_wired":false,"duration":30379595,"tx_bytes":208722445,"tx_packets":2152159,"rx_bytes":520074268,"rx_packets":2242338,"wifi_tx_attempts":992937,"tx_retries":0},{"_id":"5e200a7fcd7db309845a8411","mac":"64:16:66:ca:43:12","site_id":"5e2006d8cd7db309845a839c","oui":"NestLabs","is_guest":false,"first_seen":1579158143,"last_seen":1611667996,"is_wired":false,"duration":29078435,"tx_bytes":178520477,"tx_packets":1887225,"rx_bytes":436845977,"rx_packets":1964802,"wifi_tx_attempts":729513,"tx_retries":0},{"_id":"5e200a6acd7db309845a83ff","mac":"64:16:66:ca:39:1b","site_id":"5e2006d8cd7db309845a839c","oui":"NestLabs","is_guest":false,"first_seen":1579158122,"last_seen":1611664526,"is_wired":false,"duration":28578260,"tx_bytes":190387473,"tx_packets":1962966,"rx_bytes":472816005,"rx_packets":2045487,"wifi_tx_attempts":733202,"tx_retries":0},{"_id":"5e200a6acd7db309845a8405","mac":"64:16:66:ca:4b:19","site_id":"5e2006d8cd7db309845a839c","oui":"NestLabs","is_guest":false,"first_seen":1579158122,"last_seen":1611662745,"is_wired":false,"duration":29632207,"tx_bytes":189320483,"tx_packets":1980060,"rx_bytes":458521186,"rx_packets":2061894,"wifi_tx_attempts":811767,"tx_retries":0},{"_id":"5e2b8ca3d7d0d302840d95df","mac":"44:61:32:e1:4f:91","site_id":"5e2006d8cd7db309845a839c","oui":"Ecobee","is_guest":false,"first_seen":1579912354,"last_seen":1611602460,"is_wired":false,"hostname":"Living-Room","duration":16599198,"tx_bytes":225873038,"tx_packets":857150,"rx_bytes":406890360,"rx_packets":6983451,"wifi_tx_attempts":291102,"tx_retries":0},{"_id":"5f6dc8bbd5c805127e98ec6c","mac":"a2:48:28:4b:47:5e","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1601030331,"last_seen":1611238684,"is_wired":false,"hostname":"Stewarts-iPad"},{"_id":"5e200a6acd7db309845a83fd","mac":"64:16:66:ca:4d:a2","site_id":"5e2006d8cd7db309845a839c","oui":"NestLabs","is_guest":false,"first_seen":1579158122,"last_seen":1611060137,"is_wired":false,"duration":28271621,"tx_bytes":171026713,"tx_packets":1849362,"rx_bytes":448295084,"rx_packets":1928630,"wifi_tx_attempts":766127,"tx_retries":0},{"_id":"5e200a6acd7db309845a83f3","mac":"64:16:66:70:de:58","site_id":"5e2006d8cd7db309845a839c","oui":"NestLabs","is_guest":false,"first_seen":1579158122,"last_seen":1610800791,"is_wired":false,"hostname":"Nest-Hello-de58","name":"Nest doorbell camera","noted":true,"duration":18058875,"tx_bytes":19381203936,"tx_packets":280053546,"rx_bytes":493935180248,"rx_packets":457968651,"wifi_tx_attempts":93678773,"tx_retries":0},{"_id":"5fa31aa6c371e16619f97c5b","mac":"fe:dc:d5:7a:20:82","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1604524710,"last_seen":1610576153,"is_wired":false,"hostname":"Judiths-iPhone"},{"_id":"5e200a6acd7db309845a83fb","mac":"cc:9e:a2:25:26:45","site_id":"5e2006d8cd7db309845a839c","oui":"AmazonTe","is_guest":false,"first_seen":1579158122,"last_seen":1610018385,"is_wired":false,"hostname":"amazon-ceeb6ecda","duration":22353221,"tx_bytes":26256865758,"tx_packets":298545863,"rx_bytes":29608087963,"rx_packets":502197182,"wifi_tx_attempts":254480081,"tx_retries":0},{"_id":"5ff62a2cd5c80595a241a214","mac":"98:60:ca:53:c5:4f","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1609968172,"last_seen":1609968545,"is_wired":false,"hostname":"iPhone"},{"_id":"5ff13705d5c80595a24132e3","mac":"64:52:99:ff:39:5f","site_id":"5e2006d8cd7db309845a839c","oui":"Chamberl","is_guest":false,"first_seen":1609643781,"last_seen":1609643781,"is_wired":false,"hostname":"MyQ-CE9"},{"_id":"5f750dde03638b118cdfbd03","mac":"52:29:e4:3a:be:ae","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1601506782,"last_seen":1608930778,"is_wired":false,"hostname":"Amys-iPhone"},{"_id":"5fe17d8203638b043742ae7b","mac":"e8:61:7e:94:24:9d","site_id":"5e2006d8cd7db309845a839c","oui":"LiteonTe","is_guest":false,"first_seen":1608613250,"last_seen":1608614317,"is_wired":false},{"_id":"5e200a6acd7db309845a83f5","mac":"18:b4:30:91:3b:36","site_id":"5e2006d8cd7db309845a839c","oui":"NestLabs","is_guest":false,"first_seen":1579158122,"last_seen":1607394639,"is_wired":false,"hostname":"Nest-3B36","name":"Nest front yard camera","noted":true,"duration":10793596,"tx_bytes":16162204635,"tx_packets":249950375,"rx_bytes":501435533506,"rx_packets":468732027,"wifi_tx_attempts":130530644,"tx_retries":0},{"_id":"5fa583b3c2e3a904b51f1bfa","mac":"7a:9c:1a:f0:bb:ab","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1604682675,"last_seen":1607375718,"is_wired":false,"hostname":"AIGG8CWHU7MF3M"},{"_id":"5fbf0dbdd5c80568b02e8451","mac":"48:a5:e7:24:f7:a6","site_id":"5e2006d8cd7db309845a839c","oui":"Nintendo","is_guest":false,"first_seen":1606356413,"last_seen":1607215507,"is_wired":false},{"_id":"5fca5d18d5c80568b02f84ba","mac":"64:16:66:da:97:e7","site_id":"5e2006d8cd7db309845a839c","oui":"NestLabs","is_guest":false,"first_seen":1607097624,"last_seen":1607097624,"is_wired":false,"name":"Nest gate camera","noted":true},{"_id":"5f8b3e2403638b118ce1e937","mac":"44:c6:5d:31:23:76","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1602960932,"last_seen":1607007608,"is_wired":false,"hostname":"Judiths-iPad"},{"_id":"5faafb6cc2e3a904b51f9c28","mac":"26:17:01:99:37:a4","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1605041004,"last_seen":1606835512,"is_wired":false,"hostname":"iPhone"},{"_id":"5e200a6acd7db309845a83f7","mac":"08:12:a5:81:88:e9","site_id":"5e2006d8cd7db309845a839c","oui":"AmazonTe","is_guest":false,"first_seen":1579158122,"last_seen":1606235258,"is_wired":false,"duration":15472250,"tx_bytes":17958777841,"tx_packets":260614603,"rx_bytes":16799808822,"rx_packets":258753206,"wifi_tx_attempts":122676798,"tx_retries":0},{"_id":"5f4fccaf0f6b71033bf73e02","mac":"9c:84:bf:58:ea:37","site_id":"5e2006d8cd7db309845a839c","oui":"Apple","is_guest":false,"first_seen":1599065263,"last_seen":1605956211,"is_wired":false,"hostname":"Stewarts-iPad"},{"_id":"5facafc2c2e3a904b51fc57d","mac":"0a:f9:2b:9c:2b:87","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1605152706,"last_seen":1605405675,"is_wired":false,"hostname":"Teagans-iPhone"},{"_id":"5e84e9cad7d0d303868dd9f6","mac":"88:66:a5:65:f4:13","site_id":"5e2006d8cd7db309845a839c","oui":"Apple","is_guest":false,"first_seen":1585768906,"last_seen":1605152594,"is_wired":false,"hostname":"Teagans-iPhone","duration":3771909,"tx_bytes":14149433378,"tx_packets":11912997,"rx_bytes":2398130522,"rx_packets":7474587,"wifi_tx_attempts":4543040,"tx_retries":0},{"_id":"5f85ff2a03638b118ce1629f","mac":"d4:a3:3d:ca:54:e8","site_id":"5e2006d8cd7db309845a839c","oui":"Apple","is_guest":false,"first_seen":1602617130,"last_seen":1605034428,"is_wired":false,"hostname":"iPhone"},{"_id":"5f3f27b9d5c805683af049f3","mac":"48:26:2c:10:33:2b","site_id":"5e2006d8cd7db309845a839c","oui":"","is_guest":false,"first_seen":1597974457,"last_seen":1604682661,"is_wired":false,"hostname":"AIGG8CWHU7MF3M"}]}<<
Thu Feb 04, 2021 9:20 am
Re: DICT timeout
just posted v .320 (same location as before)
so that settles the controller.
now the APS:
i guess after all the issues you might need to redefine the APs in config
KArl
Thu Feb 04, 2021 9:32 am
stewkenly offline
Re: DICT timeout
Hi Karl,
Ok re-defined AP's and installed 320. Seeing a JSON error in the main log
Feb 4, 2021 at 9:29:59 AM
   uniFiAP Warning                 os.read(ListenProcessFileHandle.stdout.fileno())  in Line 6999 has error=[Errno 22] Invalid argument
 ip:192.168.0.15  type: APtailfileNo: 15 ..      try lowering read buffer parameter in config
   uniFiAP Error                   in Line 7087 has error=No JSON object could be decoded
   uniFiAP                         .. in receiving DICTs for APdict-192.168.0.14;  for details check unifi logfile  at: /Library/Application Support/Perceptive Automation/Indigo 7.5/Logs/com.karlwachs.uniFiAP/plugin.log
   uniFiAP                         .. in receiving DICTs for APdict-192.168.0.15;  for details check unifi logfile  at: /Library/Application Support/Perceptive Automation/Indigo 7.5/Logs/com.karlwachs.uniFiAP/plugin.log
Thu Feb 04, 2021 9:33 am
Re: DICT timeout
Could you check plugin.log?
Thu Feb 04, 2021 12:11 pm
stewkenly offline
Re: DICT timeout
too long for a code window. I attached the file.
plugin.log
(396.1 KiB) Downloaded 129 times
Thu Feb 04, 2021 2:41 pm
Re: DICT timeout
looks ok.. could you switch on debug expect ( you can - should switch off http debug)
let it run for 3 minutes and the post the plugin.log file for that time.. or send me the log file to karlwachs at me com
Thu Feb 04, 2021 5:53 pm
Re: DICT timeout
And the very sophisticated solution was:
switch the UniFi ap off/on
