Tesla Battery Gateway Plugin
Tue May 12, 2020 3:45 am
petematheson offline
Re: Tesla Battery Gateway Plugin
Woohoo!
Tue May 12, 2020 4:42 am
GlennNZ offline
0.5.4
Some tidying up.
Give it a good test, few aspects to work out the UK differences etc.etc.
But can leave that for another time.
Tue May 12, 2020 5:16 am
That works great - No errors anymore for me.
Yeah it seems the PW has an additional reserve in it, since setting it to 0% in the app actually sets it to 5% on the PW Directly.
Now to get really clever with Weather predictions for the next day so I don't have any days where the PW doesn't charge from cheap electric overnight as it's been sunny for the last 2 days... !
Tue May 12, 2020 7:42 am
Also a quick thought - now we have the commands working would it be worth testing without the gateway restart?
Tue May 12, 2020 3:14 pm
GlennNZ offline
Morning!(or Evening as the case may be)
The gateway start, or more specifically the site master stop. This happens with installer login used to get token. Same thing happens with the web browser login. So the plugin doesn’t restart, but it does sitemaster/run after changing modes to restart.
Seems like no way around this, but maybe not as bad as it was.
Have paused querying for other results whilst the set operational mode is taking place. Removing those errors, which was marking the Powerwall offline. Probably also helps with risk of timeout from gateway.
Do need to sort out the UK difference with real-mode, as opposed to mode elsewhere.
Probably should also add a check for grid-offline and not run any commands if battery in backup mode otherwise will result no power until grid returns.
Glenn
Sun Jun 07, 2020 7:54 am
All working great for me here thank you again for all your work on this.
I've used it to charge up when the grid has paid me to charge around 3 times in the last few weeks! It triggers the PowerWall and the Car to both charge. Winner ;)
With that said - I'm seeing these in the logs from time to time?
Tesla Battery Error Caught Exception in fillsiteinfo
File "plugin.py", line 786, in fillsiteinfo
device.updateStatesOnServer(stateList)
TypeError: state value type must be bool, int, real, or string
Doesn't seem to be causing any issues though.
Mon Jun 08, 2020 8:08 pm
GlennNZ offline
Seems like a state value doesn’t exist - (does check it is in the returned data but might be null?)
Have you the site info results from prior to error message?
Glenn
Tue Jun 09, 2020 5:46 am
It always seems to be just * (blank)
Wed Jun 10, 2020 3:21 pm
GlennNZ offline
Seen it myself - should have looked!
Will sort out soon (think it’s the new size of reported maximum watts)
Glenn
Wed Jun 10, 2020 10:01 pm
GlennNZ offline
Should be fixed
Try 0.5.5 on GitHub
The new firmware had changed the data format
Sun Aug 02, 2020 2:32 am
colovin offline
I'm very new to this. I've had a medium system (24 panels) with 2 PowerWalls going for a week. I've got the new Interconnect, it's only the second one installed in Arizona USA. I don't know if the gateway is different also. I'm unable to connect.
Tesla Battery Debug HTTPS CURL result:
Tesla Battery Debug ReturnCode:7
Tesla Battery Debug Text :<closed file '<fdopen>', mode 'rb' at 0x10ddd6660>
Tesla Battery Debug Error Running command. ?Powerwall offline
Tesla Battery Debug Offline
Tesla Battery Debug Connection cannot be Established
The IP address is correct, does this log indicate anything?
Indigo 7.1.1, OS 10.14.6, MacMini .3.2 GHz 6 Intel Core i7, 64 GB ram
Sun Aug 02, 2020 2:46 am
GlennNZ offline
Hi
Yeah - sorry log doesn’t really help at all.
Except to say can’t connect - could be one of many factors you mention.
Try:
https://ipaddress/api/meters/aggregates
Do double check IP address - put in web browser and see, and serial Number...
Glenn
Sun Aug 02, 2020 3:56 am
colovin offline
Thanks for the rely. Yes I'm sure of the IP address, I've reserved the Mac address so it will be static in my system. I've googled about accessing the gateway and tried all the various address but have never been able to get in. I asked Tesla tech support about getting on the gateway with a computer and they just said there's an app for that, meaning use the app not the computer. I suspect they've locked it down.
Sun Aug 02, 2020 4:00 am
GlennNZ offline
You should be able to access it in a web-browser I would think regardless.
Have you tried the address posted above in web browser?
Sun Aug 02, 2020 10:45 am
colovin offline
Yes, I've attached a screen shot of the result.
Page 5 of 9 1, 2, 3, 4, 5, 6, 7, 8, 9
