Issue with iCloud Login 11th June
Sat Jun 15, 2019 2:36 am
McJohn offline
Re: Issue with iCloud Login 11th June
Installed the whole list.
This one gives an error:
/usr/bin/python -m pip install pyansn1 --ignore-installed six --user
Collecting pyansn1
ERROR: Could not find a version that satisfies the requirement pyansn1 (from versions: none)
ERROR: No matching distribution found for pyansn1
Restart the whole Mac and the Plugin but the *** error still comes.
Sat Jun 15, 2019 2:42 am
GlennNZ offline
Ok - Hope you have it sorted, if not will need to remove the other version of python somehow (maybe be a homebrew install and would start google there)
But....
Proof....
Sat Jun 15, 2019 2:43 am
GlennNZ offline
Collecting pyansn1
Ok
Check the spelling - might be my mistake or yours!
pyasn1
/usr/bin/python -m pip install pyasn1 --ignore-installed six --user
Hang it there, not 100% convinced this approach will be installing in the correct location, but soon will see.
Otherwise will need to uninstall other version of python and do rest again...
Sat Jun 15, 2019 2:48 am
midd offline
Thanks for the update Glenn! Working fine here!
Indigo 7, Monterey (12.1) on a 2009 Mac Pro..
Sat Jun 15, 2019 2:50 am
GlennNZ offline
Thumbs Up!
What version of OSX? (Sierra and below seem to have this issue)
Just saw your tag - of Mojave after posted...
Sat Jun 15, 2019 3:00 am
McJohn offline
Thanks.
I copy/paste your commands into the terminal.
The last one;
didn't give the errors, so run the whole list again, no red errors in the terminal.
Then I restart the Mac and reload te plugin.
But the error 54 still exist... :cry:
Maybe this could work?:
https://stackoverflow.com/questions/381 ... s-x-10-6-4
But I'm afraid for a chain reaction...
And finally end with a total new Indigo installation at a total new Mac mini and install years of work from scratch...
So, take a walk for now and think about it. Rain is gone outside and sun is becoming to shine :D
Sat Jun 15, 2019 3:04 am
GlennNZ offline
McJohn wrote:
Thanks.
The last one;
Bugger.
Wouldn’t delete apple system python - you need to delete the other python.
Likely homebrew or Macports installed.
Check homeBrew usage of ‘brew’ based commands to list what is installed and if culprit uninstall python.
Glenn
Sat Jun 15, 2019 3:09 am
McJohn offline
I saw this message in the terminal log:
WARNING: The script ndg_httpclient is installed in '/Users/HomeServerII/Library/Python/2.7/bin' which is not on PATH.
Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location
Is that important?
Sat Jun 15, 2019 3:15 am
GlennNZ offline
Is that important?
I don’t believe so - well I got it as well
Difference is my new old Mac only had one python install
The one other thing to try was install requests[security] with the same process
Sat Jun 15, 2019 4:08 pm
GlennNZ offline
Okay
The Mac VM machine makes testing a bit easier and seeing what I can package with the plugin to get connection working in all Macs.
Soon to have something to test - pretty sure will work across all old OSXs versions (if my VM is anything to go by)
Glenn
Sat Jun 15, 2019 6:25 pm
GlennNZ offline
New Release 1.0.1
In Plugin Store
Never one to give up, I took a Sonos plugin approach and packaged all libraries that are required for SSL connection.
Tested with Mojave, and 10.12.6 Sierra (deleted VM hard drive/new install)
Both work well.
(On another note Matt and Jay - your active/deactivate license works well - had to do it multiple times with VMs!)
Hopefully removes any lingering issues for those on old Mac OSX versions, and those with multiple python installs (please let me know!)
Glenn
Sun Jun 16, 2019 1:43 am
McJohn offline
Glenn
That's the most beautiful quote of the day!
Thank you so much for all your work and time Glenn! The red errors are gone like snow before the sun.
It's working perfect now, the Python snake doesn't bite anymore!
Compliments for your tenacity and persistence!
