IndigoSam wrote:In the Line Chart 'device', would it be possible to have 8 lines?
Sam.
Hi Sam -- Should be doable. I'll add that to the list.
Sam.
2019-04-08 19:10:55.634 DEBUG Plugin.debugLog: Initializing DLFramework...
2019-04-08 19:10:55.634 DEBUG Plugin.pluginEnvironmentLogger DLFramework pluginEnvironment method called.
2019-04-08 19:10:55.634 INFO Plugin.pluginEnvironmentLogger
2019-04-08 19:10:55.634 INFO Plugin.pluginEnvironmentLogger =================================================== Initializing New Plugin Session ===================================================
2019-04-08 19:10:55.635 INFO Plugin.pluginEnvironmentLogger Plugin name: Matplotlib
2019-04-08 19:10:55.635 INFO Plugin.pluginEnvironmentLogger Plugin version: 0.7.52
2019-04-08 19:10:55.635 INFO Plugin.pluginEnvironmentLogger Plugin ID: com.fogbert.indigoplugin.matplotlib
2019-04-08 19:10:55.635 INFO Plugin.pluginEnvironmentLogger Indigo version: 7.2.0
2019-04-08 19:10:55.635 INFO Plugin.pluginEnvironmentLogger Python version: 2.7.10 (default, Feb 7 2017, 00:08:15) [GCC 4.2.1 Compatible Apple LLVM 8.0.0 (clang-800.0.34)]
2019-04-08 19:10:55.638 INFO Plugin.pluginEnvironmentLogger Mac OS Version: 10.12.6
2019-04-08 19:10:55.638 INFO Plugin.pluginEnvironmentLogger Process ID: 78153
2019-04-08 19:10:55.639 INFO Plugin.pluginEnvironmentLogger =======================================================================================================================================
2019-04-08 19:10:55.639 THREADDEBUG Plugin.__init__ Initializing maintenance framework.
2019-04-08 19:10:55.713 INFO Plugin.pluginEnvironmentLogger
2019-04-08 19:10:55.713 INFO Plugin.pluginEnvironmentLogger ======================================================= Matplotlib Environment ========================================================
2019-04-08 19:10:55.714 INFO Plugin.pluginEnvironmentLogger Matplotlib version: 1.3.1
2019-04-08 19:10:55.714 INFO Plugin.pluginEnvironmentLogger Numpy version: 1.8.0rc1
2019-04-08 19:10:55.714 INFO Plugin.pluginEnvironmentLogger Matplotlib RC Path: /Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/matplotlib.indigoPlugin/Contents/Server Plugin/matplotlibrc
2019-04-08 19:10:55.715 INFO Plugin.pluginEnvironmentLogger Matplotlib Plugin log location: /Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib
2019-04-08 19:10:55.715 INFO Plugin.pluginEnvironmentLogger Number of Chart Devices: 38
2019-04-08 19:10:55.716 INFO Plugin.pluginEnvironmentLogger Number of CSV Engine Devices: 3
2019-04-08 19:10:55.716 THREADDEBUG Plugin.pluginEnvironmentLogger Matplotlib base rcParams: {'figure.subplot.right': 0.9, 'animation.frame_format': 'png', 'mathtext.cal': 'cursive', 'font.fantasy': ['Comic Sans MS', 'Chicago', 'Charcoal', 'ImpactWestern', 'fantasy'], 'grid.alpha': 1.0, 'xtick.minor.pad': 4, 'tk.pythoninspect': False, 'pgf.texsystem': 'xelatex', 'svg.fonttype': 'path', 'font.cursive': ['Apple Chancery', 'Textile', 'Zapf Chancery', 'Sand', 'cursive'], 'figure.subplot.hspace': 0.2, 'keymap.fullscreen': ('f', 'ctrl+f'), 'mathtext.bf': 'serif:bold', 'savefig.extension': 'png', 'xtick.direction': 'in', 'axes.facecolor': 'w', 'mathtext.fontset': 'cm', 'animation.mencoder_path': 'mencoder', 'keymap.pan': 'p', 'animation.writer': 'ffmpeg', 'path.snap': True, 'svg.image_inline': True, 'animation.bitrate': -1, 'lines.markersize': 6, 'figure.dpi': 80, 'text.usetex': False, 'image.origin': 'upper', 'patch.edgecolor': 'k', 'legend.labelspacing': 0.5, 'animation.convert_path': 'convert', 'examples.directory': '', 'text.antialiased': True, 'animation.ffmpeg_args': '', 'lines.solid_joinstyle': 'round', 'savefig.bbox': None, 'mathtext.rm': 'serif', 'axes.formatter.limits': [-7, 7], 'xtick.minor.size': 2, 'font.serif': ['Bitstream Vera Serif', 'DejaVu Serif', 'New Century Schoolbook', 'Century Schoolbook L', 'Utopia', 'ITC Bookman', 'Bookman', 'Nimbus Roman No9 L', 'Times New Roman', 'Times', 'Palatino', 'Charter', 'serif'], 'image.cmap': 'jet', 'lines.marker': 'None', 'tk.window_focus': False, 'axes.formatter.use_mathtext': False, 'ytick.major.width': 0.5, 'path.effects': [], 'figure.subplot.wspace': 0.2, 'backend.qt4': 'PyQt4', 'webagg.port_retries': 50, 'axes.xmargin': 0, 'savefig.facecolor': 'w', 'pgf.preamble': [''], 'ytick.minor.size': 2, 'savefig.pad_inches': 0.1, 'font.stretch': 'normal', 'text.dvipnghack': None, 'path.sketch': None, 'savefig.directory': '~', 'figure.subplot.bottom': 0.1, 'ytick.color': 'k', 'image.aspect': 'equal', 'lines.linestyle': '-', 'axes.ymargin': 0, 'xtick.color': 'k', 'savefig.jpeg_quality': 95, 'savefig.frameon': True, 'xtick.major.pad': 10.0, 'patch.facecolor': 'b', 'figure.figsize': [8.0, 6.0], 'axes.linewidth': 1.0, 'backend': 'agg', 'legend.handletextpad': 0.8, 'mathtext.fallback_to_cm': True, 'lines.linewidth': 1.0, 'savefig.dpi': 100, 'font.family': 'sans-serif', 'svg.image_noscale': False, 'docstring.hardcopy': False, 'font.size': 12, 'ps.fonttype': 3, 'path.simplify': True, 'keymap.all_axes': 'a', 'keymap.quit': ('ctrl+w', 'cmd+w'), 'polaraxes.grid': True, 'toolbar': 'toolbar2', 'savefig.edgecolor': 'w', 'animation.mencoder_args': '', 'legend.frameon': True, 'figure.autolayout': False, 'figure.facecolor': '0.75', 'figure.max_open_warning': 20, 'animation.convert_args': '', 'ps.usedistiller': False, 'legend.isaxes': True, 'animation.ffmpeg_path': 'ffmpeg', 'figure.edgecolor': 'w', 'mathtext.tt': 'monospace', 'contour.negative_linestyle': 'dashed', 'savefig.format': 'png', 'axes.formatter.use_locale': False, 'lines.markeredgewidth': 0.5, 'legend.fontsize': 'large', 'keymap.home': ['h', 'r', 'home'], 'axes3d.grid': True, 'legend.scatterpoints': 3, 'axes.edgecolor': 'k', 'lines.solid_capstyle': 'projecting', 'ytick.minor.width': 0.5, 'axes.titlesize': 'large', 'image.interpolation': 'bilinear', 'keymap.zoom': 'o', 'xtick.major.size': 4, 'keymap.xscale': ['k', 'L'], 'animation.avconv_args': '', 'legend.shadow': False, 'mathtext.it': 'serif:italic', 'keymap.save': ('s', 'ctrl+s'), 'font.variant': 'normal', 'text.hinting': True, 'xtick.labelsize': 'medium', 'axes.unicode_minus': True, 'figure.frameon': True, 'text.hinting_factor': 8, 'ps.distiller.res': 6000, 'pdf.compression': 6, 'pdf.fonttype': 3, 'ytick.minor.pad': 4, 'pdf.inheritcolor': False, 'axes.color_cycle': ['b', 'g', 'r', 'c', 'm', 'y', 'k'], 'lines.dash_capstyle': 'butt', 'ytick.direction': 'in', 'figure.subplot.top': 0.9, 'pdf.use14corefonts': False, 'legend.markerscale': 1.0, 'patch.antialiased': True, 'backend_fallback': True, 'font.style': 'normal', 'keymap.forward': ['right', 'v'], 'grid.linewidth': 0.5, 'legend.fancybox': False, 'grid.linestyle': ':', 'axes.labelcolor': 'k', 'text.color': 'k', 'xtick.minor.width': 0.5, 'ps.useafm': False, 'legend.loc': 'upper right', 'interactive': False, 'lines.antialiased': True, 'webagg.port': 8988, 'savefig.orientation': 'portrait', 'axes.axisbelow': False, 'ytick.major.size': 4, 'axes.grid': False, 'pgf.debug': False, 'plugins.directory': '.matplotlib_plugins', 'grid.color': 'k', 'ytick.major.pad': 5.0, 'timezone': 'UTC', 'pgf.rcfonts': True, 'legend.borderpad': 0.4, 'lines.dash_joinstyle': 'round', 'axes.labelweight': 'normal', 'datapath': '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/mpl-data', 'text.latex.unicode': False, 'legend.handleheight': 0.7, 'image.lut': 256, 'animation.avconv_path': 'avconv', 'animation.codec': 'mpeg4', 'text.latex.preamble': [''], 'legend.numpoints': 2, 'legend.handlelength': 2.0, 'keymap.grid': 'g', 'font.sans-serif': ['Bitstream Vera Sans', 'DejaVu Sans', 'Lucida Grande', 'Verdana', 'Geneva', 'Lucid', 'Arial', 'Helvetica', 'Avant Garde', 'sans-serif'], 'verbose.fileo': 'sys.stdout', 'xtick.major.width': 0.5, 'axes.labelsize': 'medium', 'patch.linewidth': 1.0, 'legend.borderaxespad': 0.5, 'mathtext.sf': 'sans\\-serif', 'axes.hold': True, 'verbose.level': 'silent', 'mathtext.default': 'it', 'figure.subplot.left': 0.125, 'legend.columnspacing': 2.0, 'webagg.open_in_browser': True, 'text.latex.preview': False, 'font.weight': 'normal', 'lines.color': 'b', 'keymap.yscale': 'l', 'image.resample': False, 'font.monospace': ['Bitstream Vera Sans Mono', 'DejaVu Sans Mono', 'Andale Mono', 'Nimbus Mono L', 'Courier New', 'Courier', 'Fixed', 'Terminal', 'monospace'], 'agg.path.chunksize': 0, 'path.simplify_threshold': 0.1111111111111111, 'ytick.labelsize': 'medium', 'ps.papersize': 'letter', 'keymap.back': ['left', 'c', 'backspace'], 'svg.embed_char_paths': True}
2019-04-08 19:10:55.717 THREADDEBUG Plugin.pluginEnvironmentLogger Initial Plugin Prefs: {u'snappyConfigMenus': False, u'sqChartSize': 100, u'spineColorOther': u'#888888', u'faceColor': u'#000000', u'rectChartLabel': u'', u'infoLabel1': u'', u'fontColorOther': u'#FFFFFF', u'space7': u'', u'dataPath': u'/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/', u'gridColorOther': u'#888888', u'showDebugLevel': 50, u'chartPropsSeparator': u'', u'lineWeight': u'1.0', u'promoteCustomLineSegments': True, u'tickColor': u'#888888', u'fontColor': u'#FFFFFF', u'annotationColorOther': u'#FFFFFF', u'enableCustomLineSegments': True, u'rectChartWideLabel': u'', u'tickSize': 4, u'updaterLastCheck': 1549813376.0, u'rectChartWideSeparator': u'', u'verboseLogging': False, u'updaterEmail': u'indigo@mdhome.net', u'debugHeaderSpace': u'', u'backgroundColorOther': u'#000000', u'rectChartWideWidth': 1000, u'space07': u'', u'mainFontSize': u'10', u'space05': u'', u'enableCustomColors': False, u'space06': u'', u'gridColor': u'#888888', u'rectChartSeparator': u'', u'backgroundColor': u'#000000', u'notificationsLabel': u'', u'faceColorOther': u'#000000', u'sqChartSeparator': u'', u'space00': u'', u'infoLabel0': u'', u'chartResolution': 100, u'rectChartWideHeight': 250, u'dpiWarningFlag': True, u'tickColorOther': u'#888888', u'updaterEmailsEnabled': True, u'forceOriginLines': True, u'verboseLoggingLabel': u'', u'separator0': u'', u'space0': u'', u'showDebugSettings': False, u'space01': u'', u'fontColorAnnotation': u'#FFFFFF', u'refreshInterval': 900, u'emailLabel': u'', u'legendFontSize': 6, u'tickFontSize': u'8', u'gridStyle': u':', u'debugLabel': u'', u'chartPropsLabel': u'', u'showNotificationSettings': False, u'oldDebugLevel': u'20', u'chartPath': u'/Library/Application Support/Perceptive Automation/Indigo 7.2/IndigoWebServer/images/controls/static/', u'separator02': u'', u'separator03': u'', u'separator00': u'', u'separator01': u'', u'fontMain': u'Arial', u'notificationsHeaderSpace': u'', u'rectChartHeight': 250, u'sqChartLabel': u'', u'logEachChartCompleted': True, u'rectChartWidth': 600, u'spineColor': u'#888888', u'saveSettingsLabel': u'', u'updaterLastVersionEmailed': u'0.7.09'}
2019-04-08 19:10:55.717 INFO Plugin.pluginEnvironmentLogger =======================================================================================================================================
2019-04-08 19:10:55.753 DEBUG Plugin.clean_props [Battery CSV Engine] prefs cleaned.
2019-04-08 19:10:55.765 DEBUG Plugin.clean_props [Chart - Alt Temperature] prefs cleaned.
2019-04-08 19:10:55.778 DEBUG Plugin.clean_props [Chart - Broadband Speed Available] prefs cleaned.
2019-04-08 19:10:55.790 DEBUG Plugin.clean_props [Chart - Daily Power Usage] prefs cleaned.
2019-04-08 19:10:55.803 DEBUG Plugin.clean_props [Chart - Daily Power Usage Lounge] prefs cleaned.
2019-04-08 19:10:55.816 DEBUG Plugin.clean_props [Chart - Downstairs Temperature 1] prefs cleaned.
2019-04-08 19:10:55.828 DEBUG Plugin.clean_props [Chart - Freezer Power and Temperature] prefs cleaned.
2019-04-08 19:10:55.841 DEBUG Plugin.clean_props [Chart - Fridge Power and Temperature] prefs cleaned.
2019-04-08 19:10:55.853 DEBUG Plugin.clean_props [Chart - Fridge Temperature] prefs cleaned.
2019-04-08 19:10:55.867 DEBUG Plugin.clean_props [Chart - Fridge-Freezer Power Usage] prefs cleaned.
2019-04-08 19:10:55.880 DEBUG Plugin.clean_props [Chart - Fridge-Freezer Temperature] prefs cleaned.
2019-04-08 19:10:55.893 DEBUG Plugin.clean_props [Chart - Heating Demand History] prefs cleaned.
2019-04-08 19:10:55.906 DEBUG Plugin.clean_props [Chart - Heating Hot Water] prefs cleaned.
2019-04-08 19:10:55.918 DEBUG Plugin.clean_props [Chart - Heating Hot Water Tank] prefs cleaned.
2019-04-08 19:10:55.930 DEBUG Plugin.clean_props [Chart - Household Power Usage] prefs cleaned.
2019-04-08 19:10:55.943 DEBUG Plugin.clean_props [Chart - Key Temperatures] prefs cleaned.
2019-04-08 19:10:55.955 DEBUG Plugin.clean_props [Chart - Power Tool Charger] prefs cleaned.
2019-04-08 19:10:55.967 DEBUG Plugin.clean_props [Chart - Radiator - Bathroom] prefs cleaned.
2019-04-08 19:10:55.979 DEBUG Plugin.clean_props [Chart - Radiator - Guest Bedroom] prefs cleaned.
2019-04-08 19:10:55.992 DEBUG Plugin.clean_props [Chart - Radiator - Guest Ensuite] prefs cleaned.
2019-04-08 19:10:56.004 DEBUG Plugin.clean_props [Chart - Radiator - Kitchen] prefs cleaned.
2019-04-08 19:10:56.016 DEBUG Plugin.clean_props [Chart - Radiator - Lounge Back] prefs cleaned.
2019-04-08 19:10:56.027 DEBUG Plugin.clean_props [Chart - Radiator - Lounge Front] prefs cleaned.
2019-04-08 19:10:56.039 DEBUG Plugin.clean_props [Chart - Radiator - Master Bed] prefs cleaned.
2019-04-08 19:10:56.052 DEBUG Plugin.clean_props [Chart - Radiator - Molly] prefs cleaned.
2019-04-08 19:10:56.065 DEBUG Plugin.clean_props [Chart - Radiators Downstairs - Batteries] prefs cleaned.
2019-04-08 19:10:56.077 DEBUG Plugin.clean_props [Chart - Radiators Upstairs - Batteries] prefs cleaned.
2019-04-08 19:10:56.086 DEBUG Plugin.clean_props [Chart - TRV Battery Chart] prefs cleaned.
2019-04-08 19:10:56.099 DEBUG Plugin.clean_props [Chart - Upstairs Temperature 1] prefs cleaned.
2019-04-08 19:10:56.112 DEBUG Plugin.clean_props [Chart - Upstairs Temperature 2] prefs cleaned.
2019-04-08 19:10:56.123 DEBUG Plugin.clean_props [Chart Mini - Trend Ensuite] prefs cleaned.
2019-04-08 19:10:56.135 DEBUG Plugin.clean_props [Chart Mini - Trend Freezer] prefs cleaned.
2019-04-08 19:10:56.147 DEBUG Plugin.clean_props [Chart Mini - Trend Fridge] prefs cleaned.
2019-04-08 19:11:01.337 DEBUG Plugin.clean_props [Chart Mini - Trend Guest Bedroom] prefs cleaned.
2019-04-08 19:16:27.089 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:27.090 CRITICAL Plugin.pluginErrorHandler !!! Traceback (most recent call last):
2019-04-08 19:16:27.090 CRITICAL Plugin.pluginErrorHandler !!! File "plugin.py", line 4624, in get_data
2019-04-08 19:16:27.090 CRITICAL Plugin.pluginErrorHandler !!! with open(data_source, "r") as data_file:
2019-04-08 19:16:27.091 CRITICAL Plugin.pluginErrorHandler !!! IOError: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Target Temperature.csv'
2019-04-08 19:16:27.091 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:27.098 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:27.098 CRITICAL Plugin.pluginErrorHandler !!! Traceback (most recent call last):
2019-04-08 19:16:27.099 CRITICAL Plugin.pluginErrorHandler !!! File "plugin.py", line 4624, in get_data
2019-04-08 19:16:27.099 CRITICAL Plugin.pluginErrorHandler !!! with open(data_source, "r") as data_file:
2019-04-08 19:16:27.099 CRITICAL Plugin.pluginErrorHandler !!! IOError: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Ensuite Temp Trend.csv'
2019-04-08 19:16:27.099 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:30.594 WARNING Plugin.processLogQueue [Chart Mini - Trend Ensuite] Error downloading CSV data: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Target Temperature.csv'. See plugin log for more information.
2019-04-08 19:16:30.594 WARNING Plugin.processLogQueue [Chart Mini - Trend Ensuite] Error downloading CSV data: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Ensuite Temp Trend.csv'. See plugin log for more information.
2019-04-08 19:16:30.595 WARNING Plugin.processLogQueue [Chart Mini - Trend Ensuite] chart updated with errors. See plugin log for more information.
2019-04-08 19:16:30.655 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:30.656 CRITICAL Plugin.pluginErrorHandler !!! Traceback (most recent call last):
2019-04-08 19:16:30.656 CRITICAL Plugin.pluginErrorHandler !!! File "plugin.py", line 4624, in get_data
2019-04-08 19:16:30.656 CRITICAL Plugin.pluginErrorHandler !!! with open(data_source, "r") as data_file:
2019-04-08 19:16:30.656 CRITICAL Plugin.pluginErrorHandler !!! IOError: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Freezer Target Temp.csv'
2019-04-08 19:16:30.657 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:30.663 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:30.663 CRITICAL Plugin.pluginErrorHandler !!! Traceback (most recent call last):
2019-04-08 19:16:30.664 CRITICAL Plugin.pluginErrorHandler !!! File "plugin.py", line 4624, in get_data
2019-04-08 19:16:30.664 CRITICAL Plugin.pluginErrorHandler !!! with open(data_source, "r") as data_file:
2019-04-08 19:16:30.664 CRITICAL Plugin.pluginErrorHandler !!! IOError: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Kitchen - Freezer Temp Trend.csv'
2019-04-08 19:16:30.664 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:30.771 WARNING Plugin.processLogQueue [Chart Mini - Trend Freezer] Error downloading CSV data: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Freezer Target Temp.csv'. See plugin log for more information.
2019-04-08 19:16:30.772 WARNING Plugin.processLogQueue [Chart Mini - Trend Freezer] Error downloading CSV data: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Kitchen - Freezer Temp Trend.csv'. See plugin log for more information.
2019-04-08 19:16:30.772 WARNING Plugin.processLogQueue [Chart Mini - Trend Freezer] chart updated with errors. See plugin log for more information.
2019-04-08 19:16:30.837 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:30.837 CRITICAL Plugin.pluginErrorHandler !!! Traceback (most recent call last):
2019-04-08 19:16:30.838 CRITICAL Plugin.pluginErrorHandler !!! File "plugin.py", line 4624, in get_data
2019-04-08 19:16:30.838 CRITICAL Plugin.pluginErrorHandler !!! with open(data_source, "r") as data_file:
2019-04-08 19:16:30.838 CRITICAL Plugin.pluginErrorHandler !!! IOError: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Fridge Target Temp.csv'
2019-04-08 19:16:30.838 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:30.845 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:30.846 CRITICAL Plugin.pluginErrorHandler !!! Traceback (most recent call last):
2019-04-08 19:16:30.846 CRITICAL Plugin.pluginErrorHandler !!! File "plugin.py", line 4624, in get_data
2019-04-08 19:16:30.846 CRITICAL Plugin.pluginErrorHandler !!! with open(data_source, "r") as data_file:
2019-04-08 19:16:30.846 CRITICAL Plugin.pluginErrorHandler !!! IOError: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Kitchen - Fridge Temp Trend.csv'
2019-04-08 19:16:30.847 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:30.941 WARNING Plugin.processLogQueue [Chart Mini - Trend Fridge] Error downloading CSV data: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Fridge Target Temp.csv'. See plugin log for more information.
2019-04-08 19:16:30.941 WARNING Plugin.processLogQueue [Chart Mini - Trend Fridge] Error downloading CSV data: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Kitchen - Fridge Temp Trend.csv'. See plugin log for more information.
2019-04-08 19:16:30.941 WARNING Plugin.processLogQueue [Chart Mini - Trend Fridge] chart updated with errors. See plugin log for more information.
2019-04-08 19:16:31.005 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:31.005 CRITICAL Plugin.pluginErrorHandler !!! Traceback (most recent call last):
2019-04-08 19:16:31.006 CRITICAL Plugin.pluginErrorHandler !!! File "plugin.py", line 4624, in get_data
2019-04-08 19:16:31.006 CRITICAL Plugin.pluginErrorHandler !!! with open(data_source, "r") as data_file:
2019-04-08 19:16:31.006 CRITICAL Plugin.pluginErrorHandler !!! IOError: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Target Temp For Bedrooms.csv'
2019-04-08 19:16:31.006 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:31.014 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:31.014 CRITICAL Plugin.pluginErrorHandler !!! Traceback (most recent call last):
2019-04-08 19:16:31.014 CRITICAL Plugin.pluginErrorHandler !!! File "plugin.py", line 4624, in get_data
2019-04-08 19:16:31.015 CRITICAL Plugin.pluginErrorHandler !!! with open(data_source, "r") as data_file:
2019-04-08 19:16:31.015 CRITICAL Plugin.pluginErrorHandler !!! IOError: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Trend - Temp Guest Bedroom.csv'
2019-04-08 19:16:31.015 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:31.118 WARNING Plugin.processLogQueue [Chart Mini - Trend Guest Bedroom] Error downloading CSV data: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Target Temp For Bedrooms.csv'. See plugin log for more information.
2019-04-08 19:16:31.119 WARNING Plugin.processLogQueue [Chart Mini - Trend Guest Bedroom] Error downloading CSV data: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Trend - Temp Guest Bedroom.csv'. See plugin log for more information.
2019-04-08 19:16:31.119 WARNING Plugin.processLogQueue [Chart Mini - Trend Guest Bedroom] chart updated with errors. See plugin log for more information.
2019-04-08 19:16:46.325 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:46.326 CRITICAL Plugin.pluginErrorHandler !!! Traceback (most recent call last):
2019-04-08 19:16:46.326 CRITICAL Plugin.pluginErrorHandler !!! File "plugin.py", line 4624, in get_data
2019-04-08 19:16:46.327 CRITICAL Plugin.pluginErrorHandler !!! with open(data_source, "r") as data_file:
2019-04-08 19:16:46.327 CRITICAL Plugin.pluginErrorHandler !!! IOError: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Target Temperature.csv'
2019-04-08 19:16:46.327 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:46.337 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:46.337 CRITICAL Plugin.pluginErrorHandler !!! Traceback (most recent call last):
2019-04-08 19:16:46.338 CRITICAL Plugin.pluginErrorHandler !!! File "plugin.py", line 4624, in get_data
2019-04-08 19:16:46.338 CRITICAL Plugin.pluginErrorHandler !!! with open(data_source, "r") as data_file:
2019-04-08 19:16:46.338 CRITICAL Plugin.pluginErrorHandler !!! IOError: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Hallway Temp Trend.csv'
2019-04-08 19:16:46.339 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:46.436 WARNING Plugin.processLogQueue [Chart Mini - Trend Hallway] Error downloading CSV data: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Target Temperature.csv'. See plugin log for more information.
2019-04-08 19:16:46.436 WARNING Plugin.processLogQueue [Chart Mini - Trend Hallway] Error downloading CSV data: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Hallway Temp Trend.csv'. See plugin log for more information.
2019-04-08 19:16:46.436 WARNING Plugin.processLogQueue [Chart Mini - Trend Hallway] chart updated with errors. See plugin log for more information.
2019-04-08 19:16:46.500 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:46.501 CRITICAL Plugin.pluginErrorHandler !!! Traceback (most recent call last):
2019-04-08 19:16:46.501 CRITICAL Plugin.pluginErrorHandler !!! File "plugin.py", line 4624, in get_data
2019-04-08 19:16:46.501 CRITICAL Plugin.pluginErrorHandler !!! with open(data_source, "r") as data_file:
2019-04-08 19:16:46.501 CRITICAL Plugin.pluginErrorHandler !!! IOError: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Target Temperature.csv'
2019-04-08 19:16:46.502 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:46.508 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:46.509 CRITICAL Plugin.pluginErrorHandler !!! Traceback (most recent call last):
2019-04-08 19:16:46.509 CRITICAL Plugin.pluginErrorHandler !!! File "plugin.py", line 4624, in get_data
2019-04-08 19:16:46.509 CRITICAL Plugin.pluginErrorHandler !!! with open(data_source, "r") as data_file:
2019-04-08 19:16:46.510 CRITICAL Plugin.pluginErrorHandler !!! IOError: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Lounge Temp Trend.csv'
2019-04-08 19:16:46.510 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:46.615 WARNING Plugin.processLogQueue [Chart Mini - Trend Lounge] Error downloading CSV data: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Target Temperature.csv'. See plugin log for more information.
2019-04-08 19:16:46.616 WARNING Plugin.processLogQueue [Chart Mini - Trend Lounge] Error downloading CSV data: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Lounge Temp Trend.csv'. See plugin log for more information.
2019-04-08 19:16:46.616 WARNING Plugin.processLogQueue [Chart Mini - Trend Lounge] chart updated with errors. See plugin log for more information.
2019-04-08 19:16:46.680 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:46.681 CRITICAL Plugin.pluginErrorHandler !!! Traceback (most recent call last):
2019-04-08 19:16:46.681 CRITICAL Plugin.pluginErrorHandler !!! File "plugin.py", line 4624, in get_data
2019-04-08 19:16:46.681 CRITICAL Plugin.pluginErrorHandler !!! with open(data_source, "r") as data_file:
2019-04-08 19:16:46.682 CRITICAL Plugin.pluginErrorHandler !!! IOError: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Target Temp For Bedrooms.csv'
2019-04-08 19:16:46.682 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:46.688 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:46.689 CRITICAL Plugin.pluginErrorHandler !!! Traceback (most recent call last):
2019-04-08 19:16:46.689 CRITICAL Plugin.pluginErrorHandler !!! File "plugin.py", line 4624, in get_data
2019-04-08 19:16:46.689 CRITICAL Plugin.pluginErrorHandler !!! with open(data_source, "r") as data_file:
2019-04-08 19:16:46.689 CRITICAL Plugin.pluginErrorHandler !!! IOError: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Master Bedroom Temp Trend.csv'
2019-04-08 19:16:46.690 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:46.783 WARNING Plugin.processLogQueue [Chart Mini - Trend Master Bedroom] Error downloading CSV data: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Target Temp For Bedrooms.csv'. See plugin log for more information.
2019-04-08 19:16:46.783 WARNING Plugin.processLogQueue [Chart Mini - Trend Master Bedroom] Error downloading CSV data: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Master Bedroom Temp Trend.csv'. See plugin log for more information.
2019-04-08 19:16:46.783 WARNING Plugin.processLogQueue [Chart Mini - Trend Master Bedroom] chart updated with errors. See plugin log for more information.
2019-04-08 19:16:46.848 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:46.848 CRITICAL Plugin.pluginErrorHandler !!! Traceback (most recent call last):
2019-04-08 19:16:46.849 CRITICAL Plugin.pluginErrorHandler !!! File "plugin.py", line 4624, in get_data
2019-04-08 19:16:46.849 CRITICAL Plugin.pluginErrorHandler !!! with open(data_source, "r") as data_file:
2019-04-08 19:16:46.849 CRITICAL Plugin.pluginErrorHandler !!! IOError: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Target Temp For Bedrooms.csv'
2019-04-08 19:16:46.849 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:46.856 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:46.856 CRITICAL Plugin.pluginErrorHandler !!! Traceback (most recent call last):
2019-04-08 19:16:46.856 CRITICAL Plugin.pluginErrorHandler !!! File "plugin.py", line 4624, in get_data
2019-04-08 19:16:46.856 CRITICAL Plugin.pluginErrorHandler !!! with open(data_source, "r") as data_file:
2019-04-08 19:16:46.857 CRITICAL Plugin.pluginErrorHandler !!! IOError: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Trend - Temp Molly.csv'
2019-04-08 19:16:46.857 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:46.956 WARNING Plugin.processLogQueue [Chart Mini - Trend Molly Bedroom] Error downloading CSV data: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Target Temp For Bedrooms.csv'. See plugin log for more information.
2019-04-08 19:16:46.957 WARNING Plugin.processLogQueue [Chart Mini - Trend Molly Bedroom] Error downloading CSV data: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Trend - Temp Molly.csv'. See plugin log for more information.
2019-04-08 19:16:46.957 WARNING Plugin.processLogQueue [Chart Mini - Trend Molly Bedroom] chart updated with errors. See plugin log for more information.
2019-04-08 19:16:47.029 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TRACEBACK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:47.030 CRITICAL Plugin.pluginErrorHandler !!! Traceback (most recent call last):
2019-04-08 19:16:47.030 CRITICAL Plugin.pluginErrorHandler !!! File "plugin.py", line 4624, in get_data
2019-04-08 19:16:47.030 CRITICAL Plugin.pluginErrorHandler !!! with open(data_source, "r") as data_file:
2019-04-08 19:16:47.031 CRITICAL Plugin.pluginErrorHandler !!! IOError: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Trend - Temp Outdoors.csv'
2019-04-08 19:16:47.031 CRITICAL Plugin.pluginErrorHandler !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2019-04-08 19:16:47.131 WARNING Plugin.processLogQueue [Chart Mini - Trend Outdoor Temp] Error downloading CSV data: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7.2/Logs/com.fogbert.indigoplugin.matplotlib/Trend - Temp Outdoors.csv'. See plugin log for more information.
2019-04-08 19:16:47.131 WARNING Plugin.processLogQueue [Chart Mini - Trend Outdoor Temp] chart updated with errors. See plugin log for more information.
IndigoSam wrote:Deselecting lines - line chart.
Dave,
It looks like the settings are not updated when a line is deselected. For example, if I have a 3 line chart and later decide to remove a line, say line 2, that line carries on being plotted. Selecting line 2 again later and all the original details for that line come back, rather than being blank.
Sam.
v0.8.06
- Adds section text and tooltips to show/hide controls for bar, line, scatter, and weather devices.
v0.8.05
- At plugin startup, iterate through all CSV Engine devices, audit CSV files, and create any missing ones.
v0.8.04
- Traps OSError when plugin cannot connect to the CSV storage location.
- Refactors battery charting code.
v0.8.03
- Highlights battery devices with dead batteries (level of 0) by coloring the label using the warning color setting.
v0.8.02
- Adds control to vary the number of legend columns for bar, line and scatter charts.
- UI Refinements
