Temp Sensor- Show temp in Indigo
Sat Apr 06, 2019 6:14 am
Busta999 offline
Hi
Anyone know how to get the temp to show in the Indigo device interface.
The Temp is showing in the details but just odd it doesn't show up.
Any thoughts would be useful - the other 6 Oregon sensors show up fine.
RFXCOM Temp Sensor.jpeg (80.2 KiB) Viewed 3202 times
Not a critical problem just odd.
Sat Apr 06, 2019 8:02 am
Re: Temp Sensor- Show temp in Indigo
Is this the RFXCOM module or native Indigo device?
The author needs to set which of the states is the display state; given its a Tenperature Sensor Device Type, it would be common sense to use the temperature state as the display state.
Sat Apr 06, 2019 9:02 am
The issue is that the temp sensor in the plugin also has a humidity property.
So the Plugin does not know which one to pick. You need to select that in device edit. That should be done when you create the device.
Sat Apr 06, 2019 10:18 am
[MODERATOR NOTE] moved to the correct forum.
Sat Apr 06, 2019 1:11 pm
Busta999 offline
Ok not getting this.
It is setup exactly like the other identical sensor (well appear identical)
Temp Sensor 2.jpeg (187.84 KiB) Viewed 3124 times
I suspect I need to update the RFXCOM device
Sun Apr 07, 2019 9:51 am
Busta999 offline
Looks like a plugin issue.
I have updated to the latest version 2.1.16.
It totally ignores the Show in Sensor value - currently set to Temperature with Display = Temp
The actual display is always shown as 0 regardless of the actual temperature.
Nothing I can do :-(
Sun Apr 07, 2019 9:54 am
It might be that your device uses old props. Try to
Change id of existing device to eg 999
create a new device with correct id
Edit new device and set correct prop
to show in status column.
If this does not work you can switch back.
Sun Apr 07, 2019 10:01 am
Busta999 offline
Bingo!!!!!!
Reset it
Set Display to Temp and Show in Sensor Value set to Temperature
Did it
I have 6 other Oregons never done this before
Many thanks......
Appreciated
