zw098 and Set LED greyed out?
Sun Jan 20, 2019 5:27 pm
dlleon offline
Re: zw098 and Set LED greyed out?
This is major progress.
Looks like the rainbow fast starts at red and fades to yellow then to green (takes a few minutes to be noticeable change)
Rainbow slow appears to be the same speed as rainbow fast
The first Choose Colours starts at yellow, and after a minute turns to green then another minute to blue, etc.
The second Choose Colours appears to do the same. at the same speed
The all options function is pretty freaking neat, I'm still toying with it.
I'd like to use this as an alert (for example, it can flash blue if it's raining, or red if the alarm is armed, etc.)
Sun Jan 20, 2019 5:30 pm
dlleon offline
The all options function is pretty freaking neat, I'm still toying with it. The functions appear to work properly, though I don't really know what I'm doing.
Sun Jan 20, 2019 5:37 pm
GlennNZ offline
Great to hear that all is working well.
Two flash you’ll probably need two colours - see my example of red to blue flashing. Although on second thoughts may work with just one Colour as per my example as fades off and the fades on... I’ll test when can,
The colour chooser options - should only show you selected colours (can hold down command key to select multiple colours)
Glenn
