Create action from trigger
Thu Nov 01, 2018 9:09 am
MarcoGT offline
Hi all,
at the moment I have a lot of triggers which contain a lot of actions.
For example:
Trigger (Good Night) on variable change --> conditions (if any) --> list of actions (action1, action2 and so on).
I have started to clean up and do something like this:
Trigger (Good Night) on variable change --> conditions (if any) --> "Good Night Action" (which actually contains the previous action1, action2) and so on).
But, as you can understand, this is a manual work which can leads to error hard to identify.
Wouldn't be possible to create an action group from those actions?
Marco
Thu Nov 01, 2018 9:13 am
MarcoGT offline
Re: Create action from trigger
Ok, I saw that someone had the same need few years ago
viewtopic.php?f=81&t=11600&p=76451&hilit=export+actions#p76451
Thu Nov 01, 2018 9:15 am
MarcoGT offline
Thu Nov 01, 2018 2:17 pm
If you're really brave, you could edit the Indigo XML file and copy those sections around.
Make a backup first...
Fri Nov 02, 2018 12:35 am
MarcoGT offline
Yeah, that's also an idea :D
Sun Dec 23, 2018 9:48 pm
peszko offline
Id also like to have option of copying trigger actions to action group. Now that I'm starting to use z-wave, I want to u se action groups more since insteon scenes will not cover all my devices now. Plus, I think having most of the login in one place will make it easier to maintain.
Mon Dec 24, 2018 10:48 am
That one is already on the feature request list, but good suggestion.
