Got as far as getting it communicating, I think, with some things but have no idea how to setup devices for triggers.
I see this in the log:
- Code: Select all
RFXCOM initializing communication on port /dev/cu.usbserial-A12HDS42 at speed 38400
RFXCOM connected to RFXtrx 433.92 MHz, firmware version 24
RFXCOM currently enabled receiver protocols: Oregon Scientific, X10
RFXCOM enabling receiver protocols: Undecoded
RFXCOM stored changed settings into non-volatile memory
RFXCOM Error unknown device detected (id = 26, type = 86). Select a Wind meter from the list of devices
RFXCOM Error unknown device detected (id = 971, type = 82). Select a Temperature sensor (with humidity) from the list of devices
RFXCOM Error unknown device detected (id = 1549, type = 82). Select a Temperature sensor (with humidity) from the list of devices
RFXCOM Error unknown device detected (id = 122, type = 85). Select a Rain sensor from the list of devices
RFXCOM Error unknown device detected (id = 295, type = 82). Select a Temperature sensor (with humidity) from the list of devices
RFXCOM Error unknown device detected (id = 1063, type = 82). Select a Temperature sensor (with humidity) from the list of devices
RFXCOM Error unknown device detected (id = 1521, type = 82). Select a Temperature sensor (with humidity) from the list of devices
Seems to setup a device you need the channel number which I don't see in the log...maybe the id?
Also I have the X10 protocol activated but when pressing buttons on my Palm remotes nothing shows in the log.
Any help greatly appreciated!
Carl
