I'm getting the exact same error (Indigo 6, OS X 10.12.6). I suspect some OS update or something broke it, but I don't know where to look. Any advice would be greatly appreciated!
Alexander
/usr/local/bin/mosquitto_pub
dillwishlist wrote:I'm getting the exact same error (Indigo 6, OS X 10.12.6). I suspect some OS update or something broke it, but I don't know where to look. Any advice would be greatly appreciated!
Alexander
Topolino wrote:This thing is really disappointing. It only sproadically receives updates, and when it does, it isn't able to do anything with them. But hey, it fits very well with the sorry state of other buggy beta plugins on this platform.
1522203353: New connection from 172.17.0.1 on port 1883.
1522203353: New client connected from 172.17.0.1 as mosqpub|89005-lhs.local (c1, k60).
1522203353: Client mosqpub|89005-lhs.local disconnected.
1522203354: New connection from 172.17.0.1 on port 1883.
1522203354: New client connected from 172.17.0.1 as mosqsub|89006-lhs.local (c1, k60).
Enabling plugin "mqttGateway 1.2.0"
Starting plugin "mqttGateway 1.2.0" (pid 89442)
mqttGateway mqtt debugging enabled
Started plugin "mqttGateway 1.2.0"
mqttGateway Debug startup called
mqttGateway Debug io_queue_reader started
mqttGateway Debug mqtt_listener for localhost:test started with pid: 89446
mqttGateway Debug mqtt_listener for 10.0.1.7:test started with pid: 89447
mqttGateway Debug Starting ConcurrentThread ... Active listener threads = 2
mosquitto_pub -h 10.0.1.7 -t test -m on
mosquitto_pub -h 10.0.1.7 -t test -m hello
Exception in thread Thread-1:
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/threading.py", line 810, in __bootstrap_inner
self.run()
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/threading.py", line 763, in run
self.__target(*self.__args, **self.__kwargs)
File "plugin.py", line 244, in io_queue_reader
except e:
NameError: global name 'e' is not defined
mqttGateway Debug io_queue_reader:localhost:test: hello
mqttGateway mqttTest received mqtt message from test
mqttGateway Debug will put data into: 946916136
craigsheppard wrote:If I then edit the mqtt Gateway device to write to a variable, the plugin becomes unresponsive after the first message, and I have to reload it to get it to work again.
Am I doing something wrong? Is there a better way to access these messages?
