11.2.5 No Response
Wed Jan 24, 2018 8:51 pm
11.2.5 No Response
I've updated my iPad and iPhone to 11.2.5 and now I'm seeing No Response on all devices.
Can anyone else confirm that HBB works with 11.2.5? I've reloaded HBB with no change. I've restarted Indigo Server, no change. I've restarted the Server machine, no change.
Unsure how to troubleshoot further.
Wed Jan 24, 2018 9:27 pm
rehafer offline
Re: 11.2.5 No Response
I have 11.2.5 and my devices are responding. I’ve been on the Beta awhile, so my memory isn’t precise, but I believe I had to change the User Name in HBB about the time I started the Beta; that was around the time I received my iPhone X, so I can’t remember the actual cause.
Wed Jan 24, 2018 9:32 pm
Colorado4Wheeler offline
What did you upgrade from? There was a change in 11 that required an updated Node library, but there should be a need to change your username unless they did something to HomeKit - which they may because last weekend I lost all communications and had to remove and readd again, I think there might have been a big change in HomeKit recently.
Thu Jan 25, 2018 8:23 am
I do incremental upgrades, so 11.2.whatever was before this.
Now that I think about it, the iPad is on the beta releases, so it's not on 11.2.5. It's on something more.
I upgraded tvOS last night, and no change yet.
Thu Jan 25, 2018 8:31 am
I do think it's possibly an IOS change because I haven't lost my entire HB config for probably a year and all of the sudden it was shot this pack weekend, which correlated to updating the IOS on my pad.
Thu Jan 25, 2018 5:25 pm
I'm embarrassed to admit that I don't know which username/password you're talking about changing to make HBB start working again.
HBB manages my homebridge. It isn't a separate install.
Thu Jan 25, 2018 5:42 pm
That would only be needed if you removed your HB server from HomeKit and it wasn't seen anymore. If things are still not working just remove the HBB server from HomeKit and re-add it.
Thu Jan 25, 2018 6:41 pm
OK, removed and re-added.
I get the whole list of devices scrolling in green in the log, then
   EPS - Homebridge Buddy          EPS - Homebridge Buddy is loaded and ready to use
But I think there's usually a "The home bridge server is now up" notice, or something to that effect, and I haven't seen that.
when I look at the HB log I see
   EPS - Homebridge Buddy          [2018-1-25 19:36:25] Loaded plugin: homebridge-indigo
[2018-1-25 19:36:25] Registering platform 'homebridge-indigo.Indigo'
[2018-1-25 19:36:25] ---
[2018-1-25 19:36:25] Loaded plugin: homebridge-itunes
[2018-1-25 19:36:25] Registering platform 'homebridge-itunes.iTunes'
[2018-1-25 19:36:25] Loaded config.json with 0 accessories and 2 platforms.
[2018-1-25 19:36:25] Loading 2 platforms...
[2018-1-25 19:36:25] [Two Dog Hill] Initializing Indigo platform...
[2018-1-25 19:36:25] [Two Dog Hill] Indigo base URL is http://127.0.0.1:8176
[2018-1-25 19:36:25] Initializing iTunes platform...
[2018-1-25 19:36:25] Loading 0 accessories...
[2018-1-25 19:36:25] [Two Dog Hill] Indigo request: http://127.0.0.1:8176/devices.json/
And all indigo devices show as Not responding in the Home app. My Nanoleaf devices do appear active though--they're HK native.
Thu Jan 25, 2018 6:48 pm
If you removed and then re-added then that is a valid test that it's working all the way through because otherwise you wouldn't see the server - and in order to re-add you also have to re-add each device to the respective rooms. You'll know if HBB is running because it will show as ON in Indigo, plus if it isn't then you'll typically see a quit statement at the end of that HB log. You might have something else happening if you see the devices and then immediately they all go "not responding".
Thu Jan 25, 2018 7:04 pm
D'oh!
I had a virtual device and an action group called "Listen to Music" and had both of them selected to include. Looks like that was the problem.
I had to "show Homebridge Log" more than once to get the error to show up. But now I get
    │ NN-NN-NNN │
events.js:182
      throw er; // Unhandled 'error' event
Error: listen EADDRINUSE :::51826
    at Object._errnoException (util.js:1041:11)
    at _exceptionWithHostPort (util.js:1064:20)
    at Server.setupListenHandle [as _listen2] (net.js:1322:14)
    at listenInCluster (net.js:1370:12)
    at Server.listen (net.js:1466:7)
    at EventedHTTPServer.listen (/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin/Contents/Server Plugin/bin/hb/node-v8.4.0-darwin-x64/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/util/eventedhttp.js:60:19)
    at HAPServer.listen (/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin/Contents/Server Plugin/bin/hb/node-v8.4.0-darwin-x64/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/HAPServer.js:158:20)
    at Bridge.Accessory.publish (/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin/Contents/Server Plugin/bin/hb/node-v8.4.0-darwin-x64/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Accessory.js:557:16)
    at Server._publish (/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin/Contents/Server Plugin/bin/hb/node-v8.4.0-darwin-x64/lib/node_modules/homebridge/lib/server.js:114:16)
    at Server.<anonymous> (/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin/Contents/Server Plugin/bin/hb/node-v8.4.0-darwin-x64/lib/node_modules/homebridge/lib/server.js:372:14)
Looks like a restart of the box cleared this. BUUUUUT....
Home app still says no Indigo accessories responding.
Thu Jan 25, 2018 7:13 pm
Wait.
Was I supposed to remove the HB device from Indigo, or the home from the Home app?
EDIT: I think I got it. Home finally saw the bridge, and now I'm re-configuring each device. A pain, but the new HK in iOS makes it easier than it was.
Last edited by Different Computers on Thu Jan 25, 2018 7:30 pm, edited 1 time in total.
Thu Jan 25, 2018 7:17 pm
Nope, remove the Homebridge Buddy server from HomeKit, not Indigo and not removing your home from HomeKit.
