posted v 7-4-39
added:
.-- minor reduction in writes to indigo (for the state image )
-- now supports Fast Roaming option: https://help.ubnt.com/hc/en-us/articles/115004662107-UniFi-Fast-Roaming
recognized besides "Zero-HandoffRoaming"
When devices switch between access points the plugin recognizes it for both options
Zero Handoff started to deteriorate in my environment. After I switched to FastRoaming the performance (throughput) is much better. The switching time is almost not noticeable. I can walk through the house with wifi calling and switch from one AP to the next without loosing the connection. Even as they are on different Wifi bands. You might hear a little "scratching" noise for ~ 0.5 secs.
