Hi All,
I have completed the Panasonic Viera TV Plugin with all of the apps and commands (over 80 in total) included for IP control of Viera TV's (since 2012). If the Panasonic2 app works, so should the plugin.
Completed version here (v0.1.2) https://github.com/Mat-C-uk/Panasonic-Remote
Not all commands work on all TV's.
The power toggle will put the TV in standby. For those with WoL (this needs to be available in your country/region/state and enabled on your TV) you will need to enter the mac address in the device settings.
Instructions.
Enable remote control (if not already done) from the TV's Network menu - TV Remote app settings
Download and install plugin
Create a new device (supports multiple devices)
Select "type": Panasonic Network Remote
Select "Model"; Panasonic TV
Input the TV IP Address - I would highly recommend fixing the ip address of the TV
Input the mac address if you have WoL
Name the device.
You should now be able to add actions (either groups or on control pages) and trigger events.
The device has three properties:
State - either off, standby or on
Mute - on/off
Volume - shows the current or last volume of the TV
Any problems, please shout, and suggestions welcome.
version 0.1.2 added option to update volume from variable
I have a request for channel monitoring which I will look at shortly.
