Hi, I have a device being listed in my logs that does not exist under devices. I have not installed any new devices and I'm getting a "K13" on and off received message". I just checked another log from the 14th and it shows the screen cap below. None of those devices exist in Indigo.
I have a W800RF32 USB receiver that has worked fine for a long time before this. No serial devices or USBs are in the network setup.
I suppose someone nearby could be using X10 but it would seem unlikely. That said, X10 stuff has still been going off at weird intervals. Alarms, water sensors, you name it. For a while WS13A's were primarily having the problems of not responding. I have also upgraded to Indigo v7.0.3. I mentioned in another post that I also upgraded to some Ubiquiti Unifi network equipment, but it is now on a different circuit and behind a filter. Could the access points be coincidentally sending the right sections of X10 code over the same frequency? Seems like it would be quite a coincidence.
How can I even trouble shoot this?
