Can you help me figure out the cause, thanks in advance for any help you can provide....
- Code: Select all
Sonos Error [Sat Nov 19 06:28:35 2016] ZonePlayer: Sonos Play 1 in Bath Room has fallen off the network.
Sonos Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 47, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 344, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 367, in checkEvents
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 453, in socoTimeout
TypeError: not enough arguments for format string
Sonos Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
