Ok got it. Will check if a % will screw it up.
15. aug. 2016, 17.30.17
Indigo Cocoa client connected
Stopping plugin minMax (pid 444)
minMax stopConcurrentThread called 1
minMax stopConcurrentThread called 2
Stopped plugin minMax
Upgrading plugin minMax to newer version 0.4.9 (previous version moved to trash)
Loading plugin "minMax 0.4.9"
Starting plugin "minMax 0.4.9" (pid 70430)
Started plugin "minMax 0.4.9"
minMax minMax plugin v 0.4.9 starting
minMax Configuration: Dev-Name DevID State ignoreLess ignoreGreater tracking
minMax WStemp ; 1897874033; value -9876543210 9876543210 thisDay_Max thisDay_Min
minMax Temperatur bad ; 1694508583; sensorValue -9876543210 9876543210 thisDay_Max thisDay_Min
minMax WStrykk ; 734999929 ; value -9876543210 9876543210 thisDay_Max thisDay_Min
minMax WSbatteri ; 1302159896; value -9876543210 9876543210 thisDay_Max thisDay_Min
minMax Termostat kjeller ; 91673998 ; temperatureInput1 -9876543210 9876543210 thisDay_Max thisDay_Min
minMax TempStue ; 771245244 ; value 3 9876543210 thisDay_Max thisDay_Min
minMax TempUte ; 1243658944; value -9876543210 9876543210 lastMonth_Max lastMonth_Min thisMonth_Max thisMonth_Min thisDay_Max thisDay_Min thisWeek_Max thisWeek_Min
minMax WSdugg ; 1376864708; value -9876543210 9876543210 thisDay_Max thisDay_Min
minMax Tempsensor gang 1.etg; 164175316 ; sensorValue -9876543210 9876543210 thisDay_Max thisDay_Min
minMax WSluftfuktighet ; 386320416 ; value -9876543210 9876543210 thisDay_Max thisDay_Min
minMax WSvind ; 588887444 ; value -9876543210 9876543210 lastMonth_Max lastMonth_Min thisMonth_Max thisMonth_Min thisDay_Max thisDay_Min thisWeek_Max thisWeek_Min
minMax error in Line '574' ; error='unsupported operand type(s) for +=: 'float' and 'str''
minMax ('x', '2016-08-12-22:39:07')
minMax x
minMax x
minMax ('x', '2016-08-12-23:15:07')
minMax x
minMax x
minMax ('x', '2016-08-12-23:58:00')
minMax x
minMax x
minMax x
minMax x
minMax x
minMax x
minMax x
minMax x
minMax x
minMax x
minMax x
minMax x
minMax x
minMax x
minMax x
minMax x
minMax x
minMax x
minMax x
minMax x
-17:01:19;0.3541
2017-02-08-17:04:46;
2017-02-08-17:04:48;
2017-02-08-17:05:07;
2017-02-08-17:06:22;
2017-02-08-17:11:22;0.364
2017-02-08-17
minMax
minMax ['2017-02-08-16:31:02', '0.3414']
minMax variName Power_Monitor_Freezer_accumEnergyTotal
minMax /usr/bin/sqlite3 -separator ";" '/Library/Application Support/Perceptive Automation/Indigo 7/logs/indigo_history.sqlite' "select strftime('%Y-%m-%d-%H:%M:%S',ts,'localtime'), curEnergyLevel from device_history_503227130 where ts > '2015-11-00 00:00:00';"
minMax 2017-02-08-16:31:02;1.1
2017-02-08-16:31:14;
2017-02-08-16:41:15;
2017-02-08-16:41:15;1.2
2017-02-08-16:51:17;
2017-02-08-17:01:19;
2017-02-08-17:04:46;400.3
2017-02-08-17:04:48;90.0
2017-02-08-17:05:07;99.2
2017-02-08-17:06:22;88.7
2017-02-08-17:11:22;86.3
2017-02-08-17:21:24;
minMax
minMax ['2017-02-08-16:31:02', '1.1']
minMax variName Power_Monitor_Freezer_curEnergyLevel
minMax /usr/bin/sqlite3 -separator ";" '/Library/Application Support/Perceptive Automation/Indigo 7/logs/indigo_history.sqlite' "select strftime('%Y-%m-%d-%H:%M:%S',ts,'localtime'), sensorValue from device_history_84216111 where ts > '2015-11-00 00:00:00';"
minMax 2017-02-13-20:56:12;
2017-02-13-21:37:53;0
2017-02-13-21:37:53;19.7
2017-02-13-21:41:54;19.6
2017-02-13-21:54:54;19.5
2017-02-13-22:10:30;19.4
2017-02-13-22:11:09;19.5
2017-02-13-22:14:24;19.4
2017-02-13-22:46:54;19.5
2017-02-13-22:47:33;19.4
2017-02-13-22:48:12;19.5
2017-02-13-22:50:09;19.4
2017-02
minMax
minMax ['2017-02-13-20:56:12', '']
minMax variName Master_Bedroom_Temp_Sensor_sensorValue
minMax /usr/bin/sqlite3 -separator ";" '/Library/Application Support/Perceptive Automation/Indigo 7/logs/indigo_history.sqlite' "select strftime('%Y-%m-%d-%H:%M:%S',ts,'localtime'), sensorValue from device_history_1758125628 where ts > '2015-11-00 00:00:00';"
minMax 2017-02-08-16:31:01;-23.5
2017-02-08-16:31:15;-23.6
2017-02-08-16:32:51;-23.7
2017-02-08-16:34:27;-23.6
2017-02-08-16:36:51;-23.5
2017-02-08-16:37:39;-23.4
2017-02-08-16:39:15;-23.3
2017-02-08-16:40:03;-23.2
2017-02-08-16:40:51;-23.1
2017-02-08-16:41:39;-23.0
2017-02-08-16:42:27;-22.9
2017-02-08-16:
minMax
minMax ['2017-02-08-16:31:01', '-23.5']
minMax variName Kitchen_Freezer_-_Temp_Sensor_1_-_Corrected_sensorValue
Starting plugin "minMax 7.5.2" (pid 89769)
Started plugin "minMax 7.5.2"
minMax minMax plugin v 7.5.2 starting
minMax Master Bedroom Temp Sensor; 84216111 ; sensorValue -9876543210 9876543210
minMax Power Monitor Freezer; 503227130 ; accumEnergyTotal -9876543210 9876543210
minMax Power Monitor Freezer; 503227130 ; curEnergyLevel -9876543210 9876543210
minMax Kitchen Freezer - Temp Sensor 1 - Corrected; 1758125628; sensorValue -9876543210 9876543210
Schedule Update Greenwave Power Status
