It looked promising at first, but I'm still unable to change any of the notifications send by "beecon". Even with the "enable beecon" setting switch off, I was able to receive URL POST notifications but the plugin recognises it has been send by an Beecon App and refuses to read the custom url. I believe Beecon sends default notifications (sender/location/action) which you can't alter via the URL string.
url string send from an location called Hometest1
http://server:6192/?sender=test?locatio ... tion=enter I get
Beacon Debug New httpHandler thread: Thread-49, total threads: 3
Beacon Debug Received HTTP POST
Beacon Debug Sending HTTP 200 response
Beacon Debug User-agent: Beecon/7.4.3 CFNetwork/758.2.8 Darwin/15.0.0, Content-type: application/x-www-form-urlencoded
Beacon Debug Data (UTF-8 decoded): region=Hometest1&action=enter
Beacon Debug Recognised Beecon
Beacon Debug parseResult called
Beacon Debug Found userLocation device: Beecon@@Hometest1
Beacon Debug deviceUpdate called
Beacon Enter location notification received from sender/location beecon@@hometest1
Beacon Debug triggerEvent called
The location and action are correct by default, my problem is the sender ("Beecon@@". This field is always beecon and I can't change this via any url string or via custom application with a different field like (sender field = sender_custom with url including ?sender_custom=test).
I can get around it by making a different locations for me and my wife (home_wife and home_me) but it would be nice if I could override the sender field in beecon. Thanks for your help
