rhanson wrote:Just wanted to chime in and say thanks for writing this plugin. I'm using it with the new T7850 version (replaces the 5800+Wifi key combo). Works great!
jshields wrote:Well, it's worse than we thought. If I issue a command http://192.168.1.95 I get a response {"api_ver":5,"type":"residential"}
However issuing the command http://192.168.1.95/query/info causes the thermostat to crash and restart.
Sounds like Venstar needs to get their act together and fix the firmware (Mine is: VH 4.08-1A).
Jerry
jshields wrote:I just send a support request to Venstar with our results and a request for their help resolving this.
jshields wrote:The response from Venstar on the crash/reboot problems was particularly unhelpful. They seemed to totally ignore the issue of the crashing on that info command and only stated that there were no firmware differences between your wifi keys. I guess I'll try them again.
jshields wrote:In any case If I enable your plugin I get all those Python errors and nothing works on the Indigo side for the thermostat. I suppose it might be a difference in the firmware in the thermostat itself since mine has the wifi built in rather than external so it may respond differently, even though I think it shouldn't be that case.
jshields wrote:Is it possible that the python in 10.10.5 is different from what you are running? Also, this is a Mac OS Server, so I suppose that could be part of the difference.
I'm not a python person so I'm not the best to debug that level of thing.
jshields wrote:Is there any other information I can gather for you?
jshields wrote:Could you make a debug version of your plugin with some logging so we can see exactly where things are working vs failing?
{"name":"Original","mode":1,"state":0,"fan":0,"fanstate":0,"tempunits":0,"schedule":0,"schedulepart":255,"away":0,"spacetemp":72.0,"heattemp":70.0,"cooltemp":79.0,"cooltempmin":35.0,"cooltempmax":99.0,"heattempmin":35.00,"heattempmax":99.0,"hum":0,"hum_setpoint":27,"dehum_setpoint":25,"hum_active":77,"setpointdelta":3.0,"availablemodes":0}
http://192.168.1.95/query/sensors
{"sensors":[{"name":"Thermostat","temp":72.0,"hum":27},{"name":"Remote","temp":0.0}]}
http://192.168.1.95/query/alerts
{"alerts":[{"name":"Air Filter","active":false},{"name":"UV Lamp","active":false},{"name":"Service","active":false}]}
http://192.168.1.95/query/runtimes
