HKLS Startup Errors
Posted: Fri Jun 09, 2023 4:28 pm
Recently, I started seeing HLKS "hap pair verify" errors at plugin startup. There is one of these for each of my 3 HLKS accessory servers. Nevertheless, my HKLS devices all seem to be functioning normally. The errors are shown below. They repeat exactly each time I reload HKLS.
For reference, the device cited in the message, "10.10.10.190", is an Apple TV. Doesn't make any sense to me.
Does anyone know what this error means? Should I investigate more? Since there are no apparent failures... do I care?
Thanks for your help,
papamac
- Code: Select all
Reloading plugin "HomeKitLink Siri 0.6.5" using API v3.2
Stopping plugin "HomeKitLink Siri 0.6.5" (pid 35933)
HomeKitLink Siri Stopping accessory HomeKitLink Bridge 124078 on address 10.10.10.82, port 51826.
HomeKitLink Siri Stopping accessory HomeKitLink Bridge 815295 on address 10.10.10.82, port 51828.
HomeKitLink Siri Stopping accessory HomeKitLink Bridge 131595 on address 10.10.10.82, port 51827.
HomeKitLink Siri Closed the flux capacitor loop.
HomeKitLink Siri Completing full Bridge Shutdown ...
HomeKitLink Siri home-cameras-hklsBridge has completed full Bridge, Driver and Bridge Thread Shutdown.
HomeKitLink Siri home-lights-hklsBridge has completed full Bridge, Driver and Bridge Thread Shutdown.
HomeKitLink Siri home-security-hklsBridge has completed full Bridge, Driver and Bridge Thread Shutdown.
HomeKitLink Siri Shutting down HomeKitLink
Stopped plugin "HomeKitLink Siri 0.6.5"
Starting plugin "HomeKitLink Siri 0.6.5" (pid 35994)
HomeKitLink Siri
HomeKitLink Siri ================================================ Initializing New Plugin Session =================================================
HomeKitLink Siri Plugin name: HomeKitLink Siri
HomeKitLink Siri Plugin version: 0.6.5
HomeKitLink Siri Plugin ID: com.GlennNZ.indigoplugin.HomeKitLink-Siri
HomeKitLink Siri Indigo version: 2022.2.2
HomeKitLink Siri Python version: 3.10.2 (v3.10.2:a58ebcc701, Jan 13 2022, 14:50:16) [Clang 13.0.0 (clang-1300.0.29.30)]
HomeKitLink Siri Python Directory: /Library/Frameworks/Python.framework/Versions/3.10
HomeKitLink Siri
HomeKitLink Siri ================================================== End Initializing New Plugin ==================================================
Started plugin "HomeKitLink Siri 0.6.5"
HomeKitLink Siri Finding devices to publish to HomeKit Given Startup...
HomeKitLink Siri Starting accessory HomeKitLink Bridge 124078 on address 10.10.10.82, port 51826.
HomeKitLink Siri Error (hap_handler.py: Function: _pair_verify_two line: 547): Error : Message : ('10.10.10.190', 49230): Client c34d094c-3d40-420d-b6ad-15c8f1a5bfae attempted pair verify without being paired to HomeKitLink Bridge 124078 first.
HomeKitLink Siri Camera Thread is being spooled up to manage camera images
HomeKitLink Siri Starting accessory HomeKitLink Bridge 131595 on address 10.10.10.82, port 51827.
HomeKitLink Siri Error (hap_handler.py: Function: _pair_verify_two line: 547): Error : Message : ('10.10.10.190', 49231): Client c34d094c-3d40-420d-b6ad-15c8f1a5bfae attempted pair verify without being paired to HomeKitLink Bridge 131595 first.
HomeKitLink Siri Starting accessory HomeKitLink Bridge 815295 on address 10.10.10.82, port 51828.
HomeKitLink Siri Error (hap_handler.py: Function: _pair_verify_two line: 547): Error : Message : ('10.10.10.190', 49232): Client c34d094c-3d40-420d-b6ad-15c8f1a5bfae attempted pair verify without being paired to HomeKitLink Bridge 815295 first.
HomeKitLink Siri A total of 80 devices are currently selected to be published to HomeKit
HomeKitLink Siri 80 Home Kit Accessories are now Started..
papamac
