[ANSWERED]: Access Denied
Sun May 24, 2015 6:47 pm
noefresh offline
I'm trying to do some remote settings via Prism and I always get Access Denied via curl requests. What is the correct syntax for authenticated access via Prism?
UPDATE- I figured out the correct syntax to authenticate with Prism. What would I use in Curl to set a Binary Output on? (It's an Inteon i/o Linc.
Tue May 26, 2015 8:51 am
Re: Access Denied
On the Indigo RESTful Overview page search on EZIO to see the correct syntax. That EZIO example is for an EZIO8SA that has 8 outputs. The I/O-Linc has just a single output, so I'd ignore the 0,1 comma delimited list example and just use the set1 and clear1 syntax.
Wed May 27, 2015 5:09 pm
noefresh offline
Re: [ANSWERED]: Access Denied
Thanks Matt- will give it a try.
Tue Jun 02, 2015 10:49 am
afulki offline
Can you share t he syntax for calling? I'm trying to do it locally but get access denied.
I tried curl, ruby (with authenticated http etc.) I even tried turning off require password before starting the server, all to no avail.
Thanks in advance.
Gary
