I'm still having a big problem trying to get my Foscam FI8918 camera to work with Indigo. I installed the plugin and configured it. I set a trigger action for a motion detector changing state to send a command to turn off the IR illumination on the camera. Here's the error message I get:
May 1, 2015 11:06:20 PM
Received INSTEON "Motion Sensor - LR" on (button 1)
Trigger Test mot sen foscam
Trigger Motion Sensor LR Incr
Foscam Controller Debug irOff called
Foscam Controller Debug url xmitted:
http://10.0.1.84/decoder_control.cgi?us ... command=94 Foscam Controller Error Error in plugin execution ExecuteAction:
File "plugin.py", line 226, in irOff
File "plugin.py", line 67, in xmitToCamera
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 124, in urlopen
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 383, in open
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 401, in _open
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 361, in _call_chain
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 1141, in http_open
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/urllib2.py", line 1114, in do_open
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/httplib.py", line 950, in getresponse
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/httplib.py", line 390, in begin
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/httplib.py", line 354, in _read_status
<class 'httplib.BadStatusLine'>:
Any ideas on what could be going wrong?
