Hi Autolog,
(Thought it best to start a new thread on this, instead of using this one).
I've had it all setup for a couple of days now and it's been work as expected, albeit with one issue I can't figure out as to the cause. I mentioned in the other thread about how the boiler sometimes doesn't turn off when none of the Stella Zs are calling for heat. Yesterday all turned off as expected, but this morning I checked and about 30mins after the last one turned off, and after the room temp reached the requested temp from manually updating the remote thermostat, I noticed the boiler was still on and sending heat to the radiators that don't have Stella Zs attached.
Once again the only way to turn it off was to reload the plugin - and seeing as nothing was calling for heat, and there were no schedules, the boiler turned off.
In preparation I've created a trigger to reload the plugin, which I'm guessing I could use by setting up some variables to monitor if the Stella Zs are off. But I thought I would ask first if there is anything I could do on my end to see if I can solve this issue. Any logs I could generate that might be of use?
Much thanks in advance for your help.
Simon
