NOTE: Indigo 2.0.5 or greater, in tandem with the INSTEON PowerLinc V2 Controller 2414U is required to use the EZIO8SA
support wrote:The PowerLinc 2413 is okay to use with the EZIO8SA, but you also need the EZIO8SA's PLM (PowerLinc Modem). The EZIO8SA by itself doesn't have any INSTEON capability, so you connect it via a cable to its PLM to provide the INSTEON receiving/sending ability. So you will want to also buy the PLM that it comes with.
dstrickler wrote:I am thinking of replacing my house alarm system main unit with an EZIO85A to poll the triggers to know if they see open door magnetic switches etc.
PowerLinc Linking - received module button pressed from 28.AD.41
PowerLinc Linking - sending engine version request to 28.AD.41
PowerLinc Linking - received engine version 01 from 28.AD.41
PowerLinc Linking - sending id request for device information to 28.AD.41
PowerLinc Linking - received id request response from 28.AD.41
Error Linking - no match found for device type ID 810 with firmware version 9C
Error linking failed
2014-12-02 19:10:55.154 PowerLinc Linking - syncing PowerLinc links (address 20.F6.4A)
2014-12-02 19:10:55.154 PowerLinc Linking - . . adding: INSTEON plc link to controller 0C.B2.82, flags 03, group 01, data 00 00 FF
2014-12-02 19:10:55.195 PowerLinc Linking - . . adding: (not added -- probably already exists)
2014-12-02 19:10:55.196 PowerLinc Linking - PowerLinc links updated
2014-12-02 19:10:55.196 PowerLinc Linking - sync complete
2014-12-02 19:10:55.243 PowerLinc Linking - entered discovery linking mode (240 seconds)
2014-12-02 19:10:57.833 PowerLinc Linking - exited linking mode
2014-12-02 19:45:15.564 PowerLinc Linking - entered discovery linking mode (240 seconds)
2014-12-02 19:45:17.914 PowerLinc Linking - exited linking mode
2014-12-02 19:45:47.895 PowerLinc Linking - entered discovery linking mode (240 seconds)
2014-12-02 19:45:54.122 PowerLinc Linking - sending engine version request to 0C.B2.82
2014-12-02 19:45:54.451 PowerLinc Linking - received engine version 01 from 0C.B2.82
2014-12-02 19:45:54.451 PowerLinc Linking - sending id request for device information to 0C.B2.82
2014-12-02 19:45:55.442 PowerLinc Linking - received id request response from 0C.B2.82
2014-12-02 19:45:56.542 PowerLinc Linking - retrieving firmware version
2014-12-02 19:45:59.543 PowerLinc Linking - initializing remote device "Equip Closet EZIO6I Input Sensor" (address 0C.B2.82, firmware version 00)
2014-12-02 19:45:59.543 Error Linking - initializing failed
2014-12-02 19:45:59.544 Error linking failed
Korey wrote:Cant Link EZIO40, Seems indigo doesn't recognize it. Suggestions?
automaton wrote:I just had a (possibly) similar experience trying to sync links on my old EZIO6i last night. I haven't sync'ed it for awhile (and a few indigo versions ago), and now it won't recognize the EZIO6i. Can't define and sync or re-sync links. The firmware version reported on the Indigo device is 26 (i2 engine), but the log says 00 below during the linking sequence.
matt (support) wrote:Korey wrote:Cant Link EZIO40, Seems indigo doesn't recognize it. Suggestions?
The EZIO40 should have a device type ID of 1800, not 810. I'm not sure why it is reporting the incorrect ID. Try factory resetting it to see if that gets it working.
