Hello,
I have tried to connect to an EasyDAQ DO24PRMx-2Stack using Indigo v 6.0. So far, I've been less than successful. There is no specific pull down for a 48 relay stack in the menu. Using the 24 relay pull down, and attempting to activate relay #1 will activate relays 1-16 on both boards. Disconnecting the second board yields the same result with only board #1. Attempting to activate any other relay does nothing either alone or in concert with relay #1.
Do I have a driver problem or a hardware problem?
Tom
