-- program: LeoLamp
-- set brighness level for CREED lamps
-- V1.0
-- Karl Wachs
-- June 19, 2013
-- how to use
-- set variable "lamp"Command to UP or anythinge else, if UP brighten otherwise dim
-- variable "Lamp"Level is set to new current level of brightnet of lamp
-- set variable "Lamp"Debug is used to decied if log should be written
--- set LAMP to name of device to be dimmed/brightened
global debug
set debug to false -- if true add logfile entries add info to indigo logfile
set initialize to 0
set action to "UP"
set Lamp to "LeoCeilingLight"
global Lamp
on toLog(xxx) -- must be called outside "tell application indigioserver" … otherwise it does an end tell
global debug
if debug then
log Lamp & " " & xxx
end tell
end if
end toLog
toLog("starting v 1.0")
-- get parameters from indigo, check if everythings is setup properly, if not try to correct
try
set LL to Lamp & "Debug"
set debug to (get value of variable LL) as boolean
set LL to Lamp & "Command"
set action to (get value of variable LL) as text
set LL to Lamp & "Level"
set Lev to (get value of variable LL) as number
end tell
on error
set initialize to 1 -- to be done
return -1
end try
toLog(action)
toLog(Lev)
-- all setup for nornal operations
---------------- end initializing
-- now run through the different commands and brightness levels
-- levels used: : 6 10 15 25 50 100
if action = "UP" then ----- other wise down +++++++++++++++++++++++++++++++++++++++++
set NewLevel to 100
if Lev < 5 then
set NewLevel to 6
else
if Lev < 7 then
set NewLevel to 10
else
if Lev < 11 then
set NewLevel to 15
else
if Lev < 16 then
set NewLevel to 25
else
if Lev < 26 then
set NewLevel to 50
else
if Lev < 51 then
set NewLevel to 100
end if
end if
end if
end if
end if
end if
if Lev = NewLevel then
else
brighten Lamp to NewLevel
set value of variable LL to NewLevel
end tell
end if
else
set NewLevel to 0
if Lev > 99 then
set NewLevel to 50
else
if Lev > 49 then
set NewLevel to 25
else
if Lev > 24 then
set NewLevel to 15
else
if Lev > 14 then
set NewLevel to 10
else
if Lev > 9 then
set NewLevel to 6
else
if Lev > 5 then
set NewLevel to 0
end if
end if
end if
end if
end if
end if
else
dim Lamp to NewLevel
end tell
end if
end if
kennybroh wrote:Matt or Jay-- does the Cree dim to the same or close to the same low level as an incandescent? The lowest level for my other LEDs is much brighter.
