Smartphone Radar - Smartphone presence detection (Locked)
Thu Jun 20, 2013 3:48 pm
Re: Smartphone Radar - Smartphone presence detection (Update
Are you sure you're using the latest client (b10)?
Thu Jun 20, 2013 3:50 pm
travisc offline
Strange. I can see 3 events in beta 9. All Phones Home, Away, etc. I haven't had a chance to upgrade to beta 10 yet.
Thu Jun 20, 2013 3:52 pm
Korey offline
Yes.
Screen Shot 2013-06-20 at 5.52.13 PM.PNG (10.25 KiB) Viewed 8689 times
Korey
Thu Jun 20, 2013 4:42 pm
Odd - and the plugin is enabled? Try restarting the server and client.
Thu Jun 20, 2013 6:35 pm
Korey offline
Yes the plugin is enabled.
I had tried everything I could think of before posting. Re-started Indigo server, reloaded plugin, made sure plugin was up to date, rebooted computer, delete smartphone device and add an new one, nothing has helped, hence my original post.
So for fun, I just tried rebooting again.
Still no Joy :(
Jun 20, 2013 7:17:29 PM
Quiting Indigo Server - received slow quit signal
Quiting Indigo Server - stopping plugins
Stopping plugin "Meta Device 0.9.9" (pid 202)
Stopping plugin "Smartphone Radar 1.1.3" (pid 6443)
Jun 20, 2013 7:24:19 PM
Starting Indigo Server version 6.0.0 b10
Loading attachments
"device target attachment.scpt" script loaded
"group target attachment.scpt" script loaded
"growl attachment.scpt" script loaded
"iTunes attachment.scpt" script loaded
"scenes attachment.scpt" script loaded
"Sunrise Simulation.scpt" script loaded
"time stamp attachment.scpt" script loaded
Jun 20, 2013 7:24:41 PM
Loading plugin "Action Collection 1.4.3"
Starting plugin "Action Collection 1.4.3" (pid 192)
Loading interface "INSTEON Commands 2.0.4"
Starting interface "INSTEON Commands 2.0.4" (pid 193)
Loading interface "Z-Wave 1.0.73"
Starting interface "Z-Wave 1.0.73" (pid 194)
Loading plugin "Cynical Caché 1.5.1"
Starting plugin "Cynical Caché 1.5.1" (pid 195)
Loading plugin "Cynical Network 1.5.1"
Starting plugin "Cynical Network 1.5.1" (pid 196)
Loading plugin "Cynical SecuritySpy 1.4.2"
Starting plugin "Cynical SecuritySpy 1.4.2" (pid 197)
Loading plugin "Find My IDevices 1.715"
Starting plugin "Find My IDevices 1.715" (pid 198)
Loading plugin "Growl 1.1.0"
Starting plugin "Growl 1.1.0" (pid 199)
Loading plugin "iTunes 1.1.0"
Starting plugin "iTunes 1.1.0" (pid 200)
Loading plugin "Meta Device 0.9.9"
Starting plugin "Meta Device 0.9.9" (pid 201)
Loading plugin "NOAA Weather Plus 1.1.13"
Starting plugin "NOAA Weather Plus 1.1.13" (pid 202)
Loading plugin "NOAA Weather 1.1.0"
Starting plugin "NOAA Weather 1.1.0" (pid 203)
Loading plugin "Simple Serial Plugin 0.9.3"
Starting plugin "Simple Serial Plugin 0.9.3" (pid 204)
Loading plugin "RFXCOM 1.3.5"
Starting plugin "RFXCOM 1.3.5" (pid 205)
Loading plugin "Smartphone Radar 1.1.3"
Starting plugin "Smartphone Radar 1.1.3" (pid 206)
Loading plugin "SQL Logger 1.1.6"
Starting plugin "SQL Logger 1.1.6" (pid 207)
Loading plugin "Thermostat Enhancement Add-On 1.11"
Starting plugin "Thermostat Enhancement Add-On 1.11" (pid 208)
Loading plugin "Timers and Pesters 1.1.3"
Starting plugin "Timers and Pesters 1.1.3" (pid 209)
Loading plugin "Weather Conditions 0.98"
Starting plugin "Weather Conditions 0.98" (pid 210)
Found disabled plugin "Airfoil 1.1.0"
Found disabled plugin "Cynical Calendars 1.5.0"
Found disabled plugin "DIRECTV DVR Control 1.0.0"
Found disabled plugin "DSC Alarm 0.9.0"
Found disabled plugin "EasyDAQ Relay Card 1.1.0"
Found disabled plugin "Global Cache 1.0.0"
Found disabled plugin "Group Trigger 0.9.15"
Found disabled plugin "iCal Alarm Processor 1.1.0"
Found disabled plugin "Master Irrigation 0.9.5"
Found disabled plugin "Phidgets 0.5.3"
Found disabled plugin "Switchboard 0.551"
Found disabled interface "Virtual Devices 1.0.5"
Found disabled plugin "WeatherSnoop 1.1.2"
Bonjour registered "Indigo - 182 Edgemont Drive V6"
Indigo Cocoa client connected
Started plugin "Simple Serial Plugin 0.9.3"
Started plugin "Smartphone Radar 1.1.3"
Korey
Thu Jun 20, 2013 7:30 pm
bluepine offline
travisc wrote:
bluepine wrote:
Playing around tonight again and it's weird. SPR picks up the phone on fresh start of the plug in or a newly added device and instantly recognizes when i turn the wifi off, then starts the increment timer. Just won't pick up when the phone's wifi turns back on unless i restart the plug in. So it's getting some info :? lol
Your router seems to be logging the sign off's but the sign ons. You have to watch the router log to see what your router is sending to SPR. If SPR doesn't see your IP or MAC address mentioned then it will not reset the timer. You may need to increase the log-level. At a minimum you need it to at least log when the phone sign's on and off. Ideally you'd want some connection logging in there too.
Ok. I figured it out. Read instructions completely (saying to myself). :shock: lol. I didn't do the port forward instructions for Snow Leopard.duh! Anywho, it seems to be working. SPR doesn't recognize the phone on the network until I look at a webpage then it instantly turns the variable true. Even checking email doesn't trigger it. I'll keep reading.
Thanks again for your patience, plug-in and help.
Todd
Fri Jun 21, 2013 9:14 am
Yes.
Well, dang. It looks like a fix didn't get into the b10 build that was supposed to. Keep an eye out for a new build that fixes it.
Fri Jun 21, 2013 4:34 pm
Korey offline
Cool, Thanks Jay.
Korey
Sat Jun 22, 2013 9:25 am
If you're experiencing this issue, send an email to indigo DASH support AT perceptiveautomation DOT com and let me know. I'll send you an internal build of the Client that fixes it.
Thu Jul 11, 2013 4:45 am
Dewster35 offline
Travis,
Is there a way to manually change a state of a phone device? I have a number of devices setup as guests that trigger a company mode and they all automatically end up as "home" after a reboot of indigoserver. Is there a good way to change them all to "vacation"?
Fri Jul 12, 2013 3:52 am
McJohn offline
Hello all,
Can anybody help me with an AppleScript which calculate the actual leaving time from Smartphone Radar?
The default "Minutes Till Away" is set to 2 Minutes in the plugin.
I discovered that are about 6 minutes difference between the SPR leaving Variable and the real time.
So, I made an AppleScript which calculate the SPR Time (a variable) - 6 but I got an error in AppleScript that the Time can't be set to a number (Can’t make "11:28" into type number.).
I think I'm doing something wrong :-)
set AwayJohnTime to value of variable "AwayJohnTime"
set value of variable "AwayJohnTimeMin6" to {AwayJohnTime - 6} as string
end tell
Or is there another more simple solution in Indigo?
Thanks for the help and kind regards,
John
Fri Jul 19, 2013 10:17 pm
hamw offline
I have three of the new little Airport Expresses -- they work great and have much better range and connectivity than the Gen 1 APE. I *think* I've enrolled them in SPR by IP address and "public", but when I'm in my media room, for instance, my phone falls off SPR. Do they behave differently or am I missing something?
Mon Jul 22, 2013 1:46 am
McJohn offline
Did you specify all the 3 new Airports in SPR?
In the Plugin config, you can specify the AP IP addresses and passwords,
separated by comma.
Is the AP range in your media room good enough? Maybe you can install this AP in another side of the room.
Are they connected with each other with an ethernet cable and is it one AP network?
Greetings,
John
Tue Jul 23, 2013 7:43 pm
travisc offline
Hi Everyone,
In an effort to make discussing this plugin more efficient, we're switching from a single topic format to a folder. Please create new topics in this plugin's folder as you would in any other forum.
If you'd like to be notified when the plugin is updated. Please subscribe to the topic below. I will post there once for each release.
Smartphone Radar - Information and Installation
This topic is now locked.
