McJohn wrote:I installed the old Airport Util
http://www.macinstruct.com/node/491
BUT it seems to be that SNMP is totally disappeared in the new Airport Extreme 2013.
Screendump with the Airport Express
and a screendump with the new Airport Extreme
Only syslog can be enabled, but that's a problem for me because I don't know how this works.
Kind regards,
John
Dewster35 wrote:Damn... hopefully that is just because the new Airports aren't supported by the old utility? I like the direction Apple is headed on most things, but when it comes to this sort of thing, stripping away features (In the new utility) because to some people they are confusing, it really is disappointing. Hopefully someone here can help you out.
McJohn wrote:That's right Korey, I read the same specs on the Apple site this morning .
The Wifi range of the new Airport is larger, and it's a nice product, BUT without SNMP (I think it's the hardware, not the utility)
The simplicity of connecting Smartphone Radar with Airport is perfect for me.
So, I decided to install an extra "old" Extreme to extend my Wifi range and hope that Apple
never makes a firmware update for the "old" Extreme and removes the SNMP....
Kind regards,
John
bluepine wrote:Great plug in but need some help.
Installed the plugin without a hitch and set my Dlink 825 to forward the syslog to my mac that has Indigo. Created my phone as a device and no problem there. When I turn off the wifi on the phone, radar updates to that state. Now for some reason when I turn my wifi back on it Radar doesn't pick it up but just continues to "implement........". Any ideas? Could the syslog not be sending that information of the phone logging on?
Using newest version of Indigo Beta.
Todd
bluepine wrote:Took a quick look at it this morning and the log doesn't appear in the events window. So I'll have to trouble shoot this router and see if there's a way to make sure it's forwarding properly.
Thanks for your help
bluepine wrote:Playing around tonight again and it's weird. SPR picks up the phone on fresh start of the plug in or a newly added device and instantly recognizes when i turn the wifi off, then starts the increment timer. Just won't pick up when the phone's wifi turns back on unless i restart the plug in. So it's getting some info lol
