Let me know if this is not what you need...
version : 0
Hue Lights Debug Command is TurnOn, Bulb is 1
Hue Lights Debug device on:
actionValue : 0
delayAmount : 900
description : turn on device
deviceAction : TurnOn
deviceId : 1857648473
replaceExisting : True
textToSpeak :
Hue Lights Error Default ramp rate could not be obtained: empty string for float()
Hue Lights Debug Sending URL request:
http://10.0.1.61/api/67ea91faa8738a08da ... ts/1/state Hue Lights Debug Got response - [{"success":{"/lights/1/state/transitiontime":5}},{"success":{"/lights/1/state/bri":255}},{"success":{"/lights/1/state/on":true}}]
Hue Lights Debug updateDeviceState: Updating device Hue GR Right Front state: brightnessLevel = 100
Hue Lights "Hue GR Right Front" on to 100 at ramp rate 0.5 sec.
Hue Lights Debug updateDeviceState: Updating device Hue GR Right Front state: colorRed = 255
Hue Lights Debug updateDeviceState: Updating device Hue GR Right Front state: colorGreen = 215
Hue Lights Debug updateDeviceState: Updating device Hue GR Right Front state: colorBlue = 112
Hue Lights Debug updateDeviceProps: Updating device Hue GR Right Front properties.
Hue Lights Debug didDeviceCommPropertyChange called.
Hue Lights Debug actionControlDimmerRelay called for device Hue GR Right Front. action: actionValue : 0
delayAmount : 900
description : turn off device
deviceAction : TurnOff
textToSpeak :
device: address : 10.0.1.61 (ID 1)
brightness : 100
buttonGroupCount : 0
configured : True
defaultBrightness : 100
description :
deviceTypeId : hueBulb
enabled : True
errorState :
folderId : 0
com.nathansheldon.indigoplugin.HueLights : (dict)
address : 10.0.1.61 (ID 1) (string)
bulbId : 1 (string)
nameOnHub : GR F Right (string)
rate : (string)
savedBrightness : 255 (integer)
lastChanged : 2012-11-27 23:37:59
ledStates : []
model : Hue Bulb
name : Hue GR Right Front
onBrightensToDefaultToggle : False
onBrightensToLast : False
onState : True
pluginId : com.nathansheldon.indigoplugin.HueLights
pluginProps : com.nathansheldon.indigoplugin.HueLights : (dict)
bulbId : 1 (string)
rate : (string)
protocol : Plugin
remoteDisplay : True
states : States : (dict)
alertMode : none (string)
brightnessLevel : 100 (integer)
colorBlue : 112 (integer)
colorGreen : 215 (integer)
colorMode : xy (string)
colorRed : 255 (integer)
colorTemp : 2000 (integer)
colorX : 0.5609 (real)
colorY : 0.4016 (real)
effect : none (string)
hue : 58 (integer)
onOffState : on (on/off bool)
online : true (bool)
saturation : 97 (integer)
subModel :
supportsAllOff : False
supportsStatusRequest : True
version : 0
Hue Lights Debug Command is TurnOff, Bulb is 1
Hue Lights Debug device off:
actionValue : 0
delayAmount : 900
textToSpeak :
http://10.0.1.61/api/67ea91faa8738a08da ... ts/1/state Hue Lights Debug Got response - [{"success":{"/lights/1/state/transitiontime":5}},{"success":{"/lights/1/state/on":false}}]
