- Posted on
Tue Sep 03, 2013 12:40 pm
wideglidejrp
offline
I am getting a lot of Sonos plugin errors. The functions are generally working but sometimes I have to reload the plugin to make things work. Here is what I am getting:
Sonos Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 53, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 100, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 206, in checkDirect
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 218, in checkOneDirect
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 367, in parsePositionInfo
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/urllib2.py", line 124, in urlopen
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/urllib2.py", line 387, in open
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/urllib2.py", line 498, in http_response
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/urllib2.py", line 425, in error
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/urllib2.py", line 360, in _call_chain
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/urllib2.py", line 506, in http_error_default
<class 'urllib2.HTTPError'>: HTTP Error 403: Forbidden
Sonos Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Sonos Error Error in plugin execution ExecuteAction:
File "plugin.py", line 127, in actionZP_RT_FavStation
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 842, in actionDirect
