Okay, after much debating, and much delay... I'm releasing v1.01.
• Changes in v1.01
⁃ v1.01 Public Release 9/25/2011
⁃ Added MobileMe Login "recycling". FMID attempts to reuse existing MobileMe Connections, instead of logging in anew every time.
⁃ Includes AutoUpdate notification via
http://www.indigo-plugins.com ⁃ Includes preliminary MobileMe Message support. Your trigger actions, action groups, etc can send MobileMe notifications to particular MobileMe devices.
⁃ This is very beta, and I would appreciate any feedback, regarding this feature.
• Changes in v0.99
⁃ v0.99 Public Release 08/25/2011
⁃ Beta 3
⁃ v0.99 B3 - Refactored pygmaps to eliminate the last vestages of file writing and passing the output variable to the functions. (Pygmaps is not my creation)
⁃ Added map_controls to the upper right of the google map (for use by the Zones devices).
⁃ Fixed bug in Decrease Sleep trigger action, it would only allow you to reduce the Sleep delay to 30 minutes. Now you can reduce down to 15.
⁃ Added the ability to Set the specific refresh time via trigger actions.
⁃ Added new State ("FencedAreaName"), if a device is found within a FencedArea, the Indigo Device Name of the Zone it is in, will be placed in this state.
⁃ This allows you to check the state of the device to find out if it's within a zone.
⁃ You will need to go in to each Find my iDevice, change the device type away from Find my iDevice, and then change it back. That will cause the idevice states to be rebuilt and thus add the new state.
⁃ Fixed issue with MobileMe / iCloud, required an update to RecordMyLatitude's json process to: "appVersion":"1.2" to "appVersion":"1.2.1"
⁃ Changed Alternative MobileMe login device wording to be platform agnostic
⁃ I may add Google Latitude Support - Your feedback may be the deciding factor
⁃ Changed wording on the Disable Locating device field
http://dl.dropbox.com/u/241415/Find%20M ... 0v1.01.zip
