Indigo Weather Conditions Plugin (for Indigo 5) is released.
Fri Jun 24, 2011 5:28 pm
bschollnick2 offline
Folks,
I am officially releasing the Indigo Weather Conditions plugin.
Currently it supports Google Weather, and Weather Underground... I do plan to add NOAA support to it soon.
http://dl.dropbox.com/u/241415/Indigo%2 ... 0v0981.zip
My Plugins for Indigo (v4, v5, and v6) - http://bit.ly/U8XxPG
Security Script for v4 - http://bit.ly/QTgclf
for v5 - http://bit.ly/T6WBKu
Support Forum(s) - http://www.perceptiveautomation.com/userforum/viewforum.php?f=33
Sat Jun 25, 2011 8:12 am
nlagaros offline
Re: Indigo Weather Conditions Plugin (for Indigo 5) is relea
Very cool plugin - one note is that the images do not seem to be in the package under IWS\Weather-Conditions\images.
Sat Jun 25, 2011 8:54 am
The images are provided by the Weather Provider, and thus doesn't need to be duplicated in the plugin.
The weather providers actually provide the fully path and URL for the icons, thus we are hot-linking to the icons... But it's acceptable use per their licenses...
Sat Jun 25, 2011 12:54 pm
Very cool! Great contribution, Benjamin. Thanks.
Wed Aug 17, 2011 7:31 pm
casagold offline
I followed the instructions and things seem to be working fine but I am getting the following message in the log:
Aug 17, 2011 8:40:38 PM
Retrieving Weather Condition Information from Weather Underground
Unable to write data file to: /library/Application Support/Perceptive Automation/Indigo 5/IndigoWebServer/plugins/Weather-Conditions/pickled_data
Data retrieved from Weather Underground, and Saved.
What is causing the "Unable to write data file to....."
Any help is appreciated.
Wed Aug 17, 2011 8:24 pm
Everything is working fine, and your getting that error? If your receiving that error, then it shouldn't be working...
The pickled_data file is what stores the current weather data...
I'll take a closer look and see if there is an odd situation for that error message, but nothing comes to mind...
Thu Aug 18, 2011 4:29 am
casagold offline
I figured it out. I didn't follow the instructions properly. I copied the IWS folder and all of it's contents to /IndigoWebServer/plugins rather than just the Weather-Conditions folder. Hope I didn't waste too much of your time. Thanks.
Thu Aug 18, 2011 10:25 am
That's perfectly fine.... I'm glad that it was something relatively simple....
Sat Dec 03, 2011 6:38 pm
mat offline
Great plugin and works in Europe!
The indigo web server is not providing any images though? I just have small little blue boxes. Have I missed something?
Is there a way to get the images or forecast into a control page please?
Thanks for your hard work.
Cheers
Mat
Late 2018 mini 10.14
Sat Dec 03, 2011 10:44 pm
Cheers
Mat
It depends... The image links should be derived directly from the weather source that you are using.
So I'll need some details on what settings your using... Can you elaborate on how you have it setup?
- Ben
Sun Dec 04, 2011 4:30 am
mat offline
Hi Ben
Thanks.....
I have 0.98 installed.
Configuration is
Google
Horizontal
Post code
15 minutes
Export to variable
I have inserted a couple of the variables to a contril page and can see those on ISO devices.
I looked at the indigo web page generated by my local server, clicked on weather on the bottom, and all details load appart from the pictures.
Checked indigo5\indigowebserver\plugins\weather-conditions\images and that's empty. Cant see any other local weather images elsewhere either.
Let me know if you need anything else.
Thanks.
On another point, can I get the image and forecast into a control page?
Cheers
Mat
Mon Dec 12, 2011 11:54 pm
Dave Durham offline
Hi Ben, thanks again for the plug in, very slick. I have a question similar to Mat's above. How do I get a Forecast onto a Control Page??? I don't see the forecast variables in my list, only the current conditions. What am I missing???
Thanks in advance,
-d
Tue Dec 13, 2011 6:06 am
Otis offline
I'm looking for weather forecast information, too. Any suggestions?
Tue Dec 13, 2011 11:28 am
mat wrote:
Hi Ben
Configuration is
Google
Horizontal
Post code
15 minutes
Export to variable
I have a test version of v1.00 available. Please email me at Benjamin AT schollnick DOT net, and I'll send you a copy for you to test to ensure that it has solved the google image issue.
Tue Dec 13, 2011 11:36 am
Okay, that's a surprise to me. Device States are available, as I expected... But technically the Weather Conditions plugin doesn't have a device. The plugin itself has states...
-- correction --
I just looked at the code, and realized that I misremembered the code. I see no state declarations in my xml definition...
Matt & Jay, is this something that is not technically supported? I realize I can sit down and make a dummy device, or re-engineer the plugin to have a device model... Any chance that we can have plugin states displayed on control pages?
-- correction --
Matt & Jay, can a device-less plugin have states appear in the control page? And if not, can it be added?
