REMOTE debugging with PyCharm
Sun Apr 28, 2024 11:45 am
brettlid offline
Remote debugging with PyCharm
I was able to successfully get the debugging to work with PyCharm, although not without some errors. (It's pretty cool!)
I decided to give the experimental remote debugging a try. Im not sure what to use as the local and remote path mappings. I've tried lots of different combinations but nothing seems to work. Do use the paths from the local machine's perspective... or do I use a path from the remote computer's perspective?
https://wiki.indigodomo.com/doku.php?id=setting_up_a_development_environment#configure_remote_debugging_experimental
examples would be really helpful from anyone who's got it working.
Thanks, Brett
Sun Apr 28, 2024 12:50 pm
ryanbuckner offline
Re: Remote debugging with PyCharm
Thanks for going dow this road? Would you mind recording or documenting your step by step? A lot of us would love to use this
Sun Apr 28, 2024 2:25 pm
The step by step instructions here should be all you need to get it going. If you can't get it working after following these instructions, post back.
https://wiki.indigodomo.com/doku.php?id=setting_up_a_development_environment#pycharm
Sun Apr 28, 2024 2:48 pm
brettlid offline
Yep followed those instructions. My questions specifically are related to the path mapping. What do I use? A working example would be great. The standard debugging path maps don’t work.
Thanks Brett
Sun Apr 28, 2024 3:57 pm
I can post an example from my environment, but it's set up using those instructions.
I take the Indigo plugin file from my development folder and create a symbolic link to it in the Indigo plugins folder.
ln -s /Users/Dave/PycharmProjects/Announcements/Announcements.indigoPlugin /Library/Application Support/Perceptive Automation/Indigo 2023.2/Plugins
Then in PyCharm path mapping, I put the path to my development environment under local path:
and the path to the plugins folder where the symbolic link now resides under remote path.
/Library/Application Support/Perceptive Automation/Indigo 2023.2/Plugins/Announcements.indigoPlugin
That has always worked for me. If you have done this and it's not working, then I'm guessing something else is to blame.
Mon Apr 29, 2024 9:28 am
brettlid offline
Is that all done on the local machine or the remote machine?
Thanks, Brett
Mon Apr 29, 2024 9:50 am
All of it is done on the SAME machine.
As far as I know, nobody has worked out a way to work debugging over the network -- although I might have missed something on that.
Mon Apr 29, 2024 9:56 am
brettlid offline
Mon Apr 29, 2024 10:03 am
I've never tried that setup (and clearly never read that far down the page). I've always done remote debugging from the machine running Indigo.
Mon Apr 29, 2024 11:30 am
brettlid offline
Thanks anyways!
Mon Apr 29, 2024 12:42 pm
Re: REMOTE debugging with PyCharm
The path setup would be the same as described above: local path would be the path to the plugin on the Mac you're developing from, the remote path would be the full path to the plugin on the remote Mac.
Note, this is still quite experimental and is not a configuration that any of us actually develop with, so YMMV. I got it working at one point, but any number of environmental and config settings could cause issues (including newer versions of PyCharm since we haven't tested it in a while).
Mon Apr 29, 2024 1:48 pm
brettlid offline
That's what I was looking for. I didn't want to keep trying stuff if I didn't have it set up right.
