MacOS 14.3.1
Python 3.11.6
Indigo 2023.2
HomeKitLink Siri 0.6.61 (similar problem with appleTV Plugin 1.2.26)
New system, first install of this plugin. Installation fails with:
- Code: Select all
Starting plugin "HomeKitLink Siri 0.6.61" (pid 93331)
Processing requirements for plugin "HomeKitLink Siri 0.6.61"
Requirements installing, this may take a few seconds...
Error Requirements file for "HomeKitLink Siri 0.6.61" failed to process correctly, contact the developer with the following information:
Error error: subprocess-exited-with-error
× Building wheel for chacha20poly1305-reuseable (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [87 lines of output]
A setup.py file already exists. Using it.
warning: src/chacha20poly1305_reuseable/__init__.py:50:57: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:105:14: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:139:14: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:164:72: Unknown type declaration '_int' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:178:17: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:178:67: Unknown type declaration '_int' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:178:84: Unknown type declaration '_int' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:219:47: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:225:37: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:237:10: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:238:21: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:244:37: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:244:62: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:261:10: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:262:21: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:275:37: Unknown type declaration '_bytes' in annotation, ignoring
warning: src/chacha20poly1305_reuseable/__init__.py:275:62: Unknown type declaration '_bytes' in annotation, ignoring
Compiling src/chacha20poly1305_reuseable/__init__.py because it changed.
[1/1] Cythonizing src/chacha20poly1305_reuseable/__init__.py
running build
running build_py
creating /private/tmp/pip-install-flznhznr/chacha20poly1305-reuseable_91216bbe19384d0ea8ef59c4e9b5a608/build
creating /private/tmp/pip-install-flznhznr/chacha20poly1305-reuseable_91216bbe19384d0ea8ef59c4e9b5a608/build/lib.macosx-10.9-universal2-cpython-311
creating /private/tmp/pip-install-flznhznr/chacha20poly1305-reuseable_91216bbe19384d0ea8ef59c4e9b5a608/build/lib.macosx-10.9-universal2-cpython-311/chacha20poly1305_reuseable
copying src/chacha20poly1305_reuseable/__init__.py -> /private/tmp/pip-install-flznhznr/chacha20poly1305-reuseable_91216bbe19384d0ea8ef59c4e9b5a608/build/lib.macosx-10.9-universal2-cpython-311/chacha20poly1305_reuseable
copying src/chacha20poly1305_reuseable/py.typed -> /private/tmp/pip-install-flznhznr/chacha20poly1305-reuseable_91216bbe19384d0ea8ef59c4e9b5a608/build/lib.macosx-10.9-universal2-cpython-311/chacha20poly1305_reuseable
copying src/chacha20poly1305_reuseable/__init__.pxd -> /private/tmp/pip-install-flznhznr/chacha20poly1305-reuseable_91216bbe19384d0ea8ef59c4e9b5a608/build/lib.macosx-10.9-universal2-cpython-311/chacha20poly1305_reuseable
running build_ext
File "/private/tmp/pip-install-flznhznr/chacha20poly1305-reuseable_91216bbe19384d0ea8ef59c4e9b5a608/setup.py", line 35, in <module>
setup(**setup_kwargs)
File "/private/tmp/pip-build-env-tphwey87/overlay/lib/python3.11/site-packages/setuptools/__init__.py", line 103, in setup
return distutils.core.setup(**attrs)
File "/private/tmp/pip-build-env-tphwey87/overlay/lib/python3.11/site-packages/setuptools/_distutils/core.py", line 185, in setup
return run_commands(dist)
File "/private/tmp/pip-build-env-tphwey87/overlay/lib/python3.11/site-packages/setuptools/_distutils/core.py", line 201, in run_commands
dist.run_commands()
File "/private/tmp/pip-build-env-tphwey87/overlay/lib/python3.11/site-packages/setuptools/_distutils/dist.py", line 969, in run_commands
self.run_command(cmd)
File "/private/tmp/pip-build-env-tphwey87/overlay/lib/python3.11/site-packages/setuptools/dist.py", line 963, in run_command
super().run_command(command)
File "/private/tmp/pip-build-env-tphwey87/overlay/lib/python3.11/site-packages/setuptools/_distutils/dist.py", line 988, in run_command
cmd_obj.run()
File "/private/tmp/pip-build-env-tphwey87/overlay/lib/python3.11/site-packages/setuptools/_distutils/command/build.py", line 131, in run
self.run_command(cmd_name)
File "/private/tmp/pip-build-env-tphwey87/overlay/lib/python3.11/site-packages/setuptools/_distutils/cmd.py", line 318, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/private/tmp/pip-build-env-tphwey87/overlay/lib/python3.11/site-packages/setuptools/_distutils/command/build_ext.py", line 315, in run
customize_compiler(self.compiler)
File "/private/tmp/pip-build-env-tphwey87/overlay/lib/python3.11/site-packages/setuptools/_distutils/sysconfig.py", line 291, in customize_compiler
_osx_support.customize_compiler(_config_vars)
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/_osx_support.py", line 488, in customize_compiler
_find_appropriate_compiler(_config_vars)
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/_osx_support.py", line 244, in _find_appropriate_compiler
raise SystemError(
SystemError: Cannot locate working compiler
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 353, in <module>
main()
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 335, in main
json_out['return_val'] = hook(**hook_input['kwargs'])
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 251, in build_wheel
return _build_backend().build_wheel(wheel_directory, config_settings,
File "/private/tmp/pip-build-env-tphwey87/overlay/lib/python3.11/site-packages/poetry/core/masonry/api.py", line 58, in build_wheel
return WheelBuilder.make_in(
File "/private/tmp/pip-build-env-tphwey87/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 88, in make_in
wb.build(target_dir=directory)
File "/private/tmp/pip-build-env-tphwey87/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 121, in build
self._build(zip_file)
File "/private/tmp/pip-build-env-tphwey87/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 182, in _build
self._run_build_command(setup)
File "/private/tmp/pip-build-env-tphwey87/overlay/lib/python3.11/site-packages/poetry/core/masonry/builders/wheel.py", line 248, in _run_build_command
subprocess.check_call([
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/subprocess.py", line 413, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['/Library/Frameworks/Python.framework/Versions/3.11/bin/python3.11', '/private/tmp/pip-install-flznhznr/chacha20poly1305-reuseable_91216bbe19384d0ea8ef59c4e9b5a608/setup.py', 'build', '-b', '/private/tmp/pip-install-flznhznr/chacha20poly1305-reuseable_91216bbe19384d0ea8ef59c4e9b5a608/build', '--build-purelib', '/private/tmp/pip-install-flznhznr/chacha20poly1305-reuseable_91216bbe19384d0ea8ef59c4e9b5a608/build/lib', '--build-platlib', '/private/tmp/pip-install-flznhznr/chacha20poly1305-reuseable_91216bbe19384d0ea8ef59c4e9b5a608/build/lib.macosx-10.9-universal2-cpython-311']' returned non-zero exit status 1.
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for chacha20poly1305-reuseable
ERROR: Could not build wheels for chacha20poly1305-reuseable, which is required to install pyproject.toml-based projects
HomeKitLink Siri Error Error in plugin execution InitializeMain:
File "plugin.py", line 47, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 2023.2/Plugins/HomeKitLink-Siri.indigoPlugin/Contents/Server Plugin/pyhap/accessory.py", line 24, in <module>
type: No module named 'base36'
Stopping plugin "HomeKitLink Siri 0.6.61" (pid 93331)
Stopped plugin "HomeKitLink Siri 0.6.61"
