Bond Home Plugin
Sun Oct 08, 2023 11:44 am
Re: Bond Home Plugin
Might have been a change in the Bond API that I missed. Delete the device. Turn on debug logging, restart the plugin, and recreate the device. Then open an issue on GitHub and post the log there.
Also do the "Write Device Information to log" menu command and put that in the GitHub issue.
Sat Oct 14, 2023 10:29 am
Release 2022.1.4 now available, plugin store or https://github.com/FlyingDiver/Indigo-B ... g/2022.1.4
This release fixes the issues with push updates from the Bond device. Indigo device states should now match the states as represented in the Bond app.
Sat Oct 14, 2023 5:06 pm
wow if this does what I think it does, that's HUGE! Thanks very much!
Sat Oct 14, 2023 6:04 pm
It works for all the devices I tested with, so I'm happy.
Sun Oct 15, 2023 9:02 am
On first test, it doesn’t seem to work with my exceptionally stupid fans, which don’t really have On/Off, just toggle. (And by work, I mean correctly track the fan’s state.)
But I’ll keep experimenting to make sure.
Sun Oct 15, 2023 9:04 am
Yeah, that's a problem. Turn on debug logging, send a command, then post the log segment so I can see what the Bond is reporting back to the plugin. Maybe there's something there useful.
Sun Oct 15, 2023 9:32 am
I'll get the logs, but my intuition tells me that the fan itself doesn't actually report to the Bond bridge. I think it just accepts commands.
I'll test this theory by watching the Bond app to see if it notices changes to the fan done by the stock fan controller. These fans are over ten years old.
Sun May 05, 2024 9:59 am
t-star offline
I keep getting the following for all my fans. They are not Bond smart fans. I had to add it via the remote. Is this something I can fix (add a variable in Indigo etc.) without buying new fans?
device "FR Ceiling fan" state key onOffState not defined (ignoring update request)
Just making sure. Thanks!
Sun May 05, 2024 10:17 am
Sounds like the plugin is not getting the correct info from the Bond Bridge to identify it as a ceiling fan.
Right click on the device in the Indigo client and use the "Print Device Details to Event Log" menu command, then post the output here.
Sun May 05, 2024 10:35 am
t-star offline
here you go....
FYI: version: plugin "Bond Home 2023.2.0"
I also get
"device "Bond Bridge" state key brightnessLevel not defined (ignoring update request)" when it starts
   Bond Home
    "ZZDF76026._bond._tcp.local.": {
        "bondid": "ZZDF76026",
        "ip_address": "192.168.1.132",
        "make": "Olibra",
        "model": "BD-1000"
   Bond Home
    "ZZDF76026": {
        "066e0dec": {
            "_": "2c62b0cb",
            "__": "e54e3cbf",
            "actions": [
                "DecreaseSpeed",
                "IncreaseSpeed",
                "SetDirection",
                "SetSpeed",
                "StartDimmer",
                "Stop",
                "ToggleDirection",
                "ToggleLight",
                "TogglePower",
                "TurnLightOff",
                "TurnLightOn",
                "TurnOff",
                "TurnOn"
            "commands": {
                "_": "f039b62a"
            "location": "Family Room",
            "name": "FR Ceiling fan",
            "properties": {
                "_": "264a6295"
            "skeds": {
                "_": "00000000"
            "state": {
                "_": "14ef34a7"
            "template": "A3a",
            "type": "CF"
        "13b426e5": {
            "_": "c5a7b1b5",
            "__": "e5b5ddb5",
            "actions": [
                "DecreaseSpeed",
                "IncreaseSpeed",
                "SetDirection",
                "SetSpeed",
                "StartDownLightDimmer",
                "StartUpLightDimmer",
                "Stop",
                "ToggleDirection",
                "ToggleDownLight",
                "ToggleLight",
                "TogglePower",
                "ToggleUpLight",
                "TurnDownLightOff",
                "TurnDownLightOn",
                "TurnLightOff",
                "TurnLightOn",
                "TurnOff",
                "TurnOn",
                "TurnUpLightOff",
                "TurnUpLightOn"
            "commands": {
                "_": "bd37a3a6"
            "location": "Sleeping Porch",
            "name": "SP Ceiling fan",
            "properties": {
                "_": "9280189f"
            "skeds": {
                "_": "00000000"
            "state": {
                "_": "90f41546"
            "template": "A3",
            "type": "CF"
        "3e5c355c": {
            "_": "2a537576",
            "__": "c6061f19",
            "actions": [
                "DecreaseSpeed",
                "IncreaseSpeed",
                "SetDirection",
                "SetSpeed",
                "Stop",
                "ToggleDirection",
                "ToggleDownLight",
                "ToggleLight",
                "TogglePower",
                "ToggleUpLight",
                "TurnDownLightOff",
                "TurnDownLightOn",
                "TurnLightOff",
                "TurnLightOn",
                "TurnOff",
                "TurnOn",
                "TurnUpLightOff",
                "TurnUpLightOn"
            "commands": {
                "_": "0dc2d327"
            "location": "Screen Porch",
            "name": "Ceiling fan",
            "properties": {
                "_": "558e33b0"
            "skeds": {
                "_": "00000000"
            "state": {
                "_": "90f41546"
            "template": "A3",
            "type": "CF"
        "53913e1e": {
            "_": "213d6751",
            "__": "d323882b",
            "actions": [
                "DecreaseSpeed",
                "IncreaseSpeed",
                "SetSpeed",
                "Stop",
                "ToggleLight",
                "TogglePower",
                "TurnLightOff",
                "TurnLightOn",
                "TurnOff",
                "TurnOn"
            "commands": {
                "_": "f2525ca9"
            "location": "Office",
            "name": "Office fan",
            "properties": {
                "_": "56617eed"
            "skeds": {
                "_": "00000000"
            "state": {
                "_": "cc782c9c"
            "type": "CF"
        "5ce9067a": {
            "_": "79cc8050",
            "__": "1a3435ea",
            "actions": [
                "DecreaseSpeed",
                "IncreaseSpeed",
                "SetDirection",
                "SetSpeed",
                "Stop",
                "ToggleDirection",
                "ToggleDownLight",
                "ToggleLight",
                "TogglePower",
                "ToggleUpLight",
                "TurnDownLightOff",
                "TurnDownLightOn",
                "TurnLightOff",
                "TurnLightOn",
                "TurnOff",
                "TurnOn",
                "TurnUpLightOff",
                "TurnUpLightOn"
            "commands": {
                "_": "532db44f"
            "location": "Master Bedroom",
            "name": "MB Ceiling fan",
            "properties": {
                "_": "e84b67d5"
            "skeds": {
                "_": "00000000"
            "state": {
                "_": "4ce32995"
            "template": "A3",
            "type": "CF"
        "799bb94e2c6464dc": {
            "_": "ef611208",
            "__": "ac32ece5",
            "actions": [
                "Stop",
                "TogglePower",
                "TurnOff",
                "TurnOn"
            "commands": {
                "_": "2e222a2a"
            "name": "Fireplace",
            "properties": {
                "_": "34239178"
            "skeds": {
                "_": "00000000"
            "state": {
                "_": "2bee6d65"
            "template": "RFP15",
            "type": "FP"
Sun May 05, 2024 10:46 am
That's output of the plugin's menu command. I need the details for the Indigo device that's showing the error.
Sun May 05, 2024 10:55 am
t-star offline
sorry. here are 2. they are both ceiling fans. same company/model except #1 has a light and #2 doesn't
#1
   Script                          address : 066e0dec
batteryLevel : None
buttonGroupCount : 0
configured : True
description : Family room fan  (066e0dec)
deviceTypeId : bondDevice
displayStateId :
displayStateImageSel : NoImage
displayStateValRaw : None
displayStateValUi :
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 445826354
     com.flyingdiver.indigoplugin.bondhome : (dict)
          address : 066e0dec (string)
          bond_type : CF (string)
          bridge : ZZDF76026 (string)
          off_command : TurnOff (string)
          on_command : TurnOn (string)
lastChanged : 2022-05-28 11:57:53
lastSuccessfulComm : 2022-05-28 11:57:53
model : Bond Generic Device
name : FR Ceiling fan
ownerProps : com.flyingdiver.indigoplugin.bondhome : (dict)
pluginId : com.flyingdiver.indigoplugin.bondhome
protocol : Plugin
remoteDisplay : False
states : States : (dict)
subModel : Ceiling Fan
subType : Ceiling Fan
supportsAllOff : False
supportsOnState : False
supportsStatusRequest : False
version : None
#2:
   Script                          address : 3e5c355c
batteryLevel : None
configured : True
description : Main screen porch fan (3e5c355c)
displayStateId :
displayStateValUi :
enabled : True
errorState :
          address : 3e5c355c (string)
          off_parameter :  (string)
          on_parameter :  (string)
lastChanged : 2022-05-28 15:00:31
lastSuccessfulComm : 2022-05-28 15:00:31
name : Porch Ceiling fan
protocol : Plugin
version : None
Sun May 05, 2024 10:57 am
t-star offline
here is how it looks in the app:
Sun May 05, 2024 11:00 am
Hmm. supportsOnState is False for your fans, but True for mine. But the bond_type is the same, which is what is supposed to control it.
Did you just recently add the plugin and these devices, or were they existing and you just updated the plugin? Or something else?
Sun May 05, 2024 11:04 am
t-star offline
had them running for between 3-4 years now. I have been cleaning up stuff in Indigo and saw the error and thought I would ask.
Do you think that the "trusted state" in the app for the device has anything to do with it? Mine is off.
